11-24-2019, 09:57 | #1 (permalink) |
Insane Poster Join Date: Oct 2012 Location: Gsm World
Member: 1819074 Status: Offline Thanks Meter: 30 | Nokia 4.2 ta-1157 soft brick How to flash?????????? It Soft Brick After Write Patched Boot file and Show only Bootloader Screen ONLY I try writing original firmware with BEST ,Unfortunately it Can't write original Boot file Please help me to fix this problem Thank you. |
11-24-2019, 20:09 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Post BEST flashing logs first, then we can try to do something. Since for fastboot used completely different files, that boot.img, that not possible to block their writing after service auth. Next time read answers to your post, because already seen it and answer. |
02-28-2020, 03:56 | #3 (permalink) | |
Member: 1819074 Status: Offline Thanks Meter: 30 | Quote:
Here is the log, but i think the problem come from SW CurrSlot : INVALID Card found : 079191XX , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Identify [FTM] [ v1.18 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : Panther HW version : 1.4 HW variant : QRD eMMC HW RF_BAND : GSM_850_900_1800_1900^W1_5_8^L_1_3_5_7_8_20_28_38_ 40_41(120MHZ) SW version : V1.22G_B01 SW CurrSlot : INVALID SW serialnm : 4T89576EA1941302300 SW secured : YES Project DevCode : Panther Bootloader type : WT2 Security Version : 0002 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Team, how can i solve this problem???? | |
02-28-2020, 14:01 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SW set boot slot by default to A. It setup in firmware and flashing process. You can manually run command : fastboot --set-active=a for old fastboot impl fastboot set_active a or fastboot set_active _a |
02-28-2020, 23:57 | #5 (permalink) | |
I try it but it says "Slot a doesn't exist " I also try with slot b, it also give same output | |
04-01-2020, 00:54 | #7 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | good you have isp for reset mdm, the cell have sucurity boot This cell has the charger locked, I know how to modify it, but I could not find the tp. to fix it. C:\ADB>fastboot flashing get_unlock_ab ... (bootloader) get_unlock_ability: 0 OKAY [ 0.016s] the charger must be 1 in order to work normally |
The Following 2 Users Say Thank You to cellcarcol For This Useful Post: |
12-06-2022, 04:46 | #9 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | hello! I have the same phone with the same problem almost. It came to me with unlocked bootloader, I flashed it with best2 and now it hangs on logo. I tried this " fastboot --set-active=a " and it worked but still it doesn't power on. Any idea? This is the log: Operation : Flash Firmware [FTM] [ v1.20 ] Setting : UserData preserve : False Setting : FRP Reset : True Setting : Change SKUID : False Setting : Keep SVC : True -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : Panther HW version : 0.4 HW variant : QRD eMMC HW RF_BAND : GSM_850_900_1800_1900^W1_5_8^L_1_3_5_7_8_20_28_38_ 40_41(120MHZ) SW version : V1.17I_B01 SW CurrSlot : INVALID SW serialnm : 0123450786AB9DEC00F SW secured : NO Bootloader type : WT2 Security Version : 0002 Prepare base package, please, wait ... Prepare data package, please, wait ... Prepare update package, please, wait ... Device : Panther ( Panther ) BLType : WT2 SecVer : 02 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Process... Finished Disconnected Finished Challenge : Process Challenge : Passed! OP : Initial Process : sbl1 : sbl1.mbn Process : rpm : rpm.mbn Process : dsp : adspso.bin Process : tz : tz.mbn Process : cmnlib : cmnlib_30.mbn Process : cmnlib64 : cmnlib64_30.mbn Process : keymaster : km4.mbn Process : devcfg : devcfg.mbn Process : modem : NON-HLOS.bin Process : aboot : emmc_appsboot.mbn Process : custom : custom.img SPImage : Process custom_a_0 SPImage : Process custom_b_0 Process : splash : splash.img Process : picture : picture.img OP : Update Process : boot : boot.img Process : dtbo : dtbo.img Process : system : system.img SPImage : Process system_a_0 SPImage : Process system_a_1 SPImage : Process system_a_2 SPImage : Process system_a_3 SPImage : Process system_a_4 SPImage : Process system_a_5 SPImage : Process system_b_0 SPImage : Process system_b_1 SPImage : Process system_b_2 SPImage : Process system_b_3 SPImage : Process system_b_4 SPImage : Process system_b_5 Process : vbmeta : vbmeta.img Process : vendor : vendor.img SPImage : Process vendor_a_0 SPImage : Process vendor_b_0 OP : Post OP : UserData preserve : disabled Process : userdata : userdata.img SPImage : Process userdata_0 OP : Reset FRP Device : Panther ( Panther ) BLType : WT2 SecVer : 02 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Process... Finished Disconnected Finished Challenge : Process Challenge : Passed! Reset FRP Ok! Done! Elapsed: 00:06:51 Thanks! |
