03-22-2016, 08:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2014 Location: ALL THINGS ARE POSIBLE WTH ***
Member: 2203712 Status: Offline Sonork: 100.1667064 Thanks Meter: 82 | NOKIA 501s RM-899 FINALLY FLASHED SUCCESSFULLY Selected FlashSettings : Manual File [Ok] : rm899_14.0.6.mcusw.fpsx File [Ok] : rm899_14.0.4_059S9P1_eu2_250_04_453884.rofs.fpsx File [Ok] : rm899_14.0.4_059S9P1_eu2_250_04_453884.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040498A21099A2278D20B27B133 ASIC ID_E : 00000C2016100040 PUBLIC ID : 739151337488F6D2498A21099A2278D20B27B133 XGCHIP ID : 739151337488F6D2 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 355523050120973 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355523050120973_2n d_XG223_CRT.rpl PAPUBkeys : B45D33F7E5B2F73BBBAFBCA173B06B46F1861C70 === SW Version Check === - > REFLASHING === SW Version Check === === Flashing MCU === Processing file : rm899_14.0.6.mcusw.fpsx Erasing... Writing... Total blocks : 82 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : B45D33F7E5B2F73BBBAFBCA173B06B46F1861C70] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 81 blocks were writen === Flashing PPM === Processing file : rm899_14.0.4_059S9P1_eu2_250_04_453884.rofs.fpsx Erasing... Writing... Total blocks : 24 Writing RKH CRT [PPM] File processed Ok, 24 blocks were writen === Flashing CNT === Processing file : rm899_14.0.4_059S9P1_eu2_250_04_453884.image.fpsx Erasing... Writing... Total blocks : 62 File processed Ok, 62 blocks were writen Flashing done , total time : 00:01:01 Reboot phone to service mode... Reading Phone Info.... Connected phone - 501s Software Info: V 14.0.6 10-07-14 RM-899 (c) Nokia IMEI: 355523050120973 PPM version : 7db59f1ffb383d21c59b6a40a2b337e1235acf76 Product code: 059T2K0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
