05-25-2011, 18:19 | #1 (permalink) |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 36
Member: 1116719 Status: Offline Thanks Meter: 542 | nokia 6120 Security Damaged!!!!! :( SDD Key status : SD Data is Ok SimLock status : Can't get status Security status : Security Damaged!!!!! Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... Reading Phone Info.... Connected phone - Nokia 6120 Software ver : V 06.01 02-09-08 RM-243 (c) Nokia IMEI : 3552xxxxxxxxxxx Ape Ver : 06.01 APE Var : Vr MEA_A 01-12-06 RM-243 APE ADSP: 256 DSP Ver : 06w41pb_08w28.0.1_rm243 APE Test: PPM : CNT : Product SN : MIH117589 Product code : 0567074 Base Prd.code: 0539292 Module code : Long Prod.SN : 0 Hardware info======= HWID : 0602 Retu : 15 Tahvo : 22 Batery: 4801 mV Camera: CMT BT: APE BT: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064. APE HW: 256 LCDVer: RF ic : 17141715 Lock info =========== IMEI : 35520xxxxxxxxx IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 08521 UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
05-25-2011, 18:24 | #2 (permalink) |
Member: 1116719 Status: Offline Thanks Meter: 542 | Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connect to server Ok, checking SX4 Server : Online, Ready SX4, processing Step #1 SX4, processing Step #2 SX4 Error, #2 1) Sx4_Ph Timeout , Try again max 3-5 times 2) SDD Non-original - > If SDD repaired - Use Local SX4 with Cust.Kets selected SX4 Auth error Local SX4 procedure started... Phone Imei: 355xxxxxxxx Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 04F00006D57D0052CAEBE08D7462984582B925B4 CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 04F00006D57D0052CAEBE08D7462984582B925B4 hash= CAEEBB65D3C48E6DC73B49DC5063A2EE key= F9B9308EE2EB9187F535D8C37CFEAA8599CC5D55 Init Service mode... Wait... Key file updated... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : Can't get status Security status : Security Damaged!!!!! ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! Uploading RF/Battery tune to phone... Using : RM-243.pm Check phone mode... Phone already in Local mode, skip change... Field 1 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 15 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 31 write - Ok Record 33 write - Ok Record 34 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 46 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED Done! Elapsed: 00:00:20 |
05-26-2011, 01:45 | #4 (permalink) | |
Member: 1116719 Status: Offline Thanks Meter: 542 | Quote:
Will Write CCC/HWC keys now... Using : RM-243.rpl CCC Data found! HWC Data found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 04F00006D57D0052CAEBE08D7462984582B925B4 CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00300020 , CMT , NAND CMT Flash ID : 00300020 < UNKNOW [NOT IN BASE] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent CMT PAPUB : 0FE1BA92D924A658E4800780FA6F4868100AC9475A Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : Can't get status Security status : Security Damaged!!!!! ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! Done! Elapsed: 00:00:16 | |
05-26-2011, 06:36 | #8 (permalink) | |
Code: Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... SL2 Simlock read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 04F00006D57D0052CAEBE08D7462984582B925B4 CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00300020 , CMT , NAND CMT Flash ID : 00300020 < UNKNOW [NOT IN BASE] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent CMT PAPUB : 0FE1BA92D924A658E4800780FA6F4868100AC9475A Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 2048 byte(s) IMEI : 3552xxxxxxxxxxxx CMT : Read CCC certificate... Cert size : 1024 byte(s) CMT : Read HWC certificate... Cert size : 1024 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\35520xx11_2nd.rpl Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Code: User ACCEPTED FULL ERASE Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 04F00006D57D0052CAEBE08D7462984582B925B4 CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00300020 , CMT , NAND CMT Flash ID : 00300020 < UNKNOW [NOT IN BASE] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent CMT PAPUB : 0FE1BA92D924A658E4800780FA6F4868100AC9475A Transmission mode : Dual (Ddr, TX2) Boot Done! Full Erase started... Asic : CMT , Sub : NAND Erase Area 0x00000000-0x07FFFFFF Erasing, wait..... Erase CMT Finished , [FF] CMT : Erase Ok Done Code: Boot Done! CMT : Read NPC certificate... Cert size : 0 byte(s) CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) No any CRT data (MCU damaged/CERT erased), skip saving Init Service mode... Wait... Init Service Mode Failed! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 04F00006D57D0052CAEBE08D7462984582B925B4 CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00300020 , CMT , NAND CMT Flash ID : 00300020 < UNKNOW [NOT IN BASE] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing rm243_07.20_prd_core.fpsx Found 3 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x00040000 - 0x00082FFF CMT , NAND , Area : 0x00083400 - 0x0087FFFF CMT , NAND , Area : 0x00B80000 - 0x04DFFFFF Erasing, wait..... CMT : Group erase Ok Erase Partition 0x0A , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:01 PrReq : NOR , 00 PrReq : NAND , 000300000000000000000000000000 Transmission mode : Dual (Ddr, TX2) Write : Processing rm243_07.20_prd_core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS*CORE] CMT: Writing Hash CERT [SOS+ROFS] Error, 03, DataMissMatch, Check Cable, FlashPack, Firmware Error write block at : 240 ERR : C7012D0103CD000010000000 Error on Flashing Phone! Error... :( Connect phone on selected interface... | |
05-26-2011, 06:46 | #9 (permalink) |
Member: 1116719 Status: Offline Thanks Meter: 542 | usb flashing ok Code: Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 04F00006D57D0052CAEBE08D7462984582B925B4 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! :) TIME : Boot time : 00:00:33 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm243_07.20_prd_core.fpsx Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing rm243_07.20_prd_core.fpsx Total 404 [404/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:16 MCU Write done ===Flashing [PPM]=== Erase : Processing rm243_07.20_prd_vB21_01_mea_b.fpsx Found 1 areas to erase Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_vB21_01_mea_b.fpsx Total 164 [164/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:34 PPM Write done ===Flashing [CNT]=== Erase : Processing rm243_07.20_prd_UDA_Sand_Gold.fpsx_128 Found 1 areas to erase Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_UDA_Sand_Gold.fpsx_128 Total 1 [1/0/0] blocks to write, writing... TIME : Write time : 00:00:00 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:52 Reboot phone now... Code: Connected phone - Nokia 6120 Software ver : V 07.20 05-10-09 RM-243 (c) Nokia IMEI : 12345610654321? Ape Ver : 07.20 APE Var : Vr MEA_B 01-12-06 RM-243 APE ADSP: 256 DSP Ver : 06w41pb_08w28.0.3_rm243 APE Test: PPM : CNT : Product SN : 0 Product code : Base Prd.code: Module code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 15 Tahvo : 22 Batery: 3754 mV Camera: CMT BT: APE BT: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 61 F0 Unable to read Lock table... :( IMEI data damaged, CRT save skipped... :( User code : Crypted UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Code: Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 04F00006D57D0052CAEBE08D7462984582B925B4 CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00300020 , CMT , NAND CMT Flash ID : 00300020 < UNKNOW [NOT IN BASE] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent CMT PAPUB : 0FE1BA92D924A658E4800780FA6F4868100AC9475A Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Done! Connect phone on selected interface... |
05-26-2011, 06:49 | #10 (permalink) |
Member: 1116719 Status: Offline Thanks Meter: 542 | Reading Phone Info.... Connected phone - Nokia 6120 Software ver : V 07.20 05-10-09 RM-243 (c) Nokia IMEI : 35520xxxxxxxxxxxxxx Ape Ver : 07.20 APE Var : Vr MEA_B 01-12-06 RM-243 APE ADSP: 256 DSP Ver : 06w41pb_08w28.0.3_rm243 APE Test: PPM : CNT : Product SN : 0 Product code : Base Prd.code: Module code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 15 Tahvo : 22 Batery: 3765 mV Camera: CMT BT: APE BT: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 35520xxxxxxxxxxx IMEI spNet : 3A 55 02 01 53 59 51 01 IMEI svNet : 33 55 02 01 53 59 51 61 F0 Unable to read Lock table... CRT308 Backup Created User code : Crypted UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! ----------------------- SDD Key status : SDData Damaged!!!!! SimLock status : Can't get status (Looks like OK) Security status : Security is Ok ----------------------- Repair SD procedure started... Phone Imei: 35520xxxxxxxxxxx Key file exists, no need to read... Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Writing Super Dongle Key... Ok! Done! Phone disconected! Local SX4 procedure started... Phone Imei: 35520xxxxxxxxx Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... Last edited by >>.123.<<; 05-26-2011 at 06:58. |
05-26-2011, 07:09 | #12 (permalink) |
Member: 1116719 Status: Offline Thanks Meter: 542 | Repair SL procedure started... Phone Imei: 35520xxxxxxxxxxx Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Ok Writing SimLock Key... Ok Done! Repair SD procedure started... Phone Imei: 355201xxxxxxxx Key file exists, no need to read... Operating mode is OK, no need change... Writing Super Dongle Key... Ok Done! Local SX4 procedure started... Phone Imei: 35520xxxxxxxxxxx Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : Can't get status Security status : Security Damaged!!!!! ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! |
05-26-2011, 07:49 | #14 (permalink) |
No Life Poster Join Date: May 2006 Location: I Love Walking In The Rain Bec
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | Local SX4 procedure started... Phone Imei: 35520xxxxxxxxxxx Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... [B][COLOR="Yellow"]Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : Can't get status Security status : Security Damaged!!!!! ----------------------- PA_SimLock Version : PA_SL2 phone detected as we know BB5 Easy Service Tool (BEST) Nokia Dongle not add SX4 Auth server you can try in mobileEx |
05-26-2011, 07:55 | #15 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | What? Local SX4 work from a long time. Server Sx4 also works. But here need local,for this case. After SD repair always need tick - Custom keys option. |
