12-10-2015, 16:15 | #31 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Code: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 46E4CD50D8CFC6E17B3C497B26CF66A7 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.21.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA0_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info : IMEI : 356478069179842 BBUID : 46E4CD50D8CFC6E17B3C497B26CF66A7 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 356478069179842_MTKx.mtsec Read Done! Connect phone on selected interface... |
12-10-2015, 16:24 | #32 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | Repaired now... Phone was at my service shop before 5 months for flashing same as now and I found a RPL backup and wrote it now is OK everything 356478069179842_MTK.mtsec Thanks |
12-11-2015, 04:47 | #33 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Can you send me second RPL backup from this phone, when it was in CS state? Will analyse it and try find some way of repair without backup. Or all, which you have for this IMEI. There was one case, when phone gone to CS due FOTA fault , can repair such cases, if face few more. |
12-15-2015, 16:02 | #34 (permalink) |
Freak Poster Join Date: May 2007
Member: 511352 Status: Offline Thanks Meter: 6 | nokia 225 in CS state due to flash by miracle box-- --- Insert USB cable now! --- Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : FD03AFA292DC28541D42F9125C2F8785 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.10.01.11.p3 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA0_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Control Block Validation (Security Test) : Code 0x08 : CBR Info is wrong! CBR SN not match with BB SN! Say thanks to some "great chinese tools" for kill your phone If backup not done - phone just a brick ========== now i have not any backup==possible to recover--? |
12-15-2015, 17:00 | #35 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Read log again, there is all answered already : Code: Code 0x08 : CBR Info is wrong! CBR SN not match with BB SN! Say thanks to some "great chinese tools" for kill your phone If backup not done - phone just a brick |
06-08-2016, 07:14 | #41 (permalink) |
Major Poster Join Date: Dec 2015 Location: India
Member: 2503159 Status: Offline Thanks Meter: 14 | Card found: S/N : 03BE9B65 , v0130 Registered to: Krishna Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Software Info: 30.06.11 00-00-00 RM-1011 IMEI: 357147064979766 PPM version : MH Product code: 059V5S3 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : D528CAE213DE482875C773E25AF53D77 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.30.06.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA0_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info : IMEI : 357147064979766 BBUID : D528CAE213DE482875C773E25AF53D77 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 357147064979766_MTKx_2nd.mtsec Read Done! Connect phone on selected interface... |
06-08-2016, 10:59 | #42 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1102837 Status: Offline Thanks Meter: 2 | you said you have back up of your phone before flash to other firmware.. in bin file format.. now flash it by volcano box.. bin file firmware use your back up.. if you have volcano box.. your problem will answered.. |
06-09-2016, 13:59 | #43 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Please, go back to your village to cows. | |
10-30-2018, 08:04 | #45 (permalink) |
Junior Member Join Date: Nov 2015 Location: peshawar pakistan
Member: 2490747 Status: Offline Thanks Meter: 4 | Nokia 225 RM 1172 Contect service Nokia 225 Rm 1172 Contect service after Flash just flash this File many Time Tested firmware https://www.samsungconverts.com/2018...rvice-fix.html |
