10-21-2016, 16:33 | #1 (permalink) |
Freak Poster Join Date: Jun 2016 Location: gods own country
Member: 2587375 Status: Offline Sonork: 100.1673985 Thanks Meter: 74 | nokia 220 rm-969 dead after flash Connect phone on selected interface... Core : v2.23 , MTKx FlashEngine : v10.1 Verify files ... MAUI : RM-969_ROM_eMP_30.06.11 VIVA : RM-969_VIVA_eMP_30.06.11 LANG : RM-969_LANG_PACK_ROM_MF_eMP_30.06.11_001 CUST : RM-969_CUSTPACK_ROM_MF_INDIA_LK_eMP_30.06.11_001 JMPT : RM-969_JUMP_TABLE_MF_INDIA_LK_eMP_30.06.11_001 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 3145B10DE342AF623B45EFE69C4207FB BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_30.06.11 SecureDecrypt : RM-969_VIVA_eMP_30.06.11 SecureDecrypt : RM-969_LANG_PACK_ROM_MF_eMP_30.06.11_001 SecureDecrypt : RM-969_CUSTPACK_ROM_MF_INDIA_LK_eMP_30.06.11_001 SecureDecrypt : RM-969_JUMP_TABLE_MF_INDIA_LK_eMP_30.06.11_001 [ERROR] : [ERROR] : FT_FILE_NOT_EXIST OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) [ERROR] : DA_NOR_BLOCK_DATA_UNSTABLE Write : RM-969_ROM_eMP_30.06.11 [ERROR] : Error While flash area!!! Flashing failed! |
The Following User Says Thank You to sager 22 For This Useful Post: |
10-21-2016, 19:41 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Try flash repair maui with older BEST version, 2.01-2.03 or similar. Anyway, that almost can be hw problem. |
10-22-2016, 05:56 | #5 (permalink) | |
Member: 2587375 Status: Offline Sonork: 100.1673985 Thanks Meter: 74 | Quote:
try moui repair with ver 1.96 also error --- Insert USB cable now! --- Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 3145B10DE342AF623B45EFE69C4207FB BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 Boot Ok [ERROR] : DA_S_FLASH_INFO_NOT_EXIST [ERROR] : DA_CBR_NOT_FOUND Get settings... Erase region , wait ... Write region , wait ... [ERROR] : DA_NOR_BLOCK_DATA_UNSTABLE Write : RM-969_970_971_Rivendell_130011_REPAIR_MAUI_m62.lbl [ERROR] : [ERROR] : Error. Repair FAILED! Something goes wrong... Finishing session All done! | |
