04-22-2016, 13:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Classified
Member: 1280253 Status: Offline Thanks Meter: 142 | Nokia 220 RM970(MTK) Reset NCK Counter ??? can any tell me pls how to Reset NCK Counter for Nokia 220 RM970(MTK) there is option in the version 2.21 however there is no go ahead option pls advice /suggest br |
04-22-2016, 15:12 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. MediaTek tab - Reset Counter. It can be done during RPL write. How make counter reset : Make "Flash Read" with tick "RPL only". Select backup in Write RPL button in MediaTek tab, but before select need additional operations - like "counter reset", or "edit lifetimer". |
04-23-2016, 18:17 | #3 (permalink) | |
Member: 1280253 Status: Offline Thanks Meter: 142 | Quote:
thank you it worked !! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Software Info: 30.06.11 00-00-00 RM-970 IMEI: 356459063288979 PPM version : AE Product code: 059V9D5 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 247 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 0DE3DA77CBAEB531E908FB7AD8E77582 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.30.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Boot Ok Get settings... [INFO] : Encrypted RPL [RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL! Reset SimLock Counters Reset SimLock Counters Done! Security restored All done! Connect phone on selected interface... br | |
