11-03-2014, 06:35 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Nokia 5235 RM-588 only vibrate After receiving the set first i make full backup then full erase and flash with same product code but same |
11-03-2014, 07:14 | #3 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | here is log Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 CFL : Reading flash certs.... CFL : Reading NPC IMEI : 351526041452193 CFL : Reading CCC CFL : Reading HWC CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... Swap data collected to 059B716.pc RPL saved : C:\InfinityBox\BEST\Backup\Cert\351526041452193.rpl All done, Disconnecting Elapsed: 00:01:03 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5236 Software ver : V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia IMEI : 351526041452193 XappVer : 000007B2 Ape Ver : V 51.1.002 APE Var : V 51.1.002V 51.1.002 APE ADSP: 256 DSP Ver : ICPR72_11WK13 APE Test: eno_version PPM : CNT : Product SN : MWH844149 Product code : 059B716 Base Prd.code: 0597014 Module code : 0204359 Long Prod.SN : 0 Hardware info======= HWID : 0512 Retu : 16 Tahvo : 22 Batery: 3670 mV APE HW: 256 Lock info =========== IMEI : 351526041452193 IMEI spNet : 3A 15 25 06 14 54 12 09 IMEI svNet : 33 15 25 06 14 54 12 19 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Reading PM from field 0 to 400 Field [1] 24 Record(s) Record 0: 114 byte(s) readed - Ok Record 2: 98 byte(s) readed - Ok Record 4: 110 byte(s) readed - Ok Record 6: 98 byte(s) readed - Ok Record 8: 110 byte(s) readed - Ok Record 13: 98 byte(s) readed - Ok Record 16: 98 byte(s) readed - Ok Record 18: 98 byte(s) readed - Ok Record 20: 98 byte(s) readed - Ok Record 22: 16 byte(s) readed - Ok Record 23: 4 byte(s) readed - Ok Record 24: 84 byte(s) readed - Ok Record 25: 4 byte(s) readed - Ok Record 26: 110 byte(s) readed - Ok Record 28: 98 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 31: 98 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 34: 80 byte(s) readed - Ok Record 35: 16 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 44: 182 byte(s) readed - Ok Record 45: 182 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 440 byte(s) readed - Ok Field [4] 7 Record(s) Record 1: 80 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 10 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 24 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1054 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 102 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 16 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 3 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 38 byte(s) readed - Ok Record 2: 30 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [88] 1 Record(s) Record 0: 36 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 7 Record(s) Record 0: 21 byte(s) readed - Ok Record 1: 79 byte(s) readed - Ok Record 2: 79 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 24: 596 byte(s) readed - Ok Record 25: 132 byte(s) readed - Ok Record 26: 12 byte(s) readed - Ok Field [117] 10 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 9 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [208] 1 Record(s) Record 1: 4 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 4 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 2306 byte(s) readed - Ok Record 2: 2306 byte(s) readed - Ok Record 3: 2306 byte(s) readed - Ok Field [291] 1 Record(s) Record 0: 92 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 8 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 5: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 8: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4516 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 13 byte(s) readed - Ok Field [356] 1 Record(s) Record 0: 2 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-625 Nokia 5236_351526041452193_0_400.pm Done! Elapsed: 00:00:00 Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done :( Boot error... :( Boot error #1, break :( Phone disconected! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. :( Boot error #1, break :( Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 CFL : Reading NPC IMEI : 351526041452193 CFL : Reading CCC CFL : Reading HWC NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351526041452193_CRT.rpl Will read flash content now... Flash IC Size : 256 MB Read done , 164 MB has read ==== WARNING ==== Memory Dump NOT CONTAIN [USER_AREA] block , it can be used only for SL extraction! ==== WARNING ==== Collected data saved to : 351526041452193_full.bin CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Done!!! