08-30-2012, 00:36 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Marrakech
Member: 282206 Status: Offline Thanks Meter: 102 | nokia 5800 rm-356 just vibre Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-356_60.0.003_prd.core.C00 PPM : RM-356_60.0.003_prd.rofs2.V11 PPM2 : RM-356_60.0.003_C03_prd.rofs3.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 14700014DA5B8B5212A95E4B09E0B75BB115A2C6 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_60.0.003_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing RM-356_60.0.003_prd.core.C00 Total 510 [510/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:35 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_60.0.003_prd.rofs2.V11 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_prd.rofs2.V11 Total 75 [75/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:05 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_60.0.003_C03_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_C03_prd.rofs3.fpsx Total 9 [9/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:43 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia IMEI: 357988030587062 Ape Version: V 60.0.003 Product code: 0577544 Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:16 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software ver : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia IMEI : 357988030587062 Ape Ver : V 60.0.003 APE Var : V 60.0.003V 60.0.003 V 60.0.003 APE ADSP: 256 DSP Ver : ICPR72_10w26p1 APE Test: eno_version PPM : CNT : v 31.0.008_020_xxx_U01 18-08-09 vanilla RM356 Product SN : MTI426565 Product code : 0577544 Base Prd.code: 0584472 Long Prod.SN : 0 Hardware info======= HWID : 1102 Retu : 15 Tahvo : 22 Batery: 3730 mV APE HW: 256 Lock info =========== IMEI : 357988030587062 IMEI spNet : 3A 75 89 08 03 85 07 06 IMEI svNet : 33 75 89 08 03 85 07 76 F4 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Damaged!!!!! PA_SL2 phone User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:08 Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... thank you |
08-30-2012, 00:58 | #2 (permalink) |
Junior Member Join Date: Dec 2010 Location: jl.sukowati watampone Age: 44
Member: 1478451 Status: Offline Sonork: phstracent Thanks Meter: 0 | nokia 5800 rm-356 just vibre Just sharing solutions For Nokia 5800_5233_5230 in on just vibrate .... please enjoy .... |
08-30-2012, 11:24 | #4 (permalink) |
Member: 282206 Status: Offline Thanks Meter: 102 | hello i have repaired security but still same problem thank you Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software ver : V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia IMEI : 357988030587062 Ape Ver : V 52.0.007 APE Var : V 52.0.007V 52.0.007 52.0.007.251.09 APE ADSP: 256 DSP Ver : ICPR72_10w16 APE Test: eno_version PPM : CNT : 52.0.007_007_U251 Product SN : 0 Product code : 0577544 Long Prod.SN : 0 Hardware info======= HWID : Retu : 15 Tahvo : 22 Batery: 3691 mV APE HW: 256 Lock info =========== IMEI : 357988030587062 IMEI spNet : 3A 75 89 08 03 85 07 06 IMEI svNet : 33 75 89 08 03 85 07 76 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Damaged!!!!! PA_SL2 phone User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 357988030587062 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 357988030587062 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-356.pm Setting to : 0577544 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Upload done Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software ver : V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia IMEI : 357988030587062 Ape Ver : V 52.0.007 APE Var : V 52.0.007V 52.0.007 52.0.007.251.09 APE ADSP: 256 DSP Ver : ICPR72_10w16 APE Test: eno_version PPM : CNT : 52.0.007_007_U251 Product SN : 0 Product code : 0577544 Long Prod.SN : 0 Hardware info======= HWID : Retu : 15 Tahvo : 22 Batery: 3706 mV APE HW: 256 Lock info =========== IMEI : 357988030587062 IMEI spNet : 3A 75 89 08 03 85 07 06 IMEI svNet : 33 75 89 08 03 85 07 76 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SL2 phone User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:08 |
The Following User Says Thank You to abderrahmane bi For This Useful Post: |
