02-24-2014, 12:13 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | Nokia 5130c-2 RM-495 flashing problem !!!! Core : v1.82 , BB5XG FlashEngine : v9.5 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 22500208073D0056180B80D2766399D1F76FBA89 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < SAMSUNG => K81259ETF FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 0 byte(s) CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) - > No any CRT data (MCU damaged/CERT erased), skip saving Init Service mode... Wait... Init Service Mode Failed! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 22500208073D0056180B80D2766399D1F76FBA89 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < SAMSUNG => K81259ETF FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:05 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.97.mcusw Error, 03, DataMissMatch, Check Cable, FlashPack, Firmware Error write block at : 0 ERR : C7012D0103CD000090000000 Error on Flashing Phone! - > Error... Connect phone on selected interface... |
