09-24-2014, 12:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | Nokia 5130c-2 RM-495 Flashing problem !!!!! i flashed a lot of nokia 5130c-2,but this phone i foud problem at flashing !!!!!! The phone now is dead . This is log: Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 17B001018FB68C56C7D92703C7A15E288FD6B73A CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 003F0001 , CMT , NOR CMT Flash ID : 003F0001 < SPANSION => 72NS512P FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 359336038680554 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359336038680554.rp l Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 17B001018FB68C56C7D92703C7A15E288FD6B73A CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 003F0001 , CMT , NOR CMT Flash ID : 003F0001 < SPANSION => 72NS512P FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:06 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.97.mcusw Error, 03, DataMissMatch, Check Cable, FlashPack, Firmware Error write block at : 0 ERR : C7012D0103CD000090000000 Error on Flashing Phone! - > Error... Connect phone on selected interface... |
