05-15-2015, 01:26 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Cuba-Holguin
Member: 256260 Status: Offline Thanks Meter: 726 | Nokia 308 dead after write PM file card found: S/N xxxxxxxxx registered to: xxxxxxx Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 308 Software ver : V 07.55 04-03-13 RM-852 (c) Nokia IMEI 1 : 353294051297564 IMEI 2 : 353294051297572 XappVer : 00000816 PPM : V 07.55 04-03-13 RM-852 (c) Nokia L CNT : Content: l_059N757 V 07.55 04-03-13 RM-838 (c) Nokia Product SN : 2A9ECC9BH Product code : 059N757 Base Prd.code: 059N194 Module code : 0205515 Long Prod.SN : 0 Hardware info======= HWID : 1402 Batery: 3870 mV CMT BT: 0101-0.1.7 LCDVer: TPO Lock info =========== IMEI : 353294051297564 IMEI spNet : 3A 35 92 04 15 92 57 06 IMEI svNet : 33 35 92 04 15 92 57 06 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading PM from field 0 to 400 Field [4] 10 Record(s) Record 1: 800 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 18: 80 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 26: 132 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 12 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Record 11: 4 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 241 byte(s) readed - Ok Field [13] 167 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 2 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 2 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 1 byte(s) readed - Ok Record 11: 48 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Record 13: 1 byte(s) readed - Ok Record 14: 1 byte(s) readed - Ok Record 15: 886 byte(s) readed - Ok Record 16: 2 byte(s) readed - Ok Record 17: 1 byte(s) readed - Ok Record 18: 1 byte(s) readed - Ok Record 19: 8 byte(s) readed - Ok Record 20: 1 byte(s) readed - Ok Record 21: 1 byte(s) readed - Ok Record 22: 1 byte(s) readed - Ok Record 23: 1 byte(s) readed - Ok Record 24: 1 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 1 byte(s) readed - Ok Record 27: 1 byte(s) readed - Ok Record 28: 1 byte(s) readed - Ok Record 29: 1 byte(s) readed - Ok Record 30: 1 byte(s) readed - Ok Record 31: 1 byte(s) readed - Ok Record 32: 1 byte(s) readed - Ok Record 33: 1 byte(s) readed - Ok Record 34: 1 byte(s) readed - Ok Record 35: 1 byte(s) readed - Ok Record 36: 1 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 38: 1 byte(s) readed - Ok Record 39: 1 byte(s) readed - Ok Record 40: 1 byte(s) readed - Ok Record 41: 1 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 4 byte(s) readed - Ok Record 44: 1 byte(s) readed - Ok Record 45: 4 byte(s) readed - Ok Record 46: 4 byte(s) readed - Ok Record 47: 1 byte(s) readed - Ok Record 48: 4 byte(s) readed - Ok Record 49: 1 byte(s) readed - Ok Record 50: 1 byte(s) readed - Ok Record 51: 1 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 4 byte(s) readed - Ok Record 54: 4 byte(s) readed - Ok Record 55: 1 byte(s) readed - Ok Record 56: 1 byte(s) readed - Ok Record 57: 1 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 1 byte(s) readed - Ok Record 60: 4 byte(s) readed - Ok Record 61: 4 byte(s) readed - Ok Record 62: 1 byte(s) readed - Ok Record 63: 4 byte(s) readed - Ok Record 64: 4 byte(s) readed - Ok Record 65: 1 byte(s) readed - Ok Record 66: 4 byte(s) readed - Ok Record 67: 4 byte(s) readed - Ok Record 68: 1 byte(s) readed - Ok Record 69: 1 byte(s) readed - Ok Record 70: 1 byte(s) readed - Ok Record 71: 4 byte(s) readed - Ok Record 72: 4 byte(s) readed - Ok Record 73: 1 byte(s) readed - Ok Record 74: 4 byte(s) readed - Ok Record 75: 2 byte(s) readed - Ok Record 76: 2 byte(s) readed - Ok Record 77: 2 byte(s) readed - Ok Record 78: 1 byte(s) readed - Ok Record 79: 1 byte(s) readed - Ok Record 80: 1 byte(s) readed - Ok Record 81: 1 byte(s) readed - Ok Record 82: 1 byte(s) readed - Ok Record 83: 2 byte(s) readed - Ok Record 84: 1 byte(s) readed - Ok Record 85: 4 byte(s) readed - Ok Record 86: 4 byte(s) readed - Ok Record 87: 2 byte(s) readed - Ok Record 88: 1 byte(s) readed - Ok Record 89: 4 byte(s) readed - Ok Record 90: 4 byte(s) readed - Ok Record 91: 2 byte(s) readed - Ok Record 92: 1 byte(s) readed - Ok Record 93: 4 byte(s) readed - Ok Record 94: 