Nokia 3310 TA-1030 read firmware error Operation : Reset Settings [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM9) MODE : NOKIA USB SERIAL PORT : 9 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9405867D280DDFAEE24F748D08442932 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.10.03.11_2.p1 BOOT : SWR : 10.03.11_2 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.10.03.11_2.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : 9405867D280DDFAEE24F748D08442932 PRDC : 059Z012 IMEI[1] : 356002082195989 IMEI[2] : 356002082195997 NCK : 20 digits PROV : 24407000 Saved as : 356002082195989.mtsec Saved to : D:\BST\BEST2\Backup\ Done! Elapsed: 00:00:50 Reconnect Power/Cable! Operation : Identify [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM9) MODE : NOKIA USB SERIAL PORT : 9 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9405867D280DDFAEE24F748D08442932 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.10.03.11_2.p1 BOOT : SWR : 10.03.11_2 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.10.03.11_2.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : 9405867D280DDFAEE24F748D08442932 PRDC : 059Z012 IMEI[1] : 356002082195989 IMEI[2] : 356002082195997 NCK : 20 digits PROV : 24407000 Saved as : 356002082195989.mtsec Saved to : D:\BST\BEST2\Backup\ Done! Elapsed: 00:00:48 Reconnect Power/Cable! Operation : Read FirmWare [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM9) MODE : NOKIA USB SERIAL PORT : 9 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9405867D280DDFAEE24F748D08442932 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.10.03.11_2.p1 BOOT : SWR : 10.03.11_2 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.10.03.11_2.p1 FLASH : 00EF : 0060 : 0018 : 0000 CODE : 0x00CD0000 Reading Flash ... Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! |
I solved by replacing usb port |
