11-10-2015, 07:47 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: srilanka
Member: 283153 Status: Offline Thanks Meter: 30 | NOKIA 5800 SIMLOCK_DATA corrupted How fix it.. Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software ver : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia IMEI : 358279038435788 XappVer : 00000852 Ape Ver : V 60.0.003 APE Var : V 60.0.003V 60.0.003 V 60.0.003 APE ADSP: 256 DSP Ver : ICPR72_10w26p1 APE Test: eno_version PPM : CNT : Product SN : MML057343 Product code : 0588613 Base Prd.code: 0592754 Long Prod.SN : 0 Hardware info======= HWID : 1104 Retu : 16 Tahvo : 22 Battery: 3953 mV APE HW: 256 Lock info =========== IMEI : 358279038435788 IMEI spNet : 3A 85 72 09 83 34 75 08 IMEI svNet : 33 85 72 09 83 34 75 78 F4 Unable to read Lock table... Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Damaged!!!!! Security status : Ok PA_SimLock Version : PA_SL phone detected User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
11-10-2015, 10:07 | #5 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2100013 Status: Offline Thanks Meter: 125 | http://forum.gsmhosting.com/vbb/f641...c-how-1363981/ First Click READ FULL FLASH after finished Click RESTORE SL Tick FROM PHONE To see what happens? To see if there 120PM certificate, please keep in mind is very important 120PM If there were RPL certificate backup Then erase And then flash ENO After the completion of the complete firmware flash Repair your RPL Repair Super dongle Repair SL manually select from READ FULL FLASH extracted 120PM Click LOCAL SX4 AUTH fix 1 + 309PM Factory settings Check all |
The Following User Says Thank You to LOKEMUNFU For This Useful Post: |