4 byte(s) readed - Ok Record 95: 2 byte(s) readed - Ok Record 96: 1 byte(s) readed - Ok Record 97: 4 byte(s) readed - Ok Record 98: 4 byte(s) readed - Ok Record 99: 2 byte(s) readed - Ok Record 100: 4 byte(s) readed - Ok Record 101: 2 byte(s) readed - Ok Record 102: 1 byte(s) readed - Ok Record 103: 4 byte(s) readed - Ok Record 104: 4 byte(s) readed - Ok Record 105: 4 byte(s) readed - Ok Record 106: 4 byte(s) readed - Ok Record 107: 4 byte(s) readed - Ok Record 108: 2 byte(s) readed - Ok Record 109: 4 byte(s) readed - Ok Record 110: 4 byte(s) readed - Ok Record 111: 4 byte(s) readed - Ok Record 112: 2 byte(s) readed - Ok Record 113: 4 byte(s) readed - Ok Record 114: 4 byte(s) readed - Ok Record 115: 1 byte(s) readed - Ok Record 116: 1 byte(s) readed - Ok Record 117: 1 byte(s) readed - Ok Record 118: 4 byte(s) readed - Ok Record 119: 4 byte(s) readed - Ok Record 120: 1 byte(s) readed - Ok Record 121: 1 byte(s) readed - Ok Record 122: 1 byte(s) readed - Ok Record 123: 8 byte(s) readed - Ok Record 124: 1 byte(s) readed - Ok Record 125: 1 byte(s) readed - Ok Record 126: 1 byte(s) readed - Ok Record 127: 1 byte(s) readed - Ok Record 128: 1 byte(s) readed - Ok Record 129: 4 byte(s) readed - Ok Record 130: 4 byte(s) readed - Ok Record 131: 1 byte(s) readed - Ok Record 132: 1 byte(s) readed - Ok Record 133: 2 byte(s) readed - Ok Record 134: 1 byte(s) readed - Ok Record 135: 2 byte(s) readed - Ok Record 136: 1 byte(s) readed - Ok Record 137: 1 byte(s) readed - Ok Record 138: 4 byte(s) readed - Ok Record 139: 4 byte(s) readed - Ok Record 140: 1 byte(s) readed - Ok Record 141: 1 byte(s) readed - Ok Record 142: 1 byte(s) readed - Ok Record 143: 1 byte(s) readed - Ok Record 144: 4 byte(s) readed - Ok Record 145: 8 byte(s) readed - Ok Record 146: 4 byte(s) readed - Ok Record 147: 4 byte(s) readed - Ok Record 148: 1 byte(s) readed - Ok Record 149: 1 byte(s) readed - Ok Record 150: 1 byte(s) readed - Ok Record 151: 1 byte(s) readed - Ok Record 152: 1 byte(s) readed - Ok Record 153: 1 byte(s) readed - Ok Record 154: 1 byte(s) readed - Ok Record 155: 1 byte(s) readed - Ok Record 156: 1 byte(s) readed - Ok Record 157: 1 byte(s) readed - Ok Record 158: 1 byte(s) readed - Ok Record 159: 2 byte(s) readed - Ok Record 160: 2 byte(s) readed - Ok Record 161: 1 byte(s) readed - Ok Record 162: 1 byte(s) readed - Ok Record 163: 1 byte(s) readed - Ok Record 164: 1 byte(s) readed - Ok Record 165: 1 byte(s) readed - Ok Record 166: 1 byte(s) readed - Ok Field [42] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [49] 2 Record(s) Record 1: 4 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 3 Record(s) Record 0: 88 byte(s) readed - Ok Record 1: 24 byte(s) readed - Ok Record 3: 6 byte(s) readed - Ok Field [111] 1 Record(s) Record 1: 4 byte(s) readed - Ok Field [116] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [117] 4 Record(s) Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 24: 10 byte(s) readed - Ok Record 25: 8 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 134 byte(s) readed - Ok Record 3: 147 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [163] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [202] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [218] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [238] 1 Record(s) Record 1: 1 byte(s) readed - Ok Field [239] 5 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 13107 byte(s) readed - Ok Record 2: 13107 byte(s) readed - Ok Record 3: 13107 byte(s) readed - Ok Record 4: 13107 byte(s) readed - Ok Field [296] 3 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [301] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [308] 9 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [339] 2 Record(s) Record 0: 511 byte(s) readed - Ok Record 1: 511 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 5: 4 byte(s) readed - Ok Record 6: 2380 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 21 byte(s) readed - Ok Field [355] 1 Record(s) Record 0: 17746 byte(s) readed - Ok Field [356] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [364] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [365] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [374] 