01-18-2016, 14:11 | #1 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1250765 Status: Offline Sonork: NOt Available Thanks Meter: 28 | nokia 310 Security status : Security Damaged!!!!! :( i have rpl file but not recover how to solve it? Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! CMLA KEY found! WMDRM KEY found! -> Skip Flash keys Part, for Flash Part use Dead Mode!!!!! Product Code Update : 059S031 SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! CMLA key sent... Ok WMDRM_PD key sent... Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok phone imei is 12345610******? |
01-18-2016, 14:37 | #3 (permalink) |
Member: 1250765 Status: Offline Sonork: NOt Available Thanks Meter: 28 | After Skip Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! CMLA KEY found! WMDRM KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error -> Error answer from BootRom Detected XGOLD 223 platform , switching ASIC ID_F : 00000C2016100040498A240982DCB98207BA8C00 ASIC ID_E : 00000C2016100040 PUBLIC ID : C7416BE0005181F3498A240982DCB98207BA8C00 XGCHIP ID : C7416BE0005181F3 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok Erase NPC ... Ok Write NPC ... Ok Erase CCC ... Ok Write CCC ... Ok Erase HWC ... Ok Write HWC ... Ok Reboot phone to service mode... Writing SimLock Key... Ok! Writing SimLock Data... Ok! Product Code Update : 059S031 SimLock status : SimLock is Ok Security status : Security Damaged!!!!! CMLA key sent... Ok WMDRM key sent... Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Check phone mode... Phone in Test mode Seting Local mode... wait... Local mode set SX4 started ... - > IMEI Validation : IMEI Damaged!!!! |
