Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 10-05-2016, 06:12   #1 (permalink)
Member: 2195211
Thanks Meter: 4,294,967,295
Nokia 501 Rm 0-2 dead after flash
i flash with infinity dongle even with same product code and higher version but after flash phone just display nokia and blue secreen i try lot of files but fails.....
Old 10-05-2016, 06:27   #2 (permalink)
azaan.skp's Avatar
Member: 2242730
Thanks Meter: 42
Thumbs down
There's difference in your RM. Perfectly check your device RM and flash file are matching?
Don't forget to press thanks button below.
Old 10-05-2016, 06:30   #3 (permalink)
Member: 2195211
inside phone i have checked and there is rm 902 and i try a lot of version like 14.0.7 higher but fails,
Old 10-05-2016, 06:52   #4 (permalink)
Member: 2195211
PPM HASH : ea6d94589d9f63b081391ac0aae46b014a8938b3 here is inside check
Old 10-05-2016, 07:40   #5 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
post all logs from start
Old 10-05-2016, 07:47   #6 (permalink)
Member: 2195211
i flash with different files but all in vine after nokia display set gives blue display
Old 10-05-2016, 07:48   #7 (permalink)
Member: 2195211
1st Boot Done, processing booting now
ASIC ID_F : 00000C2016100040498A2C098A92E9C44F4A2200
ASIC ID_E : 00000C2016100040
PUBLIC ID : 66697AA856B7ED91498A2C098A92E9C44F4A2200
XGCHIP ID : 66697AA856B7ED91
ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579
ROM ID : 535882252F54C676
Prepare and send 2nd loader...
2nd boot Ok
Prepare and send Algo loader...
Algo boot Ok
IMEI [1] : 357898059246864
IMEI [2] : 357898059246872
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\357898059246864_2n d_XG223_CRT.rpl
PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E
=== SW Version Check ===
- > REFLASHING
=== Flashing MCU ===
Processing file : rm902_14.0.5.mcusw.fpsx
Erasing...
Writing...
Total blocks : 82
Writing RKH CRT [ISSW]
Writing RKH CRT [MEMSET]
Writing RKH CRT [PRIMAPP]
Writing RKH CRT [LOADER]
Writing RKH CRT [PASUBTOC]
Writing RKH CRT [PAPUBKEYS] [PAKeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E]
Writing RKH CRT [UPDAPP]
Writing RKH CRT [MCUSW]
File processed Ok, 81 blocks were writen
=== Flashing PPM ===
Processing file : rm902_14.0.5_059R306_s1.rofs.fpsx
Erasing...
Writing...
Total blocks : 27
Writing RKH CRT [PPM]
File processed Ok, 27 blocks were writen
=== Flashing CNT ===
Processing file : rm902_14.0.5_059R306_s1.image.fpsx
Erasing...
Writing...
Total blocks : 54
File processed Ok, 54 blocks were writen
Flashing done , total time : 00:00:52
Reboot phone to service mode...
- > AfterFlash Failed! Reason : Downgrade try or HW Error
Anyway - try reinsert battery and PowerUp phone manualy
Connect phone on selected interface...
Old 10-05-2016, 08:09   #8 (permalink)
pradyumnasahoo's Avatar
Member: 1267573
Thanks Meter: 144
flash with other product code...bur version is same..........
Old 10-05-2016, 08:22   #9 (permalink)
Member: 654997
Thanks Meter: 4,073
Hello,
seek/find upper firmware version(ppm ID) and flash phone
BTW: you did not post logs from start
Old 10-05-2016, 09:07   #10 (permalink)
Member: 2195211
i have not logs from start but can u help me to find out i try a lot of files
Old 10-05-2016, 09:16   #11 (permalink)
Member: 2195211
i try a lot of version upper or down but no use
Old 10-05-2016, 09:41   #12 (permalink)
Member: 654997
Thanks Meter: 4,073
Hello,
flash phone with 059V4B0 product code files and post result/logs.....
Old 10-05-2016, 10:05   #13 (permalink)
Member: 2195211
2nd boot Ok
Algo boot Ok
- > UPGRADE
Processing file : rm902_14.0.6.mcusw.fpsx
Erasing...
Writing...
Total blocks : 82
Processing file : rm902_14.0.2_059V345_s2_8971_02_452054.rofs.fpsx
Erasing...
Writing...
Total blocks : 27
Processing file : rm902_14.0.2_059V345_s2_8971_02_452054.image.fpsx
Erasing...
Writing...
Total blocks : 55
File processed Ok, 55 blocks were writen
Same problem bro
Old 10-05-2016, 14:07   #14 (permalink)
Member: 2195211
is there any solution of this phone
Old 10-05-2016, 14:21   #15 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 307
bug in this mobile firmware this model ppm is protected u needed to flash back original ppm first manually then write only mcu and cnt every time contact me private if u want to solved ur problem
Page generated in 0.19496 seconds with 8 queries