1 Record(s) Record 0: 4 byte(s) readed - Ok Field [383] 50 Record(s) Record 1: 40 byte(s) readed - Ok Record 2: 512 byte(s) readed - Ok Record 3: 512 byte(s) readed - Ok Record 4: 144 byte(s) readed - Ok Record 5: 49 byte(s) readed - Ok Record 6: 512 byte(s) readed - Ok Record 7: 512 byte(s) readed - Ok Record 8: 512 byte(s) readed - Ok Record 9: 512 byte(s) readed - Ok Record 10: 512 byte(s) readed - Ok Record 11: 512 byte(s) readed - Ok Record 12: 512 byte(s) readed - Ok Record 13: 512 byte(s) readed - Ok Record 14: 512 byte(s) readed - Ok Record 15: 512 byte(s) readed - Ok Record 16: 512 byte(s) readed - Ok Record 17: 512 byte(s) readed - Ok Record 18: 512 byte(s) readed - Ok Record 19: 512 byte(s) readed - Ok Record 20: 512 byte(s) readed - Ok Record 21: 512 byte(s) readed - Ok Record 22: 512 byte(s) readed - Ok Record 23: 512 byte(s) readed - Ok Record 24: 512 byte(s) readed - Ok Record 25: 512 byte(s) readed - Ok Record 26: 512 byte(s) readed - Ok Record 27: 512 byte(s) readed - Ok Record 28: 512 byte(s) readed - Ok Record 29: 512 byte(s) readed - Ok Record 30: 512 byte(s) readed - Ok Record 31: 512 byte(s) readed - Ok Record 32: 512 byte(s) readed - Ok Record 33: 512 byte(s) readed - Ok Record 34: 194 byte(s) readed - Ok Record 35: 56 byte(s) readed - Ok Record 36: 126 byte(s) readed - Ok Record 37: 512 byte(s) readed - Ok Record 38: 512 byte(s) readed - Ok Record 39: 512 byte(s) readed - Ok Record 40: 512 byte(s) readed - Ok Record 41: 512 byte(s) readed - Ok Record 42: 76 byte(s) readed - Ok Record 43: 125 byte(s) readed - Ok Record 44: 164 byte(s) readed - Ok Record 45: 512 byte(s) readed - Ok Record 46: 445 byte(s) readed - Ok Record 47: 124 byte(s) readed - Ok Record 48: 493 byte(s) readed - Ok Record 49: 252 byte(s) readed - Ok Record 50: 512 byte(s) readed - Ok Field [390] 204 Record(s) Record 0: 40 byte(s) readed - Ok Record 1: 53 byte(s) readed - Ok Record 2: 512 byte(s) readed - Ok Record 3: 512 byte(s) readed - Ok Record 4: 512 byte(s) readed - Ok Record 5: 512 byte(s) readed - Ok Record 6: 512 byte(s) readed - Ok Record 7: 512 byte(s) readed - Ok Record 8: 512 byte(s) readed - Ok Record 9: 512 byte(s) readed - Ok Record 10: 512 byte(s) readed - Ok Record 11: 512 byte(s) readed - Ok Record 12: 512 byte(s) readed - Ok Record 13: 512 byte(s) readed - Ok Record 14: 512 byte(s) readed - Ok Record 15: 512 byte(s) readed - Ok Record 16: 512 byte(s) readed - Ok Record 17: 512 byte(s) readed - Ok Record 18: 304 byte(s) readed - Ok Record 19: 512 byte(s) readed - Ok Record 20: 160 byte(s) readed - Ok Record 21: 512 byte(s) readed - Ok Record 22: 512 byte(s) readed - Ok Record 23: 512 byte(s) readed - Ok Record 24: 512 byte(s) readed - Ok Record 25: 512 byte(s) readed - Ok Record 26: 512 byte(s) readed - Ok Record 27: 512 byte(s) readed - Ok Record 28: 512 byte(s) readed - Ok Record 29: 512 byte(s) readed - Ok Record 30: 512 byte(s) readed - Ok Record 31: 512 byte(s) readed - Ok Record 32: 512 byte(s) readed - Ok Record 33: 512 byte(s) readed - Ok Record 34: 512 byte(s) readed - Ok Record 35: 512 byte(s) readed - Ok Record 36: 512 byte(s) readed - Ok Record 37: 512 byte(s) readed - Ok Record 38: 512 byte(s) readed - Ok Record 39: 512 byte(s) readed - Ok Record 40: 512 byte(s) readed - Ok Record 41: 512 byte(s) readed - Ok Record 42: 56 byte(s) readed - Ok Record 43: 512 byte(s) readed - Ok Record 44: 512 byte(s) readed - Ok Record 45: 256 byte(s) readed - Ok Record 46: 512 byte(s) readed - Ok Record 47: 512 byte(s) readed - Ok Record 48: 512 byte(s) readed - Ok Record 49: 312 byte(s) readed - Ok Record 50: 512 byte(s) readed - Ok Record 51: 512 byte(s) readed - Ok Record 52: 50 byte(s) readed - Ok Record 53: 148 byte(s) readed - Ok Record 54: 512 byte(s) readed - Ok Record 55: 512 byte(s) readed - Ok Record 56: 50 byte(s) readed - Ok Record 57: 512 byte(s) readed - Ok Record 58: 512 byte(s) readed - Ok Record 59: 512 byte(s) readed - Ok Record 60: 512 byte(s) readed - Ok Record 61: 332 byte(s) readed - Ok Record 62: 512 byte(s) readed - Ok Record 63: 512 byte(s) readed - Ok Record 64: 512 byte(s) readed - Ok Record 65: 512 