07-30-2014, 09:01 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Nokia 220 flashing and format Done Code: Core : v1.92 , MTKx FlashEngine : v4.2 Verify files ... MAUI : RM-969_ROM_eMP_14.00.11 VIVA : RM-969_VIVA_eMP_14.00.11 LANG : RM-969_LANG_PACK_ROM_MH_eMP_14.00.11 CUST : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_14.00.11 JMPT : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_14.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Core : v1.92 , MTKx FlashEngine : v4.2 Verify files ... MAUI : RM-969_ROM_eMP_14.00.11 VIVA : RM-969_VIVA_eMP_14.00.11 LANG : RM-969_LANG_PACK_ROM_MH_eMP_14.00.11 CUST : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_14.00.11 JMPT : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_14.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 90 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 84350B14B6F987A4679164664EA04E72 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_14.00.11 SecureDecrypt : RM-969_VIVA_eMP_14.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_MH_eMP_14.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_14.00.11 SecureDecrypt : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_14.00.11 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_14.00.11 Write : RM-969_LANG_PACK_ROM_MH_eMP_14.00.11 Write : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_14.00.11 Write : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_14.00.11 Write : RM-969_VIVA_eMP_14.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_14.00.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_MH_eMP_14.00.11 [VERIFY] DONE : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_14.00.11 [VERIFY] DONE : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_14.00.11 [VERIFY] DONE : RM-969_VIVA_eMP_14.00.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:26 Reboot phone Ok Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 90 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 84350B14B6F987A4679164664EA04E72 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.14.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE |
The Following User Says Thank You to ishant For This Useful Post: |
08-03-2014, 09:05 | #2 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Peshawar Age: 35
Member: 2123463 Status: Offline Sonork: 100.1652545 Thanks Meter: 29 | i tried to format 220 but not detecting by infinity best i think drivers needed plz help me i need drivers |
The Following User Says Thank You to adduangel For This Useful Post: |
08-03-2014, 10:53 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Driver on support : MTK Serial Driver If you have problems with BEST 1.93 , use 1.92 for MTK. |
The Following User Says Thank You to Dzirt For This Useful Post: |
08-03-2014, 14:38 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. If someone have MTK problem on BEST 1.93 - and it work on 1.92 and have phone to test in near 3-5 hours - PM me to obtain new version. |
08-03-2014, 15:10 | #7 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: India
Member: 1728736 Status: Offline Sonork: 100.1615042 Thanks Meter: 1,098 | Quote:
I am A Best Lover And I am Also Face Problem With 1.93 Ver But When I Format It With A china Tool its Done So Please Fix The Bug If Any With 1.93 Ver Thank You | |
08-13-2014, 14:52 | #8 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Nokia 220 flashing read info and format done Connect phone on selected interface... IDM initializing, wait... Checking access to Products folder... Folder for RM-969 exist Prepare done, collect info [Query] : RM-969_auth_sv5_eMP.auth , 2.20 KB [Query] : RM-969_ROOTCERT_Signed_By_MTK_eMP_14.00.11 , 1.32 KB [Query] : RM-969_EXT_BOOTLOADER_eMP_14.00.11 , 89.79 KB [Query] : RM-969_SECURE_RO_ME_eMP_14.00.11 , 1.59 KB [Query] : RM-969_ROM_eMP_14.00.11 , 1.41 MB [Query] : RM-969_VIVA_eMP_14.00.11 , 4.01 MB [Query] : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 , 3.66 MB [Query] : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_14.00.11 , 151.26 KB [Query] : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_14.00.11 , 1.15 KB [Query] : RM-969_IMAGE_eMP_059V4M4_14.00.11.cfg , 2.78 KB [Query] : RM969_059V4M4_14.00.11_013.vpl , 6.06 KB Files to download : 11 Total size to download : 9.33 MB Downloading now, please, wait... [Skip,Exist] : RM-969_auth_sv5_eMP.auth [Skip,Exist] : RM-969_ROOTCERT_Signed_By_MTK_eMP_14.00.11 [Skip,Exist] : RM-969_EXT_BOOTLOADER_eMP_14.00.11 [Skip,Exist] : RM-969_SECURE_RO_ME_eMP_14.00.11 [Skip,Exist] : RM-969_ROM_eMP_14.00.11 [Skip,Exist] : RM-969_VIVA_eMP_14.00.11 [Skip,Exist] : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 [Skip,Exist] : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_14.00.11 [Skip,Exist] : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_14.00.11 [Download] : RM-969_IMAGE_eMP_059V4M4_14.00.11.cfg [Download] : RM969_059V4M4_14.00.11_013.vpl Verify files now ..... [Verify Ok] : RM-969_IMAGE_eMP_059V4M4_14.00.11.cfg [Verify Ok] : RM-969_ROOTCERT_Signed_By_MTK_eMP_14.00.11 [Verify Ok] : RM-969_EXT_BOOTLOADER_eMP_14.00.11 [Verify Ok] : RM-969_SECURE_RO_ME_eMP_14.00.11 [Verify Ok] : RM-969_ROM_eMP_14.00.11 [Verify Ok] : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 [Verify Ok] : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_14.00.11 [Verify Ok] : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_14.00.11 [Verify Ok] : RM-969_VIVA_eMP_14.00.11 [Verify Ok] : RM-969_auth_sv5_eMP.auth All done, all files were downloaded! Core : v1.91 , MTKx FlashEngine : v4.0 Verify files ... MAUI : RM-969_ROM_eMP_14.00.11 VIVA : RM-969_VIVA_eMP_14.00.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_14.00.11 JMPT : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_14.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 125 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 1E3221A49A63C0B83D334A688D5C64BA BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_14.00.11 SecureDecrypt : RM-969_VIVA_eMP_14.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_14.00.11 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_14.00.11 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_14.00.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 Write : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_14.00.11 Write : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_14.00.11 Write : RM-969_VIVA_eMP_14.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_14.00.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 [VERIFY] DONE : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_14.00.11 [VERIFY] DONE : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_14.00.11 [VERIFY] DONE : RM-969_VIVA_eMP_14.00.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:12 Reboot phone Ok Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 14.00.11 00-00-00 RM-969 IMEI 1 : 3530500xxxxxxxxx IMEI 2 : 3530500xxxxxxxxx XappVer : 00000776 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : Rivendell.14.00.11.p1 Product SN : 52ED5BEBH Product code : 059V2H4 Base Prd.code: 059T726 Module code : 0205836 Hardware info======= HWID : 1000 LCDVer: TPO Lock info =========== IMEI : 35305006xxxxxx IMEI spNet : 3A 35 50 00 86 77 81 12 Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Software Info: 14.00.11 00-00-00 RM-969 IMEI: 353050068xxxxxxx PPM version : IJ Product code: 059V2H4 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 125 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 1E3221A49A63C0B83D334A688D5C64BA BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.14.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Connect phone on selected interface... |
The Following User Says Thank You to >>PakFones<< For This Useful Post: |
08-18-2014, 13:54 | #9 (permalink) |
Freak Poster Join Date: Mar 2006 Location: INDIA ,PARADEEP
Member: 250050 Status: Offline Thanks Meter: 65 | BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE |
The Following User Says Thank You to chiku1245 For This Useful Post: |
