11-16-2012, 17:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | nokia 6120C CMLA Key status : Not Present ; How repair here's alog Code: card found: S/N XXXXXXXX registered to: XXXXXXX Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6120 Software ver : V 07.20 05-10-09 RM-243 (c) Nokia IMEI : 359850014129733 Ape Ver : 07.20 APE Var : Vr MEA_A 01-12-06 RM-243 APE ADSP: 256 DSP Ver : 06w41pb_08w28.0.3_rm243 APE Test: rm243_ENO_A_2009wk15v0.100 PPM : CNT : Product SN : MMI610912 Product code : 0553527 Base Prd.code: 0539292 Long Prod.SN : 0 Hardware info======= HWID : 0801 Retu : 15 Tahvo : 22 Batery: 3988 mV APE BT: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064. APE HW: 256 Lock info =========== IMEI : 359850014129733 IMEI spNet : 3A 95 58 00 41 21 79 03 IMEI svNet : 33 95 58 00 41 21 79 63 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL2 phone detected User Code : 12345 UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
11-16-2012, 18:50 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | u dont need to fix, if u downgrad bb5 so this field will damage and this time u cannot solve this problem with best tool, but many times tested if i downgrad c7 or n8 after downgrad best cannot write this filed from backup , but i dont have problem with damage this field, so no problem. |
The Following 2 Users Say Thank You to soshan For This Useful Post: |
07-11-2014, 10:06 | #4 (permalink) |
Crazy Poster Join Date: Oct 2005 Location: multan,pakistan
Member: 195472 Status: Offline Thanks Meter: 15 | HELLO Dzirt sir, The problem is nokia 5800 restart with in 3 to 5 min, Full flash but as it is there is [CMLA Key status : Not Present] is that problem or others please GUIDE me ......THANKS in advance Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software ver : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia IMEI : 351531046012802 XappVer : 0000076C Ape Ver : V 60.0.003 APE Var : V 60.0.003V 60.0.003 V 60.0.003 APE ADSP: 256 DSP Ver : ICPR72_10w26p1 APE Test: eno_version PPM : CNT : v 50.2010.06.1_001_000_U01 17-03-10 vanilla RM356 Product SN : C7C219503 Product code : 0559300 Base Prd.code: 0573711 Long Prod.SN : 0 Hardware info======= HWID : 1101 Retu : 16 Tahvo : 22 Batery: 3804 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708. APE HW: 256 Lock info =========== IMEI : 351531046012802 IMEI spNet : 3A 15 35 01 64 10 82 00 IMEI svNet : 33 15 35 01 64 10 82 70 F4 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL2 phone detected User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
07-11-2014, 10:09 | #5 (permalink) |
Member: 195472 Status: Offline Thanks Meter: 15 | Initializing Tests... IMEI : 351531046012802 , Phone : RM-356 Nokia 5800 XpressMusic Get keys... PASSED | ST_TAHVOINT_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_BACKUP_BATT_TEST ->ERROR | ST_RADIO_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_IIC_TEST NOT EXECUTED | ST_EXT_DEVICE_TEST NOT EXECUTED | ST_CDSP_SLEEPCLK_FREQ_TEST NOT EXECUTED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT EXECUTED | ST_CDSP_TX_IQ_TEST NOT EXECUTED | ST_CDSP_TXC_DATA_TEST NOT EXECUTED | ST_CDSP_PWR_DETECTOR_BIAS_TEST NOT EXECUTED | ST_CDSP_RX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST SelfTests end |