byte(s) readed - Ok Record 66: 512 byte(s) readed - Ok Record 67: 512 byte(s) readed - Ok Record 68: 512 byte(s) readed - Ok Record 69: 128 byte(s) readed - Ok Record 70: 512 byte(s) readed - Ok Record 71: 512 byte(s) readed - Ok Record 72: 128 byte(s) readed - Ok Record 73: 512 byte(s) readed - Ok Record 74: 512 byte(s) readed - Ok Record 75: 512 byte(s) readed - Ok Record 76: 512 byte(s) readed - Ok Record 77: 512 byte(s) readed - Ok Record 78: 264 byte(s) readed - Ok Record 79: 512 byte(s) readed - Ok Record 80: 512 byte(s) readed - Ok Record 81: 512 byte(s) readed - Ok Record 82: 512 byte(s) readed - Ok Record 83: 512 byte(s) readed - Ok Record 84: 512 byte(s) readed - Ok Record 85: 512 byte(s) readed - Ok Record 86: 512 byte(s) readed - Ok Record 87: 512 byte(s) readed - Ok Record 88: 512 byte(s) readed - Ok Record 89: 512 byte(s) readed - Ok Record 90: 512 byte(s) readed - Ok Record 91: 512 byte(s) readed - Ok Record 92: 512 byte(s) readed - Ok Record 93: 512 byte(s) readed - Ok Record 94: 512 byte(s) readed - Ok Record 95: 512 byte(s) readed - Ok Record 96: 512 byte(s) readed - Ok Record 97: 288 byte(s) readed - Ok Record 98: 512 byte(s) readed - Ok Record 99: 80 byte(s) readed - Ok Record 100: 512 byte(s) readed - Ok Record 101: 512 byte(s) readed - Ok Record 102: 512 byte(s) readed - Ok Record 103: 512 byte(s) readed - Ok Record 104: 512 byte(s) readed - Ok Record 105: 512 byte(s) readed - Ok Record 106: 512 byte(s) readed - Ok Record 107: 512 byte(s) readed - Ok Record 108: 512 byte(s) readed - Ok Record 109: 512 byte(s) readed - Ok Record 110: 512 byte(s) readed - Ok Record 111: 512 byte(s) readed - Ok Record 112: 512 byte(s) readed - Ok Record 113: 512 byte(s) readed - Ok Record 114: 512 byte(s) readed - Ok Record 115: 512 byte(s) readed - Ok Record 116: 512 byte(s) readed - Ok Record 117: 512 byte(s) readed - Ok Record 118: 512 byte(s) readed - Ok Record 119: 112 byte(s) readed - Ok Record 120: 512 byte(s) readed - Ok Record 121: 288 byte(s) readed - Ok Record 122: 512 byte(s) readed - Ok Record 124: 512 byte(s) readed - Ok Record 125: 512 byte(s) readed - Ok Record 126: 512 byte(s) readed - Ok Record 127: 512 byte(s) readed - Ok Record 128: 512 byte(s) readed - Ok Record 129: 512 byte(s) readed - Ok Record 131: 512 byte(s) readed - Ok Record 132: 512 byte(s) readed - Ok Record 133: 512 byte(s) readed - Ok Record 134: 264 byte(s) readed - Ok Record 135: 512 byte(s) readed - Ok Record 136: 512 byte(s) readed - Ok Record 137: 512 byte(s) readed - Ok Record 138: 512 byte(s) readed - Ok Record 139: 512 byte(s) readed - Ok Record 140: 512 byte(s) readed - Ok Record 141: 512 byte(s) readed - Ok Record 142: 512 byte(s) readed - Ok Record 143: 512 byte(s) readed - Ok Record 144: 512 byte(s) readed - Ok Record 145: 512 byte(s) readed - Ok Record 146: 512 byte(s) readed - Ok Record 147: 512 byte(s) readed - Ok Record 148: 512 byte(s) readed - Ok Record 149: 512 byte(s) readed - Ok Record 150: 512 byte(s) readed - Ok Record 151: 512 byte(s) readed - Ok Record 152: 512 byte(s) readed - Ok Record 153: 512 byte(s) readed - Ok Record 154: 512 byte(s) readed - Ok Record 155: 512 byte(s) readed - Ok Record 156: 512 byte(s) readed - Ok Record 157: 512 byte(s) readed - Ok Record 158: 512 byte(s) readed - Ok Record 159: 512 byte(s) readed - Ok Record 160: 512 byte(s) readed - Ok Record 161: 512 byte(s) readed - Ok Record 162: 512 byte(s) readed - Ok Record 163: 512 byte(s) readed - Ok Record 164: 512 byte(s) readed - Ok Record 165: 512 byte(s) readed - Ok Record 166: 512 byte(s) readed - Ok Record 167: 512 byte(s) readed - Ok Record 168: 512 byte(s) readed - Ok Record 169: 512 byte(s) readed - Ok Record 170: 512 byte(s) readed - Ok Record 171: 512 byte(s) readed - Ok Record 172: 512 byte(s) readed - Ok Record 173: 512 byte(s) readed - Ok Record 174: 512 byte(s) readed - Ok Record 175: 184 byte(s) readed - Ok Record 176: 512 byte(s) readed - Ok Record 177: 512 byte(s) readed - Ok Record 178: 512 byte(s) readed - Ok Record 179: 512 byte(s) readed - Ok Record 180: 512 byte(s) readed - Ok Record 182: 512 byte(s) readed - Ok Record 184: 512 byte(s) readed - Ok Record 185: 512 byte(s) readed - Ok Record 186: 512 byte(s) readed - Ok Record 187: 512 byte(s) readed - Ok Record 188: 132 byte(s) readed - Ok Record 204: 512 byte(s) readed - Ok Record 205: 512 byte(s) readed - Ok Record 206: 512 byte(s) readed - Ok Record 207: 512 byte(s) readed - Ok Record 208: 512 byte(s) readed - Ok Record 209: 512 byte(s) readed - Ok Record 210: 512 byte(s) readed - Ok Record 211: 512 byte(s) readed - Ok Record 212: 512 byte(s) readed - Ok Record 213: 512 byte(s) readed - Ok Record 214: 512 byte(s) readed - Ok Record 215: 512 byte(s) readed - Ok Record 216: 512 byte(s) readed - Ok Record 217: 512 byte(s) readed - Ok Record 218: 512 byte(s) readed - Ok Record 219: 512 byte(s) readed - Ok Record 220: 512 byte(s) readed - Ok Record 221: 512 byte(s) readed - Ok Record 222: 448 byte(s) readed - Ok Field [391] 31 Record(s) Record 0: 40 byte(s) readed - Ok Record 1: 69 byte(s) readed - Ok Record 2: 124 byte(s) readed - Ok Record 3: 96 byte(s) readed - Ok Record 4: 64 byte(s) readed - Ok Record 5: 64 byte(s) readed - Ok Record 6: 68 byte(s) readed - Ok Record 7: 64 byte(s) readed - Ok Record 8: 64 byte(s) readed - Ok Record 9: 68 byte(s) readed - Ok Record 10: 64 byte(s) readed - Ok Record 11: 512 byte(s) readed - Ok Record 12: 430 byte(s) readed - Ok Record 13: 512 byte(s) readed - Ok Record 14: 512 byte(s) readed - Ok Record 15: 512 byte(s) readed - Ok Record 16: 512 byte(s) readed - Ok Record 17: 512 byte(s) readed - Ok Record 19: 512 byte(s) readed - Ok Record 20: 512 byte(s) readed - Ok Record 21: 512 byte(s) readed - Ok Record 22: 512 byte(s) readed - Ok Record 23: 512 byte(s) readed - Ok Record 25: 512 byte(s) readed - Ok Record 26: 512 byte(s) readed - Ok Record 27: 512 byte(s) readed - Ok Record 28: 512 byte(s) readed - Ok Record 29: 512 byte(s) readed - Ok Record 30: 421 byte(s) readed - Ok Record 31: 512 byte(s) readed - Ok Record 32: 512 byte(s) readed - Ok Field [398] 1 Record(s) Record 0: 2 byte(s) readed - Ok Saved as C:\Archivos de programa\BEST\Backup\RM-852 Nokia 308_353294051297564_0_400.pm Done! Elapsed: 00:00:01 Backup Certificates now... Reboot.... Detected XGOLD 223 platform , switching ASIC ID_F : 00000C201610004049922028891850F014EC0F00 ASIC ID_E : 00000C2016100040 PUBLIC ID : 0000000000000000000000000000000000000000 XGCHIP ID : 0000000000000000 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 353294051297564 IMEI [2] : 353294051297572 Reboot phone to service mode... CRT308 Backup Created SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\Archivos de programa\BEST\Backup\Cert\353294051297564_XG223.rp l Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Backup CRT308 data... CRT308 Backup Created SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Reboot.... File [Ok] : rm838__08.13.mcusw File [Ok] : rm838__08.13.ppm_c File [Ok] : rm838__08.13.image_c_059N7N3 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049922028891850F014EC0F00 ASIC ID_E : 00000C2016100040 PUBLIC ID : 0000000000000000000000000000000000000000 XGCHIP ID : 0000000000000000 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 353294051297564 IMEI [2] : 353294051297572 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\Archivos de programa\BEST\Backup\Cert\353294051297564_2nd_XG22 3.rpl PAPUBkeys : FAF910DA218D8536CEFBDCE369A8C034160C6A5F === SW Version Check === - > UPGRADE === SW Version Check === === Flashing MCU === Processing file : rm838__08.13.mcusw Erasing... Writing... Total blocks : 90 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : FAF910DA218D8536CEFBDCE369A8C034160C6A5F] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 89 blocks were writen === Flashing PPM === Processing file : rm838__08.13.ppm_c Erasing... Writing... Total blocks : 15 File processed Ok, 15 blocks were writen === Flashing CNT === Processing file : rm838__08.13.image_c_059N7N3 Erasing... Writing... Total blocks : 105 File processed Ok, 105 blocks were writen Flashing done , total time : 00:01:06 Reboot phone to service mode... Reading Phone Info.... Connected phone - Nokia 308 Software Info: V 08.13 21-05-13 RM-852 (c) Nokia IMEI: 353294051297564 PPM version : V 08.13 21-05-13 RM-852 (c) Nokia