08-29-2013, 06:27 | #1 (permalink) |
Freak Poster Join Date: Feb 2012 Location: pakistan
Member: 1720342 Status: Offline Sonork: 100.1617223 Thanks Meter: 11 | nokia 2730 flashing problem Core : v1.68 , BB5XG FlashEngine : v5.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm578__10.47.mcusw PPM : rm578__10.47.ppm_m_a CNT : rm578__10.47.image_m_a_black Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101023000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0D500111BE40015697AC2B7E48FD904E33A8C570 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC109 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 000000000000000 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Init Service mode... Wait... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\12345610654321x.rp l Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101023000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0D500111BE40015697AC2B7E48FD904E33A8C570 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC109 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm578__10.47.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0155FFFF CMT , NOR , Area : 0x01560000 - 0x0175FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:58 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm578__10.47.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1394 blocks TIME : Write time : 00:03:22 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm578__10.47.ppm_m_a Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01760000 - 0x01FFFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:33 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm578__10.47.ppm_m_a Total writen 339 blocks TIME : Write time : 00:00:41 PrReq : NOR , 00 ConvertImage: Processing rm578__10.47.image_m_a_black ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm578__10.47.image_m_a_black Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x02000000 - 0x0245FFFF CMT , NOR , Area : 0x02460000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:03:18 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm578__10.47.image_m_a_black Total writen 768 blocks TIME : Write time : 00:01:50 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 2730 classic Software Info: V 10.47 27-08-10 RM-578 (c) Nokia IMEI: 12345610654321? Product code: 0591475 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 2730 classic Software ver : V 10.47 27-08-10 RM-578 (c) Nokia IMEI : 12345610654321? XappVer : 00000690 DSP Ver : ICPR72_10w01_Tommy PPM : V 10.47 27-08-10 RM-578 (c) Nokia M_A CNT : Content: m_a_black V 10.47 27-08-10 RM-578 (c) Nokia Product SN : 2C27B79AI Product code : 0591475 Base Prd.code: 0580665 Module code : 0204322 Long Prod.SN : 0 Hardware info======= HWID : 3003 Retu : 16 Tahvo : 22 Batery: 4646 mV CMT BT: 2.31-SP2.26 LCDVer: SEIKO RF ic : 17141716 Lock info =========== IMEI : 12345610654321? IMEI spNet : IMEI svNet : Unable to read Lock table... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! how to fix it or can i reback on its previous condition? |
08-30-2013, 13:14 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Problem in phone. Not in flashing. http://forum.gsmhosting.com/vbb/f641...rvice-1707354/ |
