10-02-2014, 07:08 | #3 (permalink) | |
No Life Poster Join Date: Mar 2009
Member: 988667 Status: Offline Sonork: 1593975 Thanks Meter: 42 | Quote:
Uploading RF/Battery tune to phone... Using : RM-356.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 manuy time try alwasy show this o try restore ccc.hwc but sitll not done... flash erase then restore .. agin ST_SECURITY => DAMAGED : how to slove this | |
10-02-2014, 09:23 | #5 (permalink) |
Member: 988667 Status: Offline Sonork: 1593975 Thanks Meter: 42 | PA_SimLock Version : PA_SL2 phone detected Done! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 351531xxxxxxxx Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 28 write - Ok Record 29 write - Ok Record 31 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 37 write - Ok Record 39 write - Ok Record 44 write - Ok Record 45 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Done! Elapsed: 00:00:00 Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! |
