07-06-2015, 19:01 | #1 (permalink) |
Freak Poster Join Date: Jun 2012 Location: pakistan multan
Member: 1768715 Status: Offline Sonork: sunny21 Thanks Meter: 37 | nokia 535 rm-1090 flashing done by infinity best Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone RMxxx ID : RM-1090 Phone Model ID : Nokia.MSM8212.P6214.1.1 Phone Model PC : 059W7L1 Phone IMEI : 355741067018069 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : BC2353ACA62C327ECCD582A281CA4A5672F35001 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 52% Battery Level enough to flash FFU : RM1090_02063.00000.15114.43005_RETAIL_prod_signed_ 1029_02089E_000-PK.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light Image Sent, processing PostFlash Make Factory Set : Ok PostFlash Finished Total flash time : 00:07:55 Rebooting Connect phone on selected interface... Phone found! WP8x Nokia Phone detected Read info... Ok |
The Following User Says Thank You to sunny21 For This Useful Post: |
