Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: Mexico
Member: 527046 Status: Online Thanks: 1,152
| nokia 303 problem with imei hi BEST Team, this phone was locked with user code, and it wasn't change into local mode with usb and wasn't with fbus cable too. the only way i found was flashing the handset with factory reset after flash, but now the phone is identified with imei damaged.here is read info log: Code: Reading Phone Info.... Connected phone - Nokia 303 Software ver : V 14.60 18-04-12 RM-763 (c) Nokia IMEI : 12345610654321? DSP Ver : 104_PM5_14.60 PPM : V 14.60 18-04-12 RM-763 (c) Nokia L1 CNT : Content: l1_059J1K7 V 14.60 18-04-12 RM-763 (c) Nokia Product SN : 641F97FAH Product code : 059L8K8 Base Prd.code: 059G7H1 Module code : 0205121 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 51 Tahvo : 00 Batery: 3864 mV CMT BT: 4217-v924 LCDVer: TPO Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 01 F9 Unable to read Lock table... :( IMEI DAMAGED!!! CRT308 save skipped... :( SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! but when i try to restore SL with Restore SL button it shows me the same, imei damaged but this time with 000000000000000. can i repair this phone? or i need to buy RPL? this is selftest: Code: Initializing Tests... IMEI : 12345610654321? , Phone : RM-763 Nokia 303 Get keys... PASSED | ST_USB_CHARGER_TEST PASSED | ST_TAHVOINT_TEST PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_BACKLIGHT_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_WLAN_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST ->ERROR | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_TOUCH_STUCK_TEST PASSED | ST_TOUCH_IF_TEST PASSED | ST_INTERNAL_ANTENNA_TEST PASSED | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_IIC_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_HEADSET_AMPLIFIER_TEST PASSED | ST_LED_CONTROLLER_TEST PASSED | ST_TOUCH_TEST PASSED | ST_RAM_IF_TEST NOT EXECUTED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_STROBE_TEST NOT EXECUTED | ST_CDSP_DIGI_RXTX_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT EXECUTED | ST_CDSP_PA_ID_PIN_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST SelfTests end |
| | #3 (permalink) | ||
| thanks for reply, now i have flashed with correct product code and RM type too, but the same with imei damaged. here's the flashing log: Quote:
and again thanks for reply. | ||
| | #4 (permalink) |
| Moderator ![]() Join Date: Dec 2006 Location: Pakistan " Karachi " and Dubai
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks: 208
| Hello Its not Possible Damage phone with out Erase or Wrong Flash . R u sure u was flash with Correct RM ? |
| | #5 (permalink) |
| yes, i'm sure. i flashed the phone with correct RM type, the strange is when i did read fullflash the imei showed was 000000000000000 and the phone freeze when i tried read rpl. :S maybe the phone was damaged before. i'll buy rpl thanks for reply |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Russia , Syberia Age: 23
Member: 1157320 Status: Offline Sonork: 100.1616907 Thanks: 4,098
| Before it phone was can power on? Strange at all, anyway. It can't die during flash with correct SW. |
| | #7 (permalink) |
| yes, the phone was power on with user code. and the only way to reset it was flashing with factory reset after flash. (beause the phone couldnt enter in local mode with fbus or usb) but after flashing and reset the info showed imei damaged. i think this phone was damaged before. but anyway i'll buy rpl. and thanks for your reply. |
| | #11 (permalink) |
| Backup tick during flash not harm phone. It should make backup. Press write rpl, on file selection press cancel. Connect powered off phone. if Best find backup - we can try repair phone. |
| The Following User Says Thank You to Dzirt For This Useful Post: |
| | #12 (permalink) | |
| Quote:
there's no rpl backupwhen i try restore SL with backup of full flash (with imei 00000000000000, not common 12345610654321x) Best show me imei damaged warning. i accept the next step and this is the info: Checking, wait ... Get phone info data from flash... - > IMEI damaged Continue search by user request Get secure data... ID_INFO : 13.44/04-11-11/RM-763 | |
| | #14 (permalink) | |
| right at least with correct imei not found. the first attemps to backup rpl before flash was with 000000000000 imei number, and inside rpl there's just CCC and HWC DATA. no more. Best and phone become freeze with this attemp of backup after flash the backup was 12345610654321x and inside rpl there's no NPC data: here is: Quote:
very strange | |
| | #15 (permalink) |
| Seems it was dead before |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
