04-13-2014, 15:25 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Nokia 501 ppm id error Code: Core : v1.86 , BB5XG FlashEngine : v9.8 Selected FlashSettings : Manual File [Ok] : rm902_11.1.1.mcusw.fpsx File [Ok] : rm902_11.1.1_059R2T6_m1_245_01_326885.rofs.fpsx File [Ok] : rm902_11.1.1_059R2T6_m1_245_01_326885.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049922E09B2D4100CAAA42300 ASIC ID_E : 00000C2016100040 PUBLIC ID : 1F51CA926A944F3049922E09B2D4100CAAA42300 XGCHIP ID : 1F51CA926A944F30 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 357294055005241 IMEI [2] : 357294055005258 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357294055005241_2nd_XG223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === PPM_ID Check === - > PPM_ID LOWER, THAN IN PHONE!!! - > Find other ID version and try again! - > Stop killing phone, break flashing! === PPM_ID Check === Error During flashing Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - 501 Software ver : V 14.0.4 07-03-14 RM-902 (c) Nokia IMEI : 357294055005241 XappVer : 00000744 APE Var : 0000000000000000000000000000000000000000 PPM : e87e8a112436adec81709208717d1db54ca6e4a8 CNT : Product SN : C0ADBC0BI Product code : 059T1W3 Base Prd.code: 059P9V6 Module code : 0205341 Long Prod.SN : 0 Hardware info======= HWID : 4000 Tahvo : RM-902-14.0.4-059T1W3-14.0.2-10.0.1 Batery: 3992 mV CMT BT: 0101-0.1.C LCDVer: TPO Lock info =========== IMEI : 357294055005241 IMEI spNet : 3A 75 92 04 55 00 25 04 IMEI svNet : 33 75 92 04 55 00 25 34 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User code : Crypted MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
04-13-2014, 15:31 | #2 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Hello, You are flashing with lower ver(11.1.1) and phone have already upper ver(14.0.4) So please wait till new best Navifirm/software release. therefore Best show Code: === PPM_ID Check === - > PPM_ID LOWER, THAN IN PHONE!!! - > Find other ID version and try again! - > Stop killing phone, break flashing! === PPM_ID Check === |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
04-13-2014, 15:42 | #3 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | For the this product code "059T1W3" Files has not been released but for others it has been released.. My question is can I flash other product code's files to this one like 14.0.4 and it will be ok or dead? |
04-13-2014, 15:45 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Make "Read RPL" and you will see ID inside phone. It is start point to check. |
The Following User Says Thank You to Dzirt For This Useful Post: |
04-13-2014, 15:52 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Not need hurry. In near 2-3 days I update whole PPM_ID base with all SW14 info. It will save all users from language headache. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
04-13-2014, 16:04 | #7 (permalink) | |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Quote:
Code: Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error :( -> Error answer from BootRom Detected XGOLD 223 platform , switching Remove MicroSD card, if face any boot problem ASIC ID_F : 00000C201610004049922E09B2D4100CAAA42300 ASIC ID_E : 00000C2016100040 PUBLIC ID : 1F51CA926A944F3049922E09B2D4100CAAA42300 XGCHIP ID : 1F51CA926A944F30 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 357294055005241 IMEI [2] : 357294055005258 Reboot phone to service mode... CRT308 Backup Created SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357294055005241_2nd_XG223.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok | |
