04-13-2013, 14:05 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | nokia 5800 sx4 fail Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 353382044610595 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-356.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again |
04-13-2013, 14:14 | #3 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software ver : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia IMEI : 353382044610595 Ape Ver : V 60.0.003 APE Var : V 60.0.003V 60.0.003 V 60.0.003 APE ADSP: 256 DSP Ver : ICPR72_10w26p1 APE Test: eno_version PPM : CNT : v 50.2010.06.1_001_000_U01 17-03-10 vanilla RM356 Product SN : CZB681854 Product code : 0577187 Base Prd.code: 0552692 Module code : 0204481 Long Prod.SN : 0 Hardware info======= HWID : 1101 Retu : 16 Tahvo : 22 Batery: 4587 mV APE HW: 256 Lock info =========== IMEI : 353382044610595 IMEI spNet : 3A 35 83 02 44 16 50 09 IMEI svNet : 33 35 83 02 44 16 50 79 F4 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Damaged!!!!! PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 353382044610595 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-356.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Upload done |
04-13-2013, 14:17 | #4 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 353382044610595 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! |
04-13-2013, 14:27 | #5 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | may be i m not good user but me use best dongle daily mr dzirt plz help me i try same same but fail me also try with other tools |
04-13-2013, 14:53 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | After you make local SX4 - go to Service tab , select Only 1/309 , press write PM button and select PM file from other Nokia 5800. |
The Following User Says Thank You to Dzirt For This Useful Post: |
04-13-2013, 16:28 | #7 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | me read its pm than write security test fail ok but when press power whet screen after 35 sec colurs displays flacker and goes phone off |
04-14-2013, 11:01 | #9 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | i m slow next day me come back............. Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software ver : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia IMEI : 3533xxxxxxx10595 Ape Ver : V 60.0.003 APE Var : V 60.0.003V 60.0.003 V 60.0.003 APE ADSP: 256 DSP Ver : ICPR72_10w26p1 APE Test: eno_version PPM : CNT : v 50.2010.06.1_001_000_U01 17-03-10 vanilla RM356 Product SN : C9A143646 Product code : 0575374 Base Prd.code: 0552692 Module code : 0204481 Long Prod.SN : 0 Hardware info======= HWID : 1002 Retu : 16 Tahvo : 22 Batery: 4595 mV APE HW: 256 Lock info =========== IMEI : 35338xxxxxxx10595 IMEI spNet : 3A 35 83 02 44 16 50 09 IMEI svNet : 33 35 83 02 44 16 50 79 F4 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Initializing Tests... IMEI : 353382044610595 , Phone : RM-356 Nokia 5800 XpressMusic Get keys... PASSED | ST_TAHVOINT_TEST PASSED | ST_UEM_CBUS_IF_TEST UNKNOW | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_RADIO_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST ->ERROR | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_IIC_TEST PASSED | ST_EXT_DEVICE_TEST PASSED | ST_CDSP_SLEEPCLK_FREQ_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST PASSED | ST_CDSP_TX_IQ_TEST PASSED | ST_CDSP_TXC_DATA_TEST PASSED | ST_CDSP_PWR_DETECTOR_BIAS_TEST PASSED | ST_CDSP_RX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_CAMERA_ACCELERATOR_TEST ->ERROR | ST_SEC_CAMERA_IF_TEST PASSED | ST_LED_FLASH_TEST PASSED | ST_CAMERA_AUTOFOCUS_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_MAIN_LCD_IF_TEST PASSED | ST_TOUCH_STUCK_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_WLAN_TEST PASSED | ST_BT_WLAN_COEXISTENCE_TEST PASSED | ST_TOUCH_IF_TEST PASSED | ST_ACCEL_IF_TEST PASSED | ST_LCD_CONTROLLER_TEST PASSED | ST_VIBRA_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_RADIO_TEST PASSED | ST_TVOUT_IF_TEST PASSED | ST_IO_EXPANDER_IF_TEST SelfTests end Done! Elapsed: 00:00:29 |
04-14-2013, 11:20 | #10 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | solve solve after checking selftest................. solve after checking selftest amazing plz discribe here real why all things check but ?after selftest working ok |
