12-20-2017, 08:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Nokia 222 ( RM-1136 ) Can't Register Sim / Sim Offline Problem So Please Help Me Can't Register Sim in Sim Setting Showing This Sim Offline So Please Help Me Infinity BEST Dongle Read RPL Only Report Here: Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : E2314E098BDC3B9D4EC39F38DC41FF35 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : ROME.20.05.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info IMEI : 357280080738344 BBUID : E2314E098BDC3B9D4EC39F38DC41FF35 PCCode: 059X2W3 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 357280080738344_MTKx_2nd.mtsec Read Done! Connect phone on selected interface... So Please Help Me. Thanks & Regards By: All TECH 4 You |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
12-22-2017, 05:25 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It not locked. Check sim card and other service provider. Make sure device not in blacklist. |
12-22-2017, 06:02 | #7 (permalink) | |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Quote:
& Remember I Was Check 4 Sim But Showing Can't Register Sim in Sim Setting Showing This Sim Offline Please Replay & Give Me Solution | |
12-26-2017, 08:02 | #11 (permalink) | |
Major Poster Join Date: Mar 2014
Member: 2154108 Status: Offline Sonork: 100.1622674 Thanks Meter: 5 | Quote:
Me too the same problem. If anyone have solution please reply here. | |
12-27-2017, 06:36 | #12 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Infinity BEST Dongle Product Manager & Supporter Please Help Me For Solve This Problem Thanks & Regards By: All TECH 4 You |
12-31-2017, 06:28 | #13 (permalink) |
01-02-2018, 18:15 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | You can try flash other sw version, for example. But not sure about it change much. By sw side, simlock and rpl it ok. There can be hw problem, like sim ways or near fault. |
01-02-2018, 18:50 | #15 (permalink) | |
This mobile Network well comung in Kuwait But After Come In INDIA this mobile Network is Not come so please solve my problem this mobile in not HW Problem Thanks & Regards By: All TRCH 4 You | |
