Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 09-08-2012, 07:31   #1 (permalink)
Member: 700741
Sonork: 100.1617188
Thanks Meter: 343
nokia 5130 sl repier possible
Read and Check phone data...
SDD Key status : SDData Damaged!!!!!
- > Do REPAIR SDD , Local SX4 if needed
CMLA Key status : CMLA key Not exist
SimLock status : SimLock Damaged!!!!!
- > Do REPAIR SL if it SL2/SL phone, if SL3 - Help Only Backup Or RPL
Security status : Security is Ok
Old 09-08-2012, 08:07   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,161
First was needed kill phone? after ask about possible it or not? It seems as erased.
Old 09-08-2012, 08:15   #3 (permalink)
aliyousafzai's Avatar
Member: 1358184
Sonork: 100.1616912
Thanks Meter: 610
is it possible plz post screenshot
Old 09-08-2012, 08:56   #4 (permalink)
Member: 700741
Sonork: 100.1617188
Thanks Meter: 343
how to erase nokia 5130
Old 09-08-2012, 09:19   #5 (permalink)
Member: 700741
Sonork: 100.1617188
Thanks Meter: 343
Erase done with best dongle
after erase
again flash
here is infoo
Phone found!
Series 40 Device detected!
read info... - Ok
User ACCEPTED FULL ERASE
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006030C192101033000
CMT EM0 ID : 00000296
CMT EM1 ID : 00000B22
CMT PUB ID : 1AE0011360A87D5667AE30E58DA25D45A10FE64D
CMT MODE ID : 00
CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
MCU Cfg Ok , 03
FLASHID : 89820089 , CMT , NOR
CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1
CMT Algo sent
CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027
Transmission mode : Dual (Ddr, TX2)
Boot Done!
CMT : Read NPC certificate...
Cert size : 20480 byte(s)
IMEI : 354223036438505
CMT : Read CCC certificate...
Cert size : 30600 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 0 byte(s)
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\354223036438505_CR T_2nd.rpl
Full Erase started...
Asic : CMT , Sub : NOR
Erase Area 0x00000000-0x03FFFFFF
Using TimeOut : 10 min ( 600 sec )
Erasing, wait.....
CMT : Erase Ok
Done
Phone disconected!
Old 09-08-2012, 09:24   #6 (permalink)
Member: 1358184
Sonork: 100.1616912
Thanks Meter: 610
bro post next logs advance thanks
Old 09-08-2012, 09:38   #7 (permalink)
Member: 700741
Sonork: 100.1617188
Thanks Meter: 343
here is flash infooo
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings :
Files Set for Flashing :
MCU : rm495__07.97.mcusw
PPM : rm495__07.97.ppm_mena_a1
CNT : rm495__07.97.image_mena_a1_red
Check FlashFiles, Please, wait...
-> SWversion check skipped : Dead mode selected
Backup enabled, Will read Certificates now...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Sending ALGO....
CMT Algo sent
PAPUBkeys blank (erased or HW failure)
Boot Done!
- > No any CRT data (MCU damaged/CERT erased), skip saving
Init Service mode... Wait...
Init Service Mode Failed!
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm495__07.97.mcusw
Found 6 areas to erase, erase group
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00040000 - 0x000BFFFF
CMT , NOR , Area : 0x000C0000 - 0x0013FFFF
CMT , NOR , Area : 0x00140000 - 0x0137FFFF
CMT , NOR , Area : 0x01380000 - 0x0151FFFF
Using TimeOut : 7 min ( 430 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:00:05
PrReq : NOR , 00
Write : Processing rm495__07.97.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
Total writen 1169 blocks
TIME : Write time : 00:02:28
PrReq : NOR , 00
Erase : Processing rm495__07.97.ppm_mena_a1
Found 1 areas to erase, erase group
CMT , NOR , Area : 0x01520000 - 0x01DBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:02
PrReq : NOR , 00
Write : Processing rm495__07.97.ppm_mena_a1
Total writen 388 blocks
TIME : Write time : 00:00:47
PrReq : NOR , 00
ConvertImage: Processing rm495__07.97.image_mena_a1_red
ConvertImage: Page Size is 128K, no need convert
Erase : Processing rm495__07.97.image_mena_a1_red
Found 2 areas to erase, erase group
CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF
CMT , NOR , Area : 0x02160000 - 0x03FBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:08
PrReq : NOR , 00
Write : Processing rm495__07.97.image_mena_a1_red
Total writen 656 blocks
TIME : Write time : 00:01:21
PrReq : NOR , 00
Reading Phone Info....