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok User ACCEPTED FULL ERASE Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done :( Boot error... :( Looks like ASIC not supported in that mode, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm - > RAPIDO only from DEAD mode Phone disconected! Connect phone on selected interface... User ACCEPTED FULL ERASE Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error :( -> Error answer from BootRom Looks like HW failure / Cable / Battery problem Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO User ACCEPTED FULL ERASE Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 Seek file for this phone.... - > Backup for phone found and it is Ok :) CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 CFL : Reading NPC IMEI : 351526041452193 CFL : Reading CCC CFL : Reading HWC NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351526041452193_CRT_2nd.rpl CFL: Preparing for erase... Full Erase started... Asic : CMT , Sub : NAND Erase Area 0x00000000-0x0FFFFFFF Erasing Ok , [0F] Erase done , time : 00:00:01 - > USE "COLD FLASH" option in FlashSetting for revive device by USB!!! CFL: Erase done CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Phone disconected! Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Cold Flash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-588_51.0.002_prd.core.C00 PPM : RM-588_51.0.002_prd.rofs2.V21 PPM2 : RM-588_51.0.002_C01_prd.rofs3.fpsx CNT : RM-588_51.0.002_000_001_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected - > Force ColdFlash mode Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : Blank (Erased or HW failure) CFL: phone is in flash mode === SW Version Check === - > Can not collect initial info, continue flashing... - > Hope, this version will be ok === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-588_51.0.002_prd.core.C00 Partitioning.... Partitioning Ok... Erasing.... Erasing Data.... Erase area : 0x00040000 - 0x00082FFF , CMT , NAND Erase area : 0x00083400 - 0x003FFFFF , CMT , NAND Erase area : 0x00400000 - 0x007FFFFF , CMT , NAND Erase area : 0x00800000 - 0x00D5FFFF , CMT , NAND Erase area : 0x00D60000 - 0x09E5FFFF , CMT , NAND Erase Partition Partition 0x0A Erase Ok... TIME : Erase time : 00:00:01 CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 Write : Processing RM-588_51.0.002_prd.core.C00 CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*ENO] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 437 blocks TIME : Write time : 00:01:54 MCU Write done CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-588_51.0.002_prd.rofs2.V21 Erasing.... Erasing Data.... Erase area : 0x06FE0000 - 0x0915FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 Write : Processing RM-588_51.0.002_prd.rofs2.V21 CMT: Writing Hash CERT [SOS+ROFS2] Total writen 50 blocks TIME : Write time : 00:00:12 PPM Write done CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-588_51.0.002_C01_prd.rofs3.fpsx Erasing.... Erasing Data.... Erase area : 0x09160000 - 0x09E5FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 Write : Processing RM-588_51.0.002_C01_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 26 blocks TIME : Write time : 00:00:06 PPM Write done CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-588_51.0.002_000_001_U001.uda.fpsx Erasing.... Erasing Data.... Erase area : 0x09E60000 - 0x0F47FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 Write : Processing RM-588_51.0.002_000_001_U001.uda.fpsx Total writen 75 blocks TIME : Write time : 00:00:20 CNT Write done CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Flashing done! Total flash time : 00:02:35 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 Seek file for this phone.... ----------------------------- - > RPL file found for this phone! - > NPC Found in : 351526041452193.rpl Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! ----------------------------- Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 CFL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok CFL: Writing Flash certs done! :) CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Wait, reconneting... - > Phone not found... :( - > CertWrite failed : phone was not bootup - > Connection/SW/HW problem, try bootup manually - > If phone bootup Ok - write only flex keys |
11-03-2014, 13:26 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It will run Ok only on own RM with correct IMEI, on other - it will not at all! |
The Following User Says Thank You to Dzirt For This Useful Post: |
