09-09-2015, 01:22 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Help: nokia lumia 800 dead after flash !!!! Connect phone on selected interface... Core : v2.09 , WP7x FlashEngine : v7.9 ==== Settings : Reset EFS : Disabled Secure Erase : Disabled ==== Flash Files selected : OSBL : RM801_12w22_prod_generic_nokia_osbl.esco AMSS : RM801_12w22_prod_generic_amss.esco ADSP : RM801_12w22_prod_generic_adsp.esco WP : RM801_12220_prod_689_01_boot.esco UDA : RM801_12w22_prod_generic_user_area_erase.esco Check files done, All files are Ok Dead Mode is Selected Waiting for USB device... --- Press and hold 'Volume Up' button and insert cable! --- Connection opened successfully Establish connection with device... Kick ... OSBL alive Init Ok OSBL info Prt : 1.1 Ver : 1.1.0.6 Bld : 12 Tms : 17.02.2012 / 12:40:05 ==== OSBL ==== Processing : RM801_12w22_prod_generic_nokia_osbl.esco nokia_osbl.mbn.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E nokia_osbl.mbn , len : 0x000EA228 , Type : Data Will flash 1 regions OSBL flashing done ==== AMSS ==== Processing : RM801_12w22_prod_generic_amss.esco amss.mbn.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E amss.mbn.enc , len : 0x00FF0690 , Type : Data Will flash 1 regions AMSS flashing done ==== ADSP ==== Processing : RM801_12w22_prod_generic_adsp.esco adsp.mbn.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E adsp.mbn.enc , len : 0x0055C2D0 , Type : Data Will flash 1 regions ADSP flashing done ==== WINDOWS PHONE ==== Processing : RM801_12220_prod_689_01_boot.esco boot.img.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E boot.img , len : 0x17BCC800 , Type : Data Will flash 25 regions Windows Phone flashing done ==== USER DEFINED AREA ==== Processing : RM801_12w22_prod_generic_user_area_erase.esco user_area_erase.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E UDA file detected, will erase defined region Using Normal Erase method UDA erase done UDA flashing done Flashing done! Flashing time : 00:03:25 Reboot device Ok Phone disconected! Connect phone on selected interface... and now when I try to flash phone I get this: card found: S/N 8ECB:0122 registered to: dragosgsm Connect phone on selected interface... Core : v2.09 , WP7x FlashEngine : v7.9 ==== Settings : Reset EFS : Disabled Secure Erase : Disabled ==== Flash Files selected : OSBL : RM801_12w22_prod_generic_nokia_osbl.esco AMSS : RM801_12w22_prod_generic_amss.esco ADSP : RM801_12w22_prod_generic_adsp.esco WP : RM801_12220_prod_490_01_boot.esco UDA : RM801_12w22_prod_generic_user_area_erase.esco Check files done, All files are Ok Dead Mode is Selected Waiting for USB device... --- Press and hold 'Volume Up' button and insert cable! --- Connection opened successfully Establish connection with device... Kick ... - > Error on Preparing stage, Check Cable/Battery Phone disconected! Connect phone on selected interface... Core : v2.09 , WP7x FlashEngine : v7.9 ==== Settings : Reset EFS : Enabled Secure Erase : Disabled ==== Flash Files selected : OSBL : RM801_12w22_prod_generic_nokia_osbl.esco AMSS : RM801_12w22_prod_generic_amss.esco ADSP : RM801_12w22_prod_generic_adsp.esco WP : RM801_12220_prod_490_01_boot.esco UDA : RM801_12w22_prod_generic_user_area_erase.esco Check files done, All files are Ok Dead Mode is Selected Waiting for USB device... --- Press and hold 'Volume Up' button and insert cable! --- Connection opened successfully Establish connection with device... Kick ... - > Error on Preparing stage, Check Cable/Battery Phone disconected! Connect phone on selected interface... |
09-10-2015, 10:43 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Then it mean something wrong in HW. If phone have normal, not damaged HW part - it never die during flashing. Check BSI line, try remove battery for 30 minutes, or use other one. If still same - then need solder. |
11-18-2015, 08:56 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | i have the same problem after unlock the phone not turn on , only boot several time, i tried to flash still boot, i checked the battery voltage it is 4.5 v., what might be the problem, the window is 7.5 |
