06-07-2014, 12:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Nokia 220 Write flash done ,perfect solution ,infinity Best tool Nokia 220 Write flash successfull by Infinity best tool.Great work by great team. Code: Connect phone on selected interface... Core : v1.90 , MTKx FlashEngine : v3.5 Verify files ... MAUI : RM-969_ROM_eMP_10.03.11 VIVA : RM-969_VIVA_eMP_10.03.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.03.11 JMPT : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_10.03.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 24 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 00D59A921D94CE5473A0E9455E8042FB BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_10.03.11 SecureDecrypt : RM-969_VIVA_eMP_10.03.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.03.11 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_10.03.11 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 === Backup Enabled Reading RPL backup... IMEI : 353050067640548 RPL [Security] Saved to : 353050067640548_2nd.mtsec === Backup OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_10.03.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 Write : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.03.11 Write : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_10.03.11 Write : RM-969_VIVA_eMP_10.03.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_10.03.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 [VERIFY] DONE : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.03.11 [VERIFY] DONE : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_10.03.11 [VERIFY] DONE : RM-969_VIVA_eMP_10.03.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:17 Reboot phone Ok Connect phone on selected interface... Wbr ..:\\lucky//:.. |
The Following 5 Users Say Thank You to ..:\\lucky//:.. For This Useful Post: |