Connected phone - Nokia 5130c-2
Software Info: V 07.97
13-09-10
RM-495
(c) Nokia
IMEI: 12345610654321?
Product code:
Checking...
SimLock status : SimLock is Ok
Read Info Done!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done ;D
Connect phone on selected interface...
Phone found!
read info... - Ok
IMEI Validation : IMEI Damaged!!!!
- > SIMLOCK , SECURITY Info can be wrong!
- > Need restore NPC backup or RPL
PA_SimLock Version :
PA_SL phone detected
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
PrReq : NOR , 00
Phone found!
read info... - Ok
Phone found!
read info... - Ok
Will Write RPL keys now...
Check RPL file...
NPC Data found! (CMT)
CCC Data found! (CMT)
HWC Data found! (CMT)
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Preparing for write certificates...
Switching to CMT...
CMT : NPC erase Ok
Writing NPC... Ok
CMT : CCC erase Ok
Writing CCC... Ok
CMT : HWC erase Ok
Writing HWC... Ok
Done!
Phone found!
read info... - Ok
Security status : Security Damaged!!!!!
- > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual )
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
PrReq : NOR , 00
Phone found!
read info... - Ok
Check RPL file...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Switching to CMT...
CMT : NPC erase Ok
Writing NPC... Ok
CMT : CCC erase Ok
Writing CCC... Ok
CMT : HWC erase Ok
Writing HWC... Ok
Done!
Phone found!
read info... - Ok
Phone disconected!
Phone found!
read info... - Ok
Phone disconected!
Phone found!
read info... - Ok
Phone disconected!
Phone found!
read info... - Ok
Phone disconected!
Phone found!
read info... - Ok
i try to write backup write dine
but imei 123456123456???
whyyyyy
Old 09-08-2012, 09:57   #8 (permalink)
Member: 1358184
Sonork: 100.1616912
Thanks Meter: 610
have you read full rpl backup???/
Old 09-08-2012, 10:04   #9 (permalink)
Member: 700741
Sonork: 100.1617188
Thanks Meter: 343
ys i have backup
backup write done nut imei same
Old 09-08-2012, 10:17   #10 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,161
Now buy RPL.
For revive it.
Old 09-08-2012, 10:48   #11 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 383
5220 flashing done
UFS S/N 73225 boot - Ok
Phone found!
read info... - Ok
Connected phone - Nokia 5220 XpressMusic
Software ver : V 07.23 17-07-09 RM-411 (c) Nokia
IMEI : 356840025036202
DSP Ver : ICPR72_09w17
PPM : V 07.23
17-07-09
RM-411
(c) Nokia
MA
CNT :
Product SN : KQB256798
Product code : 0563598
Base Prd.code: 0554881
Module code : 0203661
Long Prod.SN : 0
Hardware info=======
HWID : 7000
Retu : 15
Tahvo : 22
Batery: 4880 mV
CMT BT: 2222-143C
LCDVer: SEIKO
RF ic : 064c0601
Lock info ===========
IMEI spNet :
IMEI svNet :
Conf key : 0000000000000000
Provider key : 2440700000000000
Country : Finland
Operator : NOKIA (Open)
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
User Code : not set
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Selected FlashSettings : FullFlash
MCU : rm411__07.23.mcusw
PPM : rm411__07.23.ppm_mb
CNT : rm411__07.23.image_mb_b_grey
-> SWversion check skipped : Manual mode selected
SLx Simlock Data read ... ok
SL2 Simlock read ... ok
WMDRM read ... ok
CRT308 Backup Created
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT EM0 ID : 00000295
CMT PUB ID : 0820010989C57C563A76F8A617B488C5077C297E
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
CMT PAPUB : D93826B23E9B093BE4DD7304FBAA6778996AE60B09
Boot Done!
Cert Read done!
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\356840025036202.rp l
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm411__07.23.mcusw
Erasing, wait.....
TIME : Erase time : 00:01:41
PrReq : NOR , 00
Write : Processing rm411__07.23.mcusw
Total writen 1280 blocks
TIME : Write time : 00:02:26
PrReq : NOR , 00
Erase : Processing rm411__07.23.ppm_mb
Erasing, wait.....