11-03-2014, 14:58 | #7 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | flash with own RM and write IMEI but same Code: card found: S/N 0613:0118 registered to: sujay dey Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-588_51.6.002_prd.core.C00 PPM : RM-588_51.6.002_prd.rofs2.V21 PPM2 : RM-588_51.6.002.426.01.rofs3.fpsx CNT : RM-588_51.6.002_000_001_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 Waiting for response: 21 Waiting for response: 20 Waiting for response: 19 Waiting for response: 18 Waiting for response: 17 Waiting for response: 16 Waiting for response: 15 Waiting for response: 14 Waiting for response: 13 Waiting for response: 12 Waiting for response: 11 Waiting for response: 10 Waiting for response: 9 Waiting for response: 8 Waiting for response: 7 Waiting for response: 6 Waiting for response: 5 Waiting for response: 4 Waiting for response: 3 Waiting for response: 2 Waiting for response: 1 Phone not found... :( Elapsed: 00:00:00 Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Cold Flash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-588_51.6.002_prd.core.C00 PPM : RM-588_51.6.002_prd.rofs2.V21 PPM2 : RM-588_51.6.002.426.01.rofs3.fpsx CNT : RM-588_51.6.002_000_001_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected - > Force ColdFlash mode Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 CFL: phone is in flash mode === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-588_51.6.002_prd.core.C00 Partitioning.... Partitioning Ok... Erasing.... Erasing Data.... Erase area : 0x00040000 - 0x00082FFF , CMT , NAND Erase area : 0x00083400 - 0x003FFFFF , CMT , NAND Erase area : 0x00400000 - 0x007FFFFF , CMT , NAND Erase area : 0x00800000 - 0x00D5FFFF , CMT , NAND Erase area : 0x00D60000 - 0x09E5FFFF , CMT , NAND Erase Partition Partition 0x0A Erase Ok... TIME : Erase time : 00:00:01 CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 Write : Processing RM-588_51.6.002_prd.core.C00 CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*ENO] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 421 blocks TIME : Write time : 00:02:00 MCU Write done CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-588_51.6.002_prd.rofs2.V21 Erasing.... Erasing Data.... Erase area : 0x06BA0000 - 0x0915FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 Write : Processing RM-588_51.6.002_prd.rofs2.V21 CMT: Writing Hash CERT [SOS+ROFS2] Total writen 50 blocks TIME : Write time : 00:00:14 PPM Write done CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-588_51.6.002.426.01.rofs3.fpsx Erasing.... Erasing Data.... Erase area : 0x09160000 - 0x09E5FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 Write : Processing RM-588_51.6.002.426.01.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 26 blocks TIME : Write time : 00:00:07 PPM Write done CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-588_51.6.002_000_001_U001.uda.fpsx Erasing.... Erasing Data.... Erase area : 0x09E60000 - 0x0F47FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 Write : Processing RM-588_51.6.002_000_001_U001.uda.fpsx Total writen 75 blocks TIME : Write time : 00:00:23 CNT Write done CFL: Request programm status NAND status : 00000003 / 00000003 / 00000000 CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Flashing done! Total flash time : 00:02:47 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:04:48 Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! SIMLOCK KEY found! WMDRM KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0A900114F60E0052D69D43CCBF2AB8F2D82F62DA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! :) CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Wait, reconneting... Phone not found... :( CertWrite failed : phone was not bootup Connection/SW/HW problem, try bootup manually If phone bootup Ok - write only flex keys Phone disconected! Connect phone on selected interface... |
11-15-2014, 15:15 | #10 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | Finally i have done with Fbus cable Connect phone on selected interface... UFS S/N xxxxx boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5230 Software ver : V ICPR72_11w16.1 28-07-11 RM-588 (c) Nokia IMEI : 351526xxxxxxxx XappVer : 000007B2 Ape Ver : V 51.6.002 APE Var : V 51.6.002V 51.6.002 51.6.002.426.01 APE ADSP: 256 DSP Ver : ICPR72_11WK13 APE Test: eno_version PPM : CNT : Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 16 Tahvo : 22 Batery: 4676 mV APE HW: 256 RF ic : 17141716 Lock info =========== IMEI : 351526xxxxxxxxx IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! |
The Following User Says Thank You to ishant For This Useful Post: |
