01-31-2017, 12:51 | #1 (permalink) |
Freak Poster Join Date: Dec 2010 Location: philippine
Member: 1473466 Status: Offline Thanks Meter: 90 | Nokia 220 (rm969) dead after flash here is logs: --- Insert USB cable now! --- Wait for phone... Phone found! [ 332 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : A1A71420B11EB069ADF37290398C6198 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_20.14.11 SecureDecrypt : RM-969_VIVA_eMP_20.14.11 SecureDecrypt : RM-969_LANG_PACK_ROM_MH_eMP_20.14.11_001 SecureDecrypt : RM-969_CUSTPACK_ROM_MH_INDIA_IN_eMP_20.14.11_001 SecureDecrypt : RM-969_JUMP_TABLE_MH_INDIA_IN_eMP_20.14.11_001 [ERROR] : [ERROR] : DA_S_FLASH_INFO_NOT_EXIST SDS info wrong, seems as damaged. RPL backup impossible OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) [ERROR] : DA_NOR_BLOCK_DATA_UNSTABLE Write : RM-969_ROM_eMP_20.14.11 [ERROR] : Error While flash area!!! Flashing failed! anyone can help me especially infinity nokia best. |
07-29-2018, 15:42 | #2 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Heart of Asia
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | I have the same problem , any suggestion BEST TEAM ? Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Card found: S/N : A7FF7D84 , v0137 Registered to: aminrezaya Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-969_ROM_eMP_14.00.11 VIVA : RM-969_VIVA_eMP_14.00.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_14.00.11 JMPT : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_14.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 34 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : FD5AB77F06F49D8D321AC8827A2CF9B7 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.30.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_14.00.11 SecureDecrypt : RM-969_VIVA_eMP_14.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_14.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_14.00.11 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_14.00.11 OVRLP : 000069B900000001 PHPID : Rivendell.30.06.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_14.00.11 [ERROR] : DA_NOR_BLOCK_DATA_UNSTABLE Error While flash area!!! Flashing failed! Connect phone on selected interface... |
07-29-2018, 21:01 | #4 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | |
