10-28-2014, 10:01 | #1 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 892974 Status: Offline Thanks Meter: 14 | Nokia 303 dead after trying to flash please advise.... i tried to flash this phone but it failed....now the phone is blinking white.... see log below.... card found: S/N xxxxxx registered to: xxxxxxxx Connect phone on selected interface... Core : v1.96 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm763__14.76.mcusw PPM : rm763__14.76.ppm_t CNT : rm763__14.76.image_t_059J1G8 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: E25E0000FFFB7C40230A2C248257657517112FDB ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : ACE39760399CD7A3FE439DCC52111C24D435D533 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 353672055087000 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353672055087000_CR T_2nd.rpl === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Elapsed: 00:00:12 Connect phone on selected interface... Last edited by lucstom; 10-28-2014 at 10:04. Reason: card information |
10-28-2014, 10:05 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello , seems as you flash lower version. Hope you made simlock backup or atleas read info first. Download latest FW for phone and flash. |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-28-2014, 12:19 | #3 (permalink) |
Member: 892974 Status: Offline Thanks Meter: 14 | after downloading latest firmware...flash it....ok....turn on phone it says contact service...see below Reading Phone Info.... Connected phone - Nokia 303 Software ver : V 14.87 17-10-12 RM-763 (c) Nokia IMEI : 353672055087000 XappVer : 000007A8 DSP Ver : 104_PM5_14.87 PPM : V 14.87 17-10-12 RM-763 (c) Nokia MH2 CNT : Content: mh2_059J1H6 V 14.87 17-10-12 RM-763 (c) Nokia Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 51 Tahvo : 00 Batery: 3557 mV CMT BT: 4217-v924 LCDVer: TPO Lock info =========== IMEI : 353672055087000 IMEI spNet : 3A 35 76 02 55 80 07 00 IMEI svNet : 33 35 76 02 55 80 07 10 F2 Unable to read Lock table... CRT308 Backup Created SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Damaged!!!!! Security status : Ok PA_SimLock Version : PA_SL phone detected User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
10-28-2014, 12:50 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | As I told already - if not made before any "Read Info" or Read RPL - there is no way. Latest BB5 TI phones, like this asha 303 and few same can die at any moment. And not matter - even if you use original tools ( like phoenix/care ) |
10-28-2014, 13:30 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | No, RPL can fix , but it very cost. Next time - always make Read Info before make any operation, like Read RPL even on those phones ( Asha 302, 303 , 300 ) |
10-29-2014, 09:03 | #8 (permalink) |
Member: 892974 Status: Offline Thanks Meter: 14 | tried today and its worst.... Connect phone on selected interface... Core : v1.96 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm763__14.87.mcusw PPM : rm763__14.87.ppm_mh2 CNT : rm763__14.87.image_mh2_059J1H6 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: E25E0000FFFB7C40230A2C248257657517112FDB ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : ACE39760399CD7A3FE439DCC52111C24D435D533 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 000000000000000 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\000000000000000_CR T_2nd.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm763__14.87.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm763__14.87.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 291 blocks TIME : Write time : 00:00:04 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm763__14.87.ppm_mh2 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm763__14.87.ppm_mh2 Total writen 61 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm763__14.87.image_mh2_059J1H6 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm763__14.87.image_mh2_059J1H6 Total writen 383 blocks TIME : Write time : 00:00:07 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:15 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 303 Software Info: V 14.87 17-10-12 RM-763 (c) Nokia IMEI: 12345610654321? PPM version : V 14.87 17-10-12 RM-763 (c) Nokia MH2 Product code: 059J1M0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Elapsed: 00:01:09 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 303 Software ver : V 14.87 17-10-12 RM-763 (c) Nokia IMEI : 12345610654321? XappVer : 000007A8 DSP Ver : 104_PM5_14.87 PPM : V 14.87 17-10-12 RM-763 (c) Nokia MH2 CNT : Content: mh2_059J1H6 V 14.87 17-10-12 RM-763 (c) Nokia Product SN : E345A0BAI Product code : 059J1M0 Base Prd.code: 059G7H1 Module code : 0205121 Long Prod.SN : 0 Hardware info======= HWID : 2000 Retu : 51 Tahvo : 00 Batery: 3451 mV CMT BT: 4217-v924 LCDVer: TPO Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 11 F2 Unable to read Lock table... IMEI DAMAGED!!! CRT308 save skipped... SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Damaged!!!!! PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Operating mode is OK, no need change... Field 2 Record 0 write - Ok Field 8 Record 0 write - Ok Record 3 write - Ok Record 4 write - Ok Record 8 write - Ok Field 11 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Field 12 Record 0 write - Ok Field 13 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Record 109 write - Ok Record 110 write - Ok Record 111 write - Ok Record 112 write - Ok Record 113 write - Ok Record 114 write - Ok Record 115 write - Ok Record 116 write - Ok Record 117 write - Ok Record 118 write - Ok Record 119 write - Ok Record 120 write - Ok Record 121 write - Ok Record 122 write - Ok Record 123 write - Ok Record 124 write - Ok Record 125 write - Ok Record 126 write - Ok Record 127 write - Ok Record 128 write - Ok Record 129 write - Ok Record 130 write - Ok Record 131 write - Ok Record 132 write - Ok Record 133 write - Ok Record 134 write - Ok Record 135 write - Ok Record 136 write - Ok Record 137 write - Ok Record 138 write - Ok Record 139 write - Ok Record 140 write - Ok Record 141 write - Ok Record 142 write - Ok Record 143 write - Ok Record 144 write - Ok Record 145 write - Ok Record 146 write - Ok Record 147 write - Ok Record 148 write - Ok Record 149 write - Ok Record 150 write - Ok Record 151 write - Ok Record 152 write - Ok Record 153 write - Ok Record 154 write - Ok Record 155 write - Ok Record 156 write - Ok Record 157 write - Ok Record 158 write - Ok Record 159 write - Ok Record 160 write - Ok Record 161 write - Ok Record 162 write - Ok Record 163 write - Ok Record 164 write - Ok Record 165 write - Ok Record 166 write - Ok Field 31 Record 4 write - Ok Field 42 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Field 50 Record 0 write - Ok Record 1 write - Ok Field 54 Record 0 write - Ok Field 96 Record 0 write - Ok Field 107 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 26 write - Ok Field 116 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Field 193 Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 9 write - Ok Field 218 Record 0 write - Ok Field 238 Record 1 write - Ok Field 296 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 301 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Field 308 Record 0 write - Error Record 1 write - Error Record 3 write - Error Record 4 write - Error Record 5 write - Error Record 6 write - Error Record 7 write - Error Record 8 write - Error Record 9 write - Error Field 322 Record 0 write - Ok Field 334 Record 0 write - Ok Field 339 Record 0 write - Ok Record 1 write - Ok Field 341 Record 0 write - Ok Field 354 Record 0 write - Ok Field 356 Record 0 write - Ok Field 369 Record 0 write - Ok Field 373 Record 0 write - Ok Done! Elapsed: 00:00:01 Reading Phone Info.... Connected phone - Nokia 303 Software ver : V 14.87 17-10-12 RM-763 (c) Nokia IMEI : 12345610654321? XappVer : 000007A8 DSP Ver : 104_PM5_14.87 PPM : V 14.87 17-10-12 RM-763 (c) Nokia MH2 CNT : Content: mh2_059J1H6 V 14.87 17-10-12 RM-763 (c) Nokia Product SN : E345A0BAI Product code : 059J1M0 Base Prd.code: 059G7H1 Module code : 0205121 Long Prod.SN : 0 Hardware info======= HWID : 2000 Retu : 51 Tahvo : 00 Batery: 3434 mV CMT BT: 4217-v924 LCDVer: TPO Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 11 F2 Unable to read Lock table... IMEI DAMAGED!!! CRT308 save skipped... SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Damaged!!!!! PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... |
