05-05-2014, 13:28 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | nokia 220 dead after flash best team help me how to revive back the phone? log: Verify files ... MAUI : RM-969_ROM_eMP_10.03.11 VIVA : RM-969_VIVA_eMP_10.03.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.03.11 JMPT : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_10.03.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 25 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 1821D6039B570938E03EE9A208E217DF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_10.03.11 SecureDecrypt : RM-969_VIVA_eMP_10.03.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.03.11 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_10.03.11 [ERROR] : [ERROR] : DA_S_FLASH_INFO_NOT_EXIST SDS info wrong, seems as damaged. RPL backup impossible OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 00 FORMAT_BIN : Ok ERASE_MAUI_INFO : ERROR WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_10.03.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 [ERROR] : DA_UART_RX_BUF_FULL Error While flash area!!! Flashing failed! Connect phone on selected interface... |
The Following User Says Thank You to prime_master786 For This Useful Post: |
05-05-2014, 15:00 | #4 (permalink) |
Member: 608370 Status: Offline Thanks Meter: 89 | sorry for misunderstading, this is the frist flash file log: Core : v1.88 , MTKx FlashEngine : v2.3 Verify files ... MAUI : RM-969_ROM_eMP_10.03.11 VIVA : RM-969_VIVA_eMP_10.03.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.03.11 JMPT : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_10.03.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 25 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 1821D6039B570938E03EE9A208E217DF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_10.03.11 SecureDecrypt : RM-969_VIVA_eMP_10.03.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.03.11 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_10.03.11 [ERROR] : [ERROR] : DA_S_FLASH_INFO_NOT_EXIST SDS info wrong, seems as damaged. RPL backup impossible OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 00 FORMAT_BIN : Ok ERASE_MAUI_INFO : ERROR WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_10.03.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 [ERROR] : DA_UART_RX_BUF_FULL Error While flash area!!! Flashing failed! Connect phone on selected interface... |
05-05-2014, 15:14 | #5 (permalink) | |||
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
05-06-2014, 06:37 | #7 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Alive phone looks like : Code: Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg Next : Code: FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Code: [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 I really want see it, because thread TITLE say us - BEST kill phones. It not true , because I not see alive phone. I see ALREADY DEAD. So, tell me true story or post real log. |
05-06-2014, 06:57 | #8 (permalink) | |
Member: 608370 Status: Offline Thanks Meter: 89 | Quote:
set was 100% working. it is true story which i am telling u from last day i have uploaded all logs please check by yourself, may be i am referring you wrong mistakenly. | |
05-06-2014, 07:51 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Finally - I see some logs. Next time - charge battery, when flash from dead mode. Short cable directly to motherboard. For this phone - wait for Repair MAUI , not have phone now, but will be in near 2-3 days. |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-13-2014, 17:38 | #14 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Congrats! Sorry, but it is not my problem how teach people charge battery and rest things. I told you already here : http://forum.gsmhosting.com/vbb/10306658-post41.html Now : Wait for update. Probably , it will be in near 1-2 days with repair files. Here , just for example, few fresh stories with 220 : http://forum.gsmhosting.com/vbb/10300907-post7461.html http://forum.gsmhosting.com/vbb/10305305-post7466.html http://forum.gsmhosting.com/vbb/f641...-best-1812590/ |
