05-27-2018, 17:04 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | Nokia 700 RM-670 stuck on teset mode ???? Supported : RapuYamaVx, RAP3Gv4, BroadComm, RAPIDO, XG213, XG221, XG223, XG618 Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Reading Phone Info.... Connected phone - Nokia 700 Software ver : V 79u_sr1_11w34_4 16-09-11 RM-670 (c) Nokia IMEI : 357023049486286 XappVer : 000008F2 Ape Ver : 111.020.0308 APE Var : 111.020.0308111.020.0308.11.01111.020.0308.C00.01 APE ADSP: 256 DSP Ver : 79u_sr1_11w34_4 APE Test: RM670_11w30_05_ENO_037 PPM : CNT : Product SN : CZG562010 Product code : 059L4G3 Base Prd.code: 059C3Z9 Module code : 0204685 Long Prod.SN : 0 Hardware info======= HWID : 1004 Retu : 35 Tahvo : 00 Battery: 3512 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 357023049486286 IMEI spNet : 3A 75 20 03 94 84 26 08 IMEI svNet : 33 75 20 03 94 84 26 08 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Reading User code... User Code is: Error! Crypted user code! Done! Reading PM from field 0 to 400 Field [1] 31 Record(s) Record 0: 10 byte(s) readed - Ok Record 1: 94 byte(s) readed - Ok Record 2: 110 byte(s) readed - Ok Record 4: 10 byte(s) readed - Ok Record 6: 110 byte(s) readed - Ok Record 7: 450 byte(s) readed - Ok Record 8: 10 byte(s) readed - Ok Record 13: 110 byte(s) readed - Ok Record 15: 30 byte(s) readed - Ok Record 16: 30 byte(s) readed - Ok Record 17: 30 byte(s) readed - Ok Record 18: 30 byte(s) readed - Ok Record 19: 30 byte(s) readed - Ok Record 22: 24 byte(s) readed - Ok Record 26: 10 byte(s) readed - Ok Record 27: 36 byte(s) readed - Ok Record 28: 110 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 30: 36 byte(s) readed - Ok Record 31: 24 byte(s) readed - Ok Record 32: 216 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 35: 24 byte(s) readed - Ok Record 36: 24 byte(s) readed - Ok Record 38: 216 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 24 byte(s) readed - Ok Record 41: 216 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 216 byte(s) readed - Ok Record 45: 216 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2808 byte(s) readed - Ok Field [4] 7 Record(s) Record 1: 200 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [6] 1 Record(s) Record 0: 98 byte(s) readed - Ok Field [8] 9 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Record 11: 4 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1061 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [26] 2 Record(s) Record 0: 16 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 18 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [88] 1 Record(s) Record 0: 60 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [117] 10 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 42 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [122] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 14 Record(s) Record 0: 2 byte(s) readed - Ok Record 3: 6267 byte(s) readed - Ok Record 4: 6267 byte(s) readed - Ok Record 5: 6267 byte(s) readed - Ok Record 6: 6267 byte(s) readed - Ok Record 7: 6267 byte(s) readed - Ok Record 8: 6267 byte(s) readed - Ok Record 11: 6267 byte(s) readed - Ok Record 12: 6267 byte(s) readed - Ok Record 13: 6267 byte(s) readed - Ok Record 14: 6267 byte(s) readed - Ok Record 15: 6267 byte(s) readed - Ok Record 20: 6267 byte(s) readed - Ok Record 21: 222 byte(s) readed - Ok Field [296] 4 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Record 3: 5 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 7 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [313] 1 Record(s) Record 0: 800 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4512 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 15 byte(s) readed - Ok Field [356] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [360] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Field [382] 1 Record(s) Record 1: 4 byte(s) readed - Ok Field [388] 1 Record(s) Record 0: 4 byte(s) readed - Ok Field [395] 1 Record(s) Record 0: 16 byte(s) readed - Ok Saved as D:\BST\BEST\Backup\RM-670 Nokia 700_357023049486286_0_400.pm Done! Elapsed: 00:00:01 Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 48300000FFFB7C401F0F5E1234770B97EF98FD96 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : BD43E84B21F8AC7B9C66EA939355891E2A08044A ADL: Reading certificates... Reading NPC certificate... IMEI : 357023049486286 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\BST\BEST\Backup\Cert\357023049486286.rpl All done, Disconnecting Elapsed: 00:00:06 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Error When resetting Full factory ... Elapsed: 00:01:15 Phone disconected! Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-670_113.010.1506_79u_prd.core.fpsx PPM : RM-670_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-670_113.010.1506_C00.01_79u_prd.rofs3.fpsx CNT : RM-670_113.010.1506_U03.01_79u.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 48300000FFFB7C401F0F5E1234770B97EF98FD96 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : BD43E84B21F8AC7B9C66EA939355891E2A08044A ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357023049486286 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\BST\BEST\Backup\Cert\357023049486286_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-670_113.010.1506_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing RM-670_113.010.1506_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 559 blocks TIME : Write time : 00:00:18 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-670_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-670_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 228 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-670_113.010.1506_C00.01_79u_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-670_113.010.1506_C00.01_79u_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] CMT: Writing Hash CERT [SOS+IVE3B] Total writen 4 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-670_113.010.1506_U03.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-670_113.010.1506_U03.01_79u.uda.fpsx Total writen 762 blocks TIME : Write time : 00:00:28 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:00:59 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 700 Software Info: V 79u_sr2_12w20.8 20-08-12 RM-670 (c) Nokia IMEI: 357023049486286 Ape Version: 113.010.1506 Product code: 059L4G3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:55 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
