07-03-2014, 12:08 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Right There ( Croatia )
Member: 38150 Status: Offline Sonork: 100.1611516 Thanks Meter: 143 | Nokia 225 RM-1012 Help I recieve this phone for unlocking it and get provider code try few time with Codes and get wrong now i wanna to know is there any way to Reset all counters because i mean that counter are blocked .... Phone are detected OK Info readed and i find option In Repair Tab Named RESTORE RPL "Reset Counter " but when i start process i ask me for some .mtsec files wich i cant see inside BEST Folder also if is Possible to make Option to send unlock code by USB will be nice ..... Screenshoot and logs are atached BR Mario |
07-03-2014, 13:03 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Select file from "BEST/Backup/" folder. Select accord your imei. If you select wrong - BEST will not allow you write it. About code - not yet , but can try do that. |
07-03-2014, 13:08 | #3 (permalink) | |
Member: 38150 Status: Offline Sonork: 100.1611516 Thanks Meter: 143 | @dzirt Quote:
Thanx for Quick answer If I can help somehow with Code sending with Infinty Contact me phone and code is in Hand Just check I dont have Any file in folder what you say | |
07-03-2014, 14:37 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Why you not check one folder deep? \Backup\Cert\ I just give start point where backups saved. About code - it take some time and will be , but later. |
11-29-2016, 12:38 | #5 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 228717 Status: Offline Thanks Meter: 28 | hi, i receive one nokia 225 rm-1012 for unlock , i made unlock by best and get the code but code are wrong i insert +7 and +1 . already flash new firmware and try to reset count with rpl but code always say "wrong code" ??? any help infinity best team please |
11-29-2016, 18:45 | #6 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Show read info log. | |
11-29-2016, 19:25 | #7 (permalink) |
Member: 228717 Status: Offline Thanks Meter: 28 | Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 30.06.11 00-00-00 RM-1012 IMEI 1 : 352395060465091 IMEI 2 : 123456789012345 XappVer : 000008B6 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : AE CNT : PEARL.30.06.11.p2 Product SN : 1A40893AU Product code : 059V9W5 Base Prd.code: 059V3Z0 Module code : 0206025 Hardware info======= HWID : 3400 LCDVer: TPO Lock info =========== IMEI : 352395060465091 IMEI spNet : 3A 25 93 05 06 64 05 19 Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! Unlock procedure started... Using F-bus count... Sending code 275601647972739 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! |
03-22-2017, 11:39 | #15 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 626209 Status: Offline Thanks Meter: 42 | Hello. I have the same problem as described by user neliocoelho in post #5 in this thread only that the phone is a Nokia 108 (RM-945) locked to Orange Romania. I received the code from BEST BF server, typed the code by hand twice (+1 & +7), sent the code by cable (+1 & +7), flashed the phone with product code of a simlock free version reset the counters and tried again but nothing always "code error". I am the very first person to have a Nokia 108 unlocked by BEST team ( note username in the first post here http://forum.gsmhosting.com/vbb/f641...108-a-1785632/ ) so I know for a fact that the solution is real so it's really weird that I can't unlock this unit. Here is log: Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 20.06.11 00-00-00 RM-945 IMEI 1 : 35172806******* IMEI 2 : 123456789012345 XappVer : 000008B6 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : AE CNT : Bree.20.06.11.p4 Product SN : 162529FAU Product code : 059V3Q8 Base Prd.code: 059S0R8 Module code : 0205623 Hardware info======= HWID : 2051 LCDVer: TPO Lock info =========== IMEI : 35172806******* IMEI spNet : 3A 15 27 08 ** ** ** ** Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! Unlock procedure started... Using F-bus count... Sending code 779292942094691 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! Please advice. Thanks in advance. |