C Product code: 059N757 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 308 Software ver : V 08.13 21-05-13 RM-852 (c) Nokia IMEI 1 : 353294051297564 IMEI 2 : 353294051297572 XappVer : 00000816 PPM : V 08.13 21-05-13 RM-852 (c) Nokia C CNT : Content: c_059N7N3 V 08.13 21-05-13 RM-838 (c) Nokia Product SN : 2A9ECC9BH Product code : 059N757 Base Prd.code: 059N194 Module code : 0205515 Long Prod.SN : 0 Hardware info======= HWID : 1402 Batery: 3770 mV CMT BT: 0101-0.1.7 LCDVer: TPO Lock info =========== IMEI : 353294051297564 IMEI spNet : 3A 35 92 04 15 92 57 06 IMEI svNet : 33 35 92 04 15 92 57 16 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Checking Camera Configuration... Operating mode is OK, no need change... CAM1 HW : 0A350160 CAM1 SW ver : 004012 Updating Camera #1 Configuration... Upload done, checking... CAM1 SW ver : 005005 Configuration Ok! Secondary Camera #2 configuration info not exist Done! Operating mode is OK, no need change... Field 4 Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 9 write - Ok Record 18 write - Ok Record 19 write - Ok Record 26 write - Ok Field 8 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Field 11 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Field 13 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Record 109 write - Ok Record 110 write - Ok Record 111 write - Ok Record 112 write - Ok Record 113 write - Ok Record 114 write - Ok Record 115 write - Ok Record 116 write - Ok Record 117 write - Ok Record 118 write - Ok Record 119 write - Ok Record 120 write - Ok Record 121 write - Ok Record 122 write - Ok Record 123 write - Ok Record 124 write - Ok Record 125 write - Ok Record 126 write - Ok Record 127 write - Ok Record 128 write - Ok Record 129 write - Ok Record 130 write - Ok Record 131 write - Ok Record 132 write - Ok Record 133 write - Ok Record 134 write - Ok Record 135 write - Ok Record 136 write - Ok Record 137 write - Ok Record 138 write - Ok Record 139 write - Ok Record 140 write - Ok Record 141 write - Ok Record 142 write - Ok Record 143 write - Ok Record 144 write - Ok Record 145 write - Ok Record 146 write - Ok Record 147 write - Ok Record 148 write - Ok Record 149 write - Ok Record 150 write - Ok Record 151 write - Ok Record 152 write - Ok Record 153 write - Ok Record 154 write - Ok Record 155 write - Ok Record 156 write - Ok Record 157 write - Ok Record 158 write - Ok Record 159 write - Ok Record 160 write - Ok Record 161 write - Ok Record 162 write - Ok Record 163 write - Ok Record 164 write - Ok Record 165 write - Ok Record 166 write - Ok Field 42 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Field 54 Record 0 write - Ok Field 96 Record 0 write - Ok Record 1 write - Ok Field 107 Record 1 write - Ok Record 3 write - Ok Field 116 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Field 153 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Field 193 Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 9 write - Ok Field 217 Record 0 write - Ok Field 218 Record 0 write - Ok Field 238 Record 1 write - Ok Field 239 Record 0 write - Ok Record 1 write - Ok Field 296 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 301 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Field 313 Record 0 write - Ok Field 322 Record 0 write - Ok Field 339 Record 0 write - Ok Record 1 write - Ok Field 341 Record 0 write - Ok Record 5 write - Ok Record 6 write - Ok Field 354 Record 0 write - Ok Field 355 Record 0 write - Ok Field 356 Record 0 write - Ok Field 364 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Field 365 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Field 372 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Field 373 Record 0 write - Ok Field 383 Record 1 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Field 390 Record 0 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Record 109 write - Ok Record 110 write - Ok Record 111 write - Ok Record 112 write - Ok Record 113 write - Ok Record 114 write - Ok Record 115 write - Ok Record 116 write - Ok Record 117 write - Ok Record 118 write - Ok Record 119 write - Ok Record 120 write - Ok Record 121 write - Ok Record 122 