08-09-2014, 11:03 | #1 (permalink) |
Product Supporter Join Date: May 2010 Location: alwar, rajasthan (india)
Member: 1306196 Status: Offline Sonork: 100.1654602 Thanks Meter: 1,578 | nokia 220 hang on logo - perfect format solve info- registered to: vishnudatt Connect phone on selected interface... UFS S/N 80244 boot - Ok Connect phone on selected interface... Core : v1.94 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm769_007.200 PPM : rm769_007.20mg CNT : rm7690_nai07.20mg_nlt Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 00000020 FLASH DIE : 00008804 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm769_007.200 Image : hw_f3_rm769_r07.200.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00000000 , Len : 0x00020000 Erasing, wait ... Erase done Write , Start : 0x00000000 , Len : 0x00006000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00800000 , Len : 0x00400000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x003F0000 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00C5D000 , Len : 0x00203000 Erasing, wait ... Erase done Write , Start : 0x00C5D000 , Len : 0x0019E700 Flashing , wait ... Region flash done Check : 0C61 ===Flashing [PPM]=== File : rm769_007.20mg Image : hw_f3_rm769_007.20mg.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00100000 , Len : 0x00700000 Erasing, wait ... Erase done Write , Start : 0x00100000 , Len : 0x004FE180 Flashing , wait ... Region flash done Check : 570C ===Flashing [CNT]=== File : rm7690_nai07.20mg_nlt Image : hw_f3_rm7690_nai07.20mg_nlt.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00E60000 , Len : 0x00100000 Erasing, wait ... Erase done Write , Start : 0x00E60000 , Len : 0x000EA000 Flashing , wait ... Region flash done Check : AC36 Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Init service mode failed! Try powerup phone manually and connect Connect phone on selected interface... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 70 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 50BAABB1045E2B4C3A16BC2614976680 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE |
The Following User Says Thank You to vishnudatt For This Useful Post: |
09-02-2014, 07:15 | #2 (permalink) |
Freak Poster Join Date: Mar 2011 Location: kasur pakistan
Member: 1532868 Status: Offline Sonork: 100.1640331 Thanks Meter: 36 | 1st flash if not solve then try this problem solve 1000000% tested...... Last edited by Amir666; 09-02-2014 at 07:15. Reason: https://www.facebook.com/photo.php?fbid=827794517252099&set=a.238462512851972.63641.100000646758668&type=1&theater |