TIME : Erase time : 00:00:31
PrReq : NOR , 00
Write : Processing rm411__07.23.ppm_mb
Total writen 400 blocks
TIME : Write time : 00:00:44
PrReq : NOR , 00
ConvertImage: Processing rm411__07.23.image_mb_b_grey
Erase : Processing rm411__07.23.image_mb_b_grey
Erasing, wait.....
TIME : Erase time : 00:01:23
PrReq : NOR , 00
Write : Processing rm411__07.23.image_mb_b_grey
Total writen 472 blocks
TIME : Write time : 00:00:52
PrReq : NOR , 00
Software Info: V 07.23
17-07-09
RM-411
(c) Nokia
IMEI: 356840025036202
Product code: 0563598
Checking...
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Total - 0 certs
Writen 21 certs!
GSM007
Old 09-08-2012, 12:08   #12 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 383
1280 Flashing Done
MCU : rm647_006.520
PPM : rm647_006.52aa
CNT : rm6470_nai06.52aa
Infineon flashing...
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
PBL : Dynamic
Boot Ok , 01AB
SBL : Dynamic
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH ID : 0020000000C08800
FLASH ID : ST, M58WR064
Boot Done!
===Flashing [MCU]===
File : rm647_006.520
Image : hw_b2_rm647_r06.520.fls
Cert block found, sending....
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00800000 , Len : 0x00210000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x00210000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00C60000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00C60000 , Len : 0x001F9440
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00FFC000 , Len : 0x00004000
Erasing, wait ...
Erase done
Write , Start : 0x00FFC000 , Len : 0x00000040
Flashing , wait ...
Region flash done
Check : A0A3
===Flashing [PPM]===
File : rm647_006.52aa
Image : hw_b2_rm647_006.52aa.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00210000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00210000 , Len : 0x0018D3C0
Flashing , wait ...
Region flash done
Check : 18A1
===Flashing [CNT]===
File : rm6470_nai06.52aa
Image : hw_b2_rm6470_nai06.52aa.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00EB0000 , Len : 0x000D0000
Erasing, wait ...
Erase done
Write , Start : 0x00EB0000 , Len : 0x00058400
Flashing , wait ...
Region flash done
Check : 4DA2
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Afterflash settings...
SW ver : V 06.52
23-08-11
RM-647
(c) Nokia
IMEI : 359045048655890
PCode : 0592303
FullFactorySet...OK!
SwUpgradeSet...OK!
All done!
GSM007
Old 09-08-2012, 12:14   #13 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 383
6303 hash read done
Phone Imei: 356235041953557
Checking locks...
Conf key : 8000000000000000
Provider key : 2720100000000000
Country : Ireland
Operator : vodafone IE
Blocks : 1
LOCK STATUS :
BLK : 1
Lock1:Close
LOCKS : Closed
PA_SL3 (15 digit) phone detected...
- > Power Off phone, dissconnect it and connect
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
ASIC ID: 000000010000022600000001020C192102054100
CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB
PUBLIC ID: 3810021417085640398FC8B0A84C607E978970F4
ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
Fetching data, wait...
- > Reinsert cable and battery, press powerOn button again
- > For X7, E7 - just waiting, near 1 minute
- > When BEST start Search Phone - Press PowerOn if needed
BootRom : 1st boot ok
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
ROM ID: 67E82268F29CEA60
Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0
Processing RAWLOADER...
FLIC : 003000EC
Req : XSR 1.6
Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:01
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 108AF4DB7EC8B1B36E9D6A60F7EB2996DC7B2B5D
ADL: Close_Session
Content: 000300000000000000000000000000
ADL: Reboot
Wait, reconneting...
rap= 3810021417085640398FC8B0A84C607E978970F4
hash= 7B045400E1752022F9EB80B0DEA9C65D
key= 42CADCFFFA39D90283569EEF83DC3E822EEE78FE
Key file updated...
Check RSA started...
Check RSA ok
Create Log file for local calculation...
File c:\InfinityBox\BEST\Local_calc\356235041953557.bcl created - Ok
File c:\InfinityBox\BEST\Local_calc\oclHashcat_35623504 1953557_32.bat created - Ok
File c:\InfinityBox\BEST\Local_calc\oclHashcat_35623504 1953557_64.bat created - Ok
Done!
GSM007
Page generated in 0.44840 seconds with 7 queries