write - Ok Record 123 write - Ok Record 124 write - Ok Record 125 write - Ok Record 126 write - Ok Record 127 write - Ok Record 128 write - Ok Record 129 write - Ok Record 130 write - Ok Record 131 write - Ok Record 132 write - Ok Record 133 write - Ok Record 134 write - Ok Record 135 write - Ok Record 136 write - Ok Record 137 write - Ok Record 138 write - Ok Record 139 write - Ok Record 140 write - Ok Record 141 write - Ok Record 142 write - Ok Record 143 write - Ok Record 144 write - Ok Record 145 write - Ok Record 146 write - Ok Record 147 write - Ok Record 148 write - Ok Record 149 write - Ok Record 150 write - Ok Record 151 write - Ok Record 152 write - Ok Record 153 write - Ok Record 154 write - Ok Record 155 write - Ok Record 156 write - Ok Record 157 write - Ok Record 158 write - Ok Record 159 write - Ok Record 160 write - Ok Record 161 write - Ok Record 162 write - Ok Record 163 write - Ok Record 164 write - Ok Record 165 write - Ok Record 166 write - Ok Record 167 write - Ok Record 168 write - Ok Record 169 write - Ok Record 170 write - Ok Record 171 write - Ok Record 172 write - Ok Record 173 write - Ok Record 174 write - Ok Record 175 write - Ok Record 176 write - Ok Record 177 write - Ok Record 178 write - Ok Record 179 write - Ok Record 180 write - Ok Record 181 write - Ok Record 182 write - Ok Record 183 write - Ok Record 184 write - Ok Record 185 write - Ok Record 186 write - Ok Record 187 write - Ok Record 188 write - Ok Field 391 Record 0 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Record 109 write - Ok Record 110 write - Ok Record 111 write - Ok Record 112 write - Ok Record 113 write - Ok Record 114 write - Ok Record 115 write - Ok Record 116 write - Ok Record 117 write - Ok Record 118 write - Ok Record 119 write - Ok Record 120 write - Ok Record 121 write - Ok Record 122 write - Ok Record 123 write - Ok Record 124 write - Ok Record 125 write - Ok Record 126 write - Ok Record 127 write - Ok Record 128 write - Ok Record 129 write - Ok Record 130 write - Ok Record 131 write - Ok Record 132 write - Ok Record 133 write - Ok Record 134 write - Ok Record 135 write - Ok Record 136 write - Ok Record 137 write - Ok Record 138 write - Ok Record 139 write - Ok Record 140 write - Ok Record 141 write - Ok Record 142 write - Ok Record 143 write - Ok Record 144 write - Ok Record 145 write - Ok Record 146 write - Ok Record 147 write - Ok Record 148 write - Ok Record 149 write - Ok Record 150 write - Ok Record 151 write - Ok Record 152 write - Ok Record 153 write - Ok Record 154 write - Ok Record 155 write - Ok Record 156 write - Ok Record 157 write - Ok Record 158 write - Ok Record 159 write - Ok Record 160 write - Ok Record 161 write - Ok Record 162 write - Ok Record 163 write - Ok Record 164 write - Ok Record 165 write - Ok Record 166 write - Ok Record 167 write - Ok Record 168 write - Ok Record 169 write - Ok Record 170 write - Ok Record 171 write - Ok Record 172 write - Ok Record 173 write - Ok Record 174 write - Ok Record 175 write - Ok Record 176 write - Ok Record 177 write - Ok Record 178 write - Ok Record 179 write - Ok Record 180 write - Ok Record 181 write - Ok Record 182 write - Ok Record 183 write - Ok Record 184 write - Ok Record 185 write - Ok Record 186 write - Ok Record 187 write - Ok Field 398 Record 0 write - Ok Done! Elapsed: 00:00:02 Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Error When resetting Full factory ... Settings Software Upgrade Defaults... Error When setting Software Upgrade Defaults ... Settings Service Centre Defaults... Error When setting Service Centre defaults ... Settings Production Tune Defaults... Error When settinng Production Tune defaults ... Settings User Data Defaults... Error When setting User Data defaults ... Settings Leave Factory defaults... Error When setting Leave Factory Defaults ... Elapsed: 00:00:03 Phone disconected! Connect phone on selected interface... card found: S/N C37C:0126 registered to: Finoyds Connect phone on selected interface... Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual File [Ok] : rm838__08.13.mcusw File [Ok] : rm838__08.13.ppm_l File [Ok] : rm838__08.13.image_l_059N757 Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049922028891850F014EC0F00 ASIC ID_E : 00000C2016100040 PUBLIC ID : 4A8037769031A2CA49922028891850F014EC0F00 XGCHIP ID : 4A8037769031A2CA ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 353294051297564 IMEI [2] : 353294051297572 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\Archivos de programa\BEST\Backup\Cert\353294051297564_XG223_CR T.rpl PAPUBkeys : FAF910DA218D8536CEFBDCE369A8C034160C6A5F === SW Version Check === - > REFLASHING === SW Version Check === === Flashing MCU === Processing file : rm838__08.13.mcusw Erasing... Writing... Total blocks : 90 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : FAF910DA218D8536CEFBDCE369A8C034160C6A5F] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 89 blocks were writen === Flashing PPM === Processing file : rm838__08.13.ppm_l Erasing... Writing... Total blocks : 13 File processed Ok, 13 blocks were writen === Flashing CNT === Processing file : rm838__08.13.image_l_059N757 Erasing... Writing... Total blocks : 104 File processed Ok, 104 blocks were writen Flashing done , total time : 00:01:06 Reboot phone to service mode... -------AFTER FLASH BREAKED BY USER------- - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Connect phone on selected interface... need Help i have 2 phone in same condicion Nokia 308.1 and Nokia 501s after write pm phone dead plaese support need some help BR...Yaio... |
05-15-2015, 10:10 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Congrats. Who advise you writing full PM in this phones? It useless completely. Also drivers problem, seems. Local mode can get by making copy of rpl and changing 1 digit in NPC string. Write it , write correct PM. |
05-15-2015, 18:35 | #5 (permalink) |
Member: 256260 Status: Offline Thanks Meter: 726 | sorry but my ingles but if you can make some more explained tuto i have this phones for test but i dont know how make phone enter in local mode please |
05-15-2015, 20:36 | #7 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
with notepad In second line , after NPC_DATA_1= will be some digits ( for ex. : 4E50.... ) change 4 to 5. Save file AS COPY! Not rewrite it ( save as ... ) in other place and write that new file in phone! After it will came in local mode. Fastly select write PM and your backup. Write it. Power off phone. Write original RPL, which not edited ( C:\Archivos de programa\BEST\Backup\Cert\353294051297564_XG223.rp l ) | ||
05-16-2015, 01:05 | #8 (permalink) |
Member: 256260 Status: Offline Thanks Meter: 726 | Open RPL backup : C:\Archivos de programa\BEST\Backup\Cert\353294051297564_XG223.rp l with notepad In second line , after NPC_DATA_1= will be some digits ( for ex. : 4E50.... ) change 4 to 5. Save file AS COPY! Not rewrite it ( save as ... ) in other place and write that new file in phone! After it will came in local mode. Fastly select write PM and your backup. Write it. Power off phone. Write original RPL, which not edited ( C:\Archivos de programa\BEST\Backup\Cert\353294051297564_XG223.rp l )[/QUOTE] ok i red and make the test and same result no come to local mode remember that hapen after write pm file phone disconect to pc and never come to local mode i have all backup of pm rpl and flash for this phone but imposible to revive Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! CMLA KEY found! WMDRM KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error -> Error answer from BootRom Detected XGOLD 223 platform , switching ASIC ID_F : 00000C201610004049922028891850F014EC0F00 ASIC ID_E : 00000C2016100040 PUBLIC ID : 4A8037769031A2CA49922028891850F014EC0F00 XGCHIP ID : 4A8037769031A2CA ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok Erase NPC ... Ok Write NPC ... Ok Erase CCC ... Ok Write CCC ... Ok Erase HWC ... Ok Write HWC ... Ok Reboot phone to service mode... |
The Following User Says Thank You to Yaio For This Useful Post: |
05-16-2015, 08:21 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Did you made that, as advised? Check again. I've tested with some phone some time before already and that is working. If still not - way is Flash Erase and RPL only. |
