Member: 1214273
Thanks Meter: 136 | Here are logs : Quote:
Connect phone on selected interface...
Phone found!
MTKx Nokia Phone detected
Read info... Ok
Software Info: 10.01.11 00-00-00 RM-1012
IMEI: 3523950615xxxxx
PPM version : EA
Product code: 059W3J5
Rebooting phone to FlashMode...
Wait for phone...
Phone found! [ 65 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 63BC48382898FA0B0F1428BD398DB08F
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x000E
Project ID : PEARL.10.01.11.p2
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000
IMEI : 3523950615xxxxx
RPL [Security] Saved to : 3523950615xxxxx.mtsec
Read Done!
Phone found!
Read info... Ok
PPM version : EA
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Boot Ok
Get settings...
SDS OFF : 0x00FF4000
SDS LEN : 0x0000C000
[INFO] : Plain RPL
[RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL!
Reset counters enabled
Counter Fix Ok
Write : 3523950615xxxxx.mtsec
Encrypt Done, Now Re-connect power/cable!
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Boot Ok
Get settings...
Write : 3523950615xxxxx_enc.mtsec
Security restored
All done!
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Boot Ok
Get settings...
[INFO] : Plain RPL
[RPL VERIFY] : Code 0xFF : MOBILE_ID check failed, not found MOBILE_ID info in RPL!
Select correct file!
Error encrypt data! Bad Security backup!
Wait for phone...
Phone found! [ 65 ]
Sync...
Initial Register Read Failed (HW/Connection Error)
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Boot Ok
Get settings...
[INFO] : Plain RPL
Counter Fix Ok
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Boot Ok
Get settings...
Security restored
All done!
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Boot Ok
Get settings...
[INFO] : Plain RPL
Wait for phone...
Phone found! [ 65 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Boot Ok
Get settings...
Security restored
All done!
Connect phone on selected interface... | It's completely log from begining working with this phone and first phone that I do with Best |
