09-05-2018, 08:42 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Nokia 3 hang on logo only it show like this Code: Operation : Write FW [ v1.04 ] Setting : UserData preserve : False Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v01.2018.0707 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
09-05-2018, 12:57 | #2 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | connect set in power off condition without hold any key on preloader port and untick BL update |
The Following User Says Thank You to kamal_singla For This Useful Post: |
09-06-2018, 05:09 | #3 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
Operation : Write FW [ v1.04 ] Setting : UserData preserve : False Setting : Bootloader update : False 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v01.2018.0707 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! | |
09-06-2018, 05:45 | #4 (permalink) |
Member: 2211790 Status: Offline Thanks Meter: 5,118 | still you connecting in BROM Port MediaTek USB Port (COM21) please connect it on preloader port disconnect battery reconnect it and connect usb cable or connect usb cable on phone and long hold power key when off release key |
09-07-2018, 07:31 | #5 (permalink) | |
so how to fix it ? pls help me. | |
09-07-2018, 08:55 | #6 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Do this and post result http://forum.gsmhosting.com/vbb/13225559-post22.html |
The Following User Says Thank You to princesaddam For This Useful Post: |
09-12-2018, 08:35 | #7 (permalink) | |
09-12-2018, 08:40 | #8 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2864674 Status: Offline Thanks Meter: 0 | my Nokia 6 is not open because I insert the charging electric fan so my cellphone wanted to power off so I insert again I was not open but its ringing and open but my screen is black if I hold the volume down and the power it's ringing because I'm trying to click the screenshot what will i do help me please???? |
09-12-2018, 13:04 | #9 (permalink) |
Insane Poster Join Date: Nov 2014 Location: bangladesh
Member: 2285601 Status: Offline Thanks Meter: 13 | Nokia 3 hang on logo only i try reflash wiht Best2 not work it show like this Code: Operation : Write FW [ v1.04 ] Setting : UserData preserve : False Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v01.2018.0707 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! ........................CM2 100% WORK.... |
09-13-2018, 10:57 | #10 (permalink) | |
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
