09-07-2017, 08:28 | #1 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Nokia 230 RM-1172 Contact Service Problem! At First I Just Added Only Farsi Languages From 13.00 to 14.00 After Phone Became Display Front Problem! Then I make Phone Full Flash With 14.00 Flash Done But Phone Showing Only Contact Service! Here is Flash Log: Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_DOHA_ROM_eMP_14.00.11 VIVA : RM-1172_DOHA_VIVA_eMP_14.00.11 LANG : RM-1172_DOHA_LANG_PACK_ROM_IC_eMP_14.00.11 CUST : RM-1172_DOHA_CUSTPACK_ROM_IC_eMP_14.00.11 JMPT : RM-1172_DOHA_JUMP_TABLE_IC_eMP_14.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 193 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CD0E27C8112C58A45510660965B72106 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.14.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_DOHA_ROM_eMP_14.00.11 SecureDecrypt : RM-1172_DOHA_VIVA_eMP_14.00.11 SecureDecrypt : RM-1172_DOHA_LANG_PACK_ROM_IC_eMP_14.00.11 SecureDecrypt : RM-1172_DOHA_CUSTPACK_ROM_IC_eMP_14.00.11 SecureDecrypt : RM-1172_DOHA_JUMP_TABLE_IC_eMP_14.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : DOHA.14.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_DOHA_ROM_eMP_14.00.11 Write : RM-1172_DOHA_LANG_PACK_ROM_IC_eMP_14.00.11 Write : RM-1172_DOHA_CUSTPACK_ROM_IC_eMP_14.00.11 Write : RM-1172_DOHA_JUMP_TABLE_IC_eMP_14.00.11 Write : RM-1172_DOHA_VIVA_eMP_14.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_DOHA_ROM_eMP_14.00.11 [VERIFY] DONE : RM-1172_DOHA_LANG_PACK_ROM_IC_eMP_14.00.11 [VERIFY] DONE : RM-1172_DOHA_CUSTPACK_ROM_IC_eMP_14.00.11 [VERIFY] DONE : RM-1172_DOHA_JUMP_TABLE_IC_eMP_14.00.11 [VERIFY] DONE : RM-1172_DOHA_VIVA_eMP_14.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:02:56 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_DOHA_ROM_eMP_14.00.11 VIVA : RM-1172_DOHA_VIVA_eMP_14.00.11 LANG : RM-1172_DOHA_LANG_PACK_ROM_IC_eMP_14.00.11 CUST : RM-1172_DOHA_CUSTPACK_ROM_IC_eMP_14.00.11 JMPT : RM-1172_DOHA_JUMP_TABLE_IC_eMP_14.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 193 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CD0E27C8112C58A45510660965B72106 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.14.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_DOHA_ROM_eMP_14.00.11 SecureDecrypt : RM-1172_DOHA_VIVA_eMP_14.00.11 SecureDecrypt : RM-1172_DOHA_LANG_PACK_ROM_IC_eMP_14.00.11 SecureDecrypt : RM-1172_DOHA_CUSTPACK_ROM_IC_eMP_14.00.11 SecureDecrypt : RM-1172_DOHA_JUMP_TABLE_IC_eMP_14.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : DOHA.14.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_DOHA_ROM_eMP_14.00.11 Write : RM-1172_DOHA_LANG_PACK_ROM_IC_eMP_14.00.11 Write : RM-1172_DOHA_CUSTPACK_ROM_IC_eMP_14.00.11 Write : RM-1172_DOHA_JUMP_TABLE_IC_eMP_14.00.11 Write : RM-1172_DOHA_VIVA_eMP_14.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_DOHA_ROM_eMP_14.00.11 [VERIFY] DONE : RM-1172_DOHA_LANG_PACK_ROM_IC_eMP_14.00.11 [VERIFY] DONE : RM-1172_DOHA_CUSTPACK_ROM_IC_eMP_14.00.11 [VERIFY] DONE : RM-1172_DOHA_JUMP_TABLE_IC_eMP_14.00.11 [VERIFY] DONE : RM-1172_DOHA_VIVA_eMP_14.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:02:55 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 193 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CD0E27C8112C58A45510660965B72106 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.14.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info IMEI : 356011082025609 BBUID : CD0E27C8112C58A45510660965B72106 PCCode: 059X5R6 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 356011082025609_MTKx.mtsec Read Done! Connect phone on selected interface... Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 193 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CD0E27C8112C58A45510660965B72106 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.14.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 Boot Ok Get settings... [INFO] : Encrypted RPL [RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL! Security restored All done! Connect phone on selected interface... Can You Tell Me, What did i Wrong?
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim |
09-07-2017, 09:10 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: I Love Walking In The Rain Bec
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | 1st read backup must with any china tool 2nd flash with new file 3rd again flash with backup file & chak bsi v |
09-07-2017, 09:15 | #3 (permalink) | |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
New File What? Another Region Firmware?
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | |
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post: |
09-07-2017, 13:00 | #4 (permalink) | |
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | Quote:
The Following 3 Users Say Thank You to FEATURE GSM™ For This Useful Post: |
09-07-2017, 13:51 | #5 (permalink) |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Problem Solved! I Followed This Thread and Fixed
