08-31-2015, 18:39 | #47 (permalink) | |
Major Poster Join Date: Jul 2006 Location: kenya
Member: 304037 Status: Offline Thanks Meter: 9 | Have same issue Quote:
in best main,not detect no flash,nothing. miracle 2 log Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 [ERROR] : DONE BB_CPU_SN : UNKNOW [ READ ERROR ] BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... Last edited by evansa; 08-31-2015 at 18:48. Reason: adding log from miracle 2 | |
08-31-2015, 19:19 | #50 (permalink) | |
Member: 304037 Status: Offline Thanks Meter: 9 | fresh log using NCK box with alcatel which is similar to this nokia give details Quote:
DA version: 5.1316.00.00 USER SELECTION : BOOT INFO. MODEL SELECTED : OT-2000X PHONE MUST BE OFF WITH BATTERY INSIDE. Connect phone in boot mode ... Com port ok : COM24 Phone detected...Please wait Download DA now...You can release power on CHANGE BAUDRATE SUCCES :S_DONE(0) DA download finished...Getting phone info BaseBand CPU: MT6250_S0001 BaseBand CPU Secure Version : 5 (Secure baseband) FLASH TYPE : NOR ID: NOR128Mb+64Mb) [MXIC] MX25U12835FZNI_10G size:0x01000000 INT RAM: 424Kb RAM: 64Mb SRAM BOOT STYLE :S_DONE(0) Get Fat ranges fail or not supported(minor error) OTP IMEI NOT EXIST Reading OTP Status, wait... OTP STATUS: OTP_UNLOCKED(3127) Reading Simlock Info, wait... Error code: 3152 maybe connection error with best or something???? coz it is not connecting with phone.help guyz. | |
07-02-2017, 09:39 | #52 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Card found: S/N : 7DBA7787 , v0136 Registered to: adelbb5 Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-969_ROM_eMP_10.03.11 VIVA : RM-969_VIVA_eMP_10.03.11 LANG : RM-969_LANG_PACK_ROM_IC_eMP_10.03.11 CUST : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_10.03.11 JMPT : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_10.03.11 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 14 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 38A84541C0F8228ABA3484B371AF87A8 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_10.03.11 SecureDecrypt : RM-969_VIVA_eMP_10.03.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IC_eMP_10.03.11 SecureDecrypt : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_10.03.11 SecureDecrypt : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_10.03.11 [ERROR] : [ERROR] : FT_FILE_NOT_EXIST OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_10.03.11 [ERROR] : DA_NOR_BLOCK_DATA_UNSTABLE Error While flash area!!! Flashing failed! Connect phone on selected interface... |
