05-05-2015, 14:53 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | nokia 311 simlock damage after flash with best tool logs Code: Core : v2.05 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : 288A65E8_rm714__07.37.mcusw PPM : 137F5FFD_rm714__07.37.ppm_c CNT : D2CB6B09_rm714__07.37.image_c_059F7G9_059Q385_459_01 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103042108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 94390080FFFB7C40F3CB8469075A8F8A1BA836A0 ASIC MODE ID: 00 ROOT KEY HASH: 6D956B2D26FEC3C784E216492B7CC90A ROM ID: 2CAC45E21CB478AF Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354133051309962 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354133051309962_CRT_2nd.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing 288A65E8_rm714__07.37.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing 288A65E8_rm714__07.37.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 287 blocks TIME : Write time : 00:00:04 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing 137F5FFD_rm714__07.37.ppm_c Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing 137F5FFD_rm714__07.37.ppm_c Total writen 97 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing D2CB6B09_rm714__07.37.image_c_059F7G9_059Q385_459_01 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing D2CB6B09_rm714__07.37.image_c_059F7G9_059Q385_459_01 Total writen 763 blocks TIME : Write time : 00:00:14 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000010000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:24 Reboot phone now... Code: read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! :( - > Do REPAIR SDD , Local SX4 if needed CMLA Key status : CMLA key Not exist SimLock status : SimLock Damaged!!!!! :( - > Do REPAIR SL if it SL2/SL phone, if SL3 - Help Only Backup Or RPL Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! Code: Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103042108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 94390080FFFB7C40F3CB8469075A8F8A1BA836A0 ASIC MODE ID: 00 ROOT KEY HASH: 6D956B2D26FEC3C784E216492B7CC90A ROM ID: 2CAC45E21CB478AF Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Seek file for this phone.... ----------------------------- - > RPL file found for this phone! - > NPC Found in : 354133051309962_CRT.rpl Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) ----------------------------- Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000010000000000000000 ADL: Reboot -> No any Flex keys selected or found, skip flex part Connect phone on selected interface... Done! Connect phone on selected interface... Code: Repair SD procedure started... Phone Imei: 354133051309962 - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007400C192103042108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 94390080FFFB7C40F3CB8469075A8F8A1BA836A0 ROOT KEY HASH: 6D956B2D26FEC3C784E216492B7CC90A Fetching data, wait... Loader start : No ack , error #1! Fetching failed :( Fetching failed! |
05-05-2015, 15:01 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Only RPL will help. I already wrote about this pity phone thousand times - they can die even after simple boot. Nokia wan't care about this problem because Service Centers can repair this via server for a seconds. Now - not care anyone at all. |
05-05-2015, 22:43 | #6 (permalink) | |
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | Quote:
2) also i not erase i think it is a bug in infinity best or nokia 311 some days ago i flash nokia x2-02 with infinty best after set not turn on only before was ok. | |
05-05-2015, 23:13 | #8 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
I never face any issue with infinity Best tool Always use for flash Nokia new ( usb )or old phone ( with hwk). and never killed any phone. it may be phone itself has issue in it? Try to send back set to Nokia Server Center- Now a Days they say - we will not repair we will change your phone !!( Microsoft idea ) | |
