11-03-2017, 10:10 | #1 (permalink) |
Freak Poster Join Date: Mar 2015
Member: 2365163 Status: Offline Thanks Meter: 20 | Nokia 3310 2017 not resetting Im having an issue with this model, since its not booting into download mode. Running ver 2.29 Please help Here is the log: Phone found! MTKx Nokia Phone detected Read info... Ok Software Info: 11.02.11 00-00-00 TA-1030 IMEI: 357300081325469 PPM version : AA Product code: 059Z374 Rebooting phone to FlashMode... Wait for phone... Device boot not done Check Drivers Try again Phone disconected! |
11-14-2017, 16:45 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | BEST can Read Info, Read Dump, Reset UserCode and make SelfTest on ALL MTK Nokia phones. Doesnt matter it generation - MS or HMD. So, not need make fake advises. |
11-20-2017, 15:20 | #6 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friends, Always Use "Search" Button Before Posting Please... Already Many Members Posted Successfully Log. http://forum.gsmhosting.com/vbb/f641...-done-2254304/ nokia 3310 2017 code reset Done 100000000000 ok And Here's Mine... Code: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 193 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : B89F4A637778DD0DA2B51501AACFC7F2 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to MyGSM World For This Useful Post: |
02-16-2018, 10:24 | #7 (permalink) |
Major Poster Join Date: Feb 2018
Member: 2806380 Status: Offline Thanks Meter: 4 | nokia 3310 2017 ta-1030 not resetting security code via infinty best and cm2 Wait for phone... Phone found! [ 38 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Connect phone on selected interface... |
