12-31-2017, 08:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Nokia 5(TA-1053) Format done, Read firmware failed Phone Condition : Ok Model : Nokia 5 ta-1053 OS : Windows 10 x86 UAC : Off AV : Off Using Short cable as usual. Operation : Reset Settings [ v1.02 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : AFD3CB07 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : A5A1547A66E2D86940FD564EC0E73AD8 ID_BLOCK_L : D5DF880C30E50F4E5C3FCF268359B8B7 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! When you will see ANDROID on screen make next steps : 1. Press and Hold both 'Vol_UP' and 'Power_On' keys 2. Hold them until device will reboot and show again ANDROID logo 3. Release 'Power_On' button, wait when color circle appear on screen! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : AFD3CB07 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : A5A1547A66E2D86940FD564EC0E73AD8 ID_BLOCK_L : D5DF880C30E50F4E5C3FCF268359B8B7 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Brand : Nokia ProdName : TA-1053_00WW ProdModel : TA-1053 Device : ND1 Manufact. : HMD Global NickName : Nokia 5 Dev Build : TA-1053_00WW-user 7.1.1 NMF26F 00WW_3_32E release-keys Dev CPU : MSM8937 Dev SKU : 600WW SKU Vendor: NOKIA SKU Locale: Worldwide SKU Carier: FIH Generic DevInfo : Nokia__TA-1053_00WW__ND1__600WW Reading Flash Content ... [Read Ok] : gpt_main0.bin Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! Note : I also tried with Infinity CM2 QLM v1.16, But It stucks here. Please see the logs... Operation : Read Flash [ v1.16 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : AFD3CB07 ID_BLOCK_L : A5A1547A66E2D86940FD564EC0E73AD8 ID_BLOCK_L : D5DF880C30E50F4E5C3FCF268359B8B7 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! ERROR : Failed to read initial info! Erased/Damaged device??? HINT : Check cable, connection and drivers! Reconnect Power/Cable! Note : I also tried with compatibility settings using windows 7 and running as Administrator, But result is same. Please check the issue.. |
