Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-03-2014, 12:08   #1 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
Nokia 225 RM-1012 Help
Hello
I recieve this phone for unlocking it and get provider code try few time with Codes and get wrong now i wanna to know is there any way to Reset all counters because i mean that counter are blocked .... Phone are detected OK Info readed and i find option In Repair Tab Named RESTORE RPL "Reset Counter " but when i start process i ask me for some .mtsec files wich i cant see inside BEST Folder also if is Possible to make Option to send unlock code by USB will be nice .....
Screenshoot and logs are atached
Mario
File Type: txt 03_07_2014_12_log.txt (825 Bytes, 123 views)
Old 07-03-2014, 13:03   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello.
Select file from "BEST/Backup/" folder.
Select accord your imei.
If you select wrong - BEST will not allow you write it.
About code - not yet , but can try do that.
Old 07-03-2014, 13:08   #3 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
@dzirt
Originally Posted by Dzirt View Post
Hello.
Hello
Thanx for Quick answer If I can help somehow with Code sending with Infinty Contact me phone and code is in Hand
Just check I dont have Any file in folder what you say
Old 07-03-2014, 14:37   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Why you not check one folder deep?
\Backup\Cert\
I just give start point where backups saved.
About code - it take some time and will be , but later.
Old 11-29-2016, 12:38   #5 (permalink)
Member: 228717
Thanks Meter: 28
hi, i receive one nokia 225 rm-1012 for unlock , i made unlock by best and get the code but code are wrong i insert +7 and +1 . already flash new firmware and try to reset count with rpl but code always say "wrong code" ??? any help infinity best team please
Old 11-29-2016, 18:45   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
Show read info log.
Old 11-29-2016, 19:25   #7 (permalink)
Member: 228717
Thanks Meter: 28
Phone found!
MTKx Nokia Phone detected
Read info... Ok
Reading Phone Info....
Software ver : 30.06.11 00-00-00 RM-1012
IMEI 1 : 352395060465091
IMEI 2 : 123456789012345
XappVer : 000008B6
Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5
PPM : AE
CNT : PEARL.30.06.11.p2
Product SN : 1A40893AU
Product code : 059V9W5
Base Prd.code: 059V3Z0
Module code : 0206025
Hardware info=======
HWID : 3400
LCDVer: TPO
Lock info ===========
IMEI : 352395060465091
IMEI spNet : 3A 25 93 05 06 64 05 19
Lock info:
Block 1
L1:Close;
SimLock status : Ok
Security status : Ok
Done!
Unlock procedure started...
Using F-bus count...
Sending code 275601647972739 Level : 7 to SimLock Server...
Simlock Server Answer: Error
Done!
Old 11-29-2016, 19:39   #8 (permalink)
JayDi's Avatar
Member: 462970
For start - enter code in MTK tab.
Old 11-29-2016, 20:00   #9 (permalink)
Member: 228717
Thanks Meter: 28
already put and send to phone
Old 11-30-2016, 12:50   #10 (permalink)
Member: 67805
Thanks Meter: 364
Server work or not? I try to unlock one mtk nokia
Old 12-19-2016, 17:04   #11 (permalink)
Member: 228717
Thanks Meter: 28
the problem is wrong code ?
no solution ?
Old 12-20-2016, 19:18   #12 (permalink)
JayDi's Avatar
Member: 462970
no solution ?
Have you try input it by hands?
Old 12-20-2016, 21:05   #13 (permalink)
Member: 228717
Thanks Meter: 28
yes of course and not work...
today i solved by new method fast unlock (direct)
and works thanks
Old 12-21-2016, 08:45   #14 (permalink)
JayDi's Avatar
Member: 462970
and works thanks
Then you should ask for refund calculation, seems as there was some fault during it.
As reason of refund - that thread and my post.
Old 03-22-2017, 11:39   #15 (permalink)
Member: 626209
Thanks Meter: 42
Hello. I have the same problem as described by user neliocoelho in post #5 in this thread only that the phone is a Nokia 108 (RM-945) locked to Orange Romania. I received the code from BEST BF server, typed the code by hand twice (+1 & +7), sent the code by cable (+1 & +7), flashed the phone with product code of a simlock free version reset the counters and tried again but nothing always "code error". I am the very first person to have a Nokia 108 unlocked by BEST team ( note username in the first post here http://forum.gsmhosting.com/vbb/f641...108-a-1785632/ ) so I know for a fact that the solution is real so it's really weird that I can't unlock this unit. Here is log:
Phone found!
Read info... Ok
Software ver : 20.06.11 00-00-00 RM-945
IMEI 1 : 35172806*******
XappVer : 000008B6
PPM : AE
CNT : Bree.20.06.11.p4
Product SN : 162529FAU
Product code : 059V3Q8
Base Prd.code: 059S0R8
Module code : 0205623
HWID : 2051
LCDVer: TPO
IMEI : 35172806*******
IMEI spNet : 3A 15 27 08 ** ** ** **
Lock info:
Block 1
L1:Close;
SimLock status : Ok
Done!
Sending code 779292942094691 Level : 7 to SimLock Server...
Done!
Please advice. Thanks in advance.
Page generated in 0.24072 seconds with 9 queries
