09-19-2013, 17:16 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 53
Member: 91140 Status: Offline Thanks Meter: 12 | Nokia 306 flash problem Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 306 Software ver : V 03.63 14-06-12 RM-767 (c) Nokia IMEI : 351955********* XappVer : 000006AE PPM : V 03.63 14-06-12 RM-767 (c) Nokia C CNT : Content: c_059L8T8 V 03.63 14-06-12 RM-767 (c) Nokia Product SN : 412CF64BI Product code : 059Q275 Base Prd.code: 059G0N8 Module code : 0204887 Long Prod.SN : 0 Hardware info======= HWID : 2001 Batery: 3897 mV CMT BT: 19e2-4702D14 LCDVer: TPO Lock info =========== IMEI : 351955********* IMEI spNet : 3A 15 59 05 25 86 02 05 IMEI svNet : 33 15 59 05 25 86 02 15 F7 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 05ED934CFC8F3215 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core : v1.71 , BB5XG FlashEngine : v5.8 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm767__07.42.mcusw PPM : rm767__07.42.ppm_k CNT : rm767__07.42.image_k_059S429 Flashing phone now... Check files done... -> Check SW version... FlashFile version : 07.42 Phone version : 03.63 14-06-12 RM-767 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 351955********* PCcode : Jõ>’åM NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\351955*********_XG 213.rpl ===Flashing [MCU]=== File : rm767__07.42.mcusw Image : rm767__07.42.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x000C0000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x000C0000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40120000 , Len : 0x01C20000 Erasing, wait ... Erase done, time : 00:01:01 Write , Start : 0x40120000 , Len : 0x01C04000 Flashing , wait ... Region flash done, time : 00:00:44 Processing Region 5/5 Erase , Start : 0x43EE0000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm767__07.42.ppm_k Image : package_k.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41D40000 , Len : 0x00800000 Erasing, wait ... Erase done, time : 00:00:15 Write , Start : 0x41D40000 , Len : 0x005EAAA8 Flashing , wait ... Region flash done, time : 00:00:08 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:02:47 Connect phone on selected interface... Please help BEST Team! Thanks! |
