11-11-2014, 09:59 | #1 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 701 call problem i have Nokia 701(rm-774) Incoming call ok, But some time when try to dial call show "not allowed"(signal show full),(need to be restart mobile for solved problem temporarily) some time during call disconnect call and show"connection error" so please tell me is it software(should i flash?) or hardware(what could be?) problem? Thanks..... |
11-11-2014, 10:13 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. For start - try with other Service Provider, to make sure about need to dig in phone. Second - PM with SX4 and factory sets. Last - is HW level. Not forget about SW - some Carriers support can be added only in latest FW's. |
11-11-2014, 13:33 | #3 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Hello, Flashing+PM with SX4(pm link) Logs. Code: Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 701 Software ver : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI : 358272041659791 XappVer : 000007BC Ape Ver : 113.010.1506 APE Var : 113.010.1506113.010.1506.10.01113.010.1506.C00.01 APE ADSP: 256 DSP Ver : 79u_sr2_12w20_2 APE Test: 0.037 PPM : CNT : Product SN : M1L361718 Product code : 059H219 Base Prd.code: 059G8T9 Long Prod.SN : 0 Hardware info======= HWID : 2011 Retu : 40 Tahvo : 00 Batery: 3992 mV APE BT: HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 3472. APE HW: 256 Lock info =========== IMEI : 358272041659791 IMEI spNet : 3A 85 72 02 14 56 79 09 IMEI svNet : 33 85 72 02 14 56 79 39 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Reading PM from field 0 to 400 Field [1] 31 Record(s) Record 0: 10 byte(s) readed - Ok Record 1: 94 byte(s) readed - Ok Record 2: 110 byte(s) readed - Ok Record 4: 10 byte(s) readed - Ok Record 6: 110 byte(s) readed - Ok Record 7: 450 byte(s) readed - Ok Record 8: 10 byte(s) readed - Ok Record 13: 110 byte(s) readed - Ok Record 15: 30 byte(s) readed - Ok Record 16: 30 byte(s) readed - Ok Record 17: 30 byte(s) readed - Ok Record 18: 30 byte(s) readed - Ok Record 19: 30 byte(s) readed - Ok Record 22: 24 byte(s) readed - Ok Record 26: 10 byte(s) readed - Ok Record 27: 36 byte(s) readed - Ok Record 28: 110 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 30: 36 byte(s) readed - Ok Record 31: 24 byte(s) readed - Ok Record 32: 216 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 35: 24 byte(s) readed - Ok Record 36: 24 byte(s) readed - Ok Record 38: 216 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 24 byte(s) readed - Ok Record 41: 216 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 216 byte(s) readed - Ok Record 45: 216 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2808 byte(s) readed - Ok Field [4] 6 Record(s) Record 1: 200 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [6] 1 Record(s) Record 0: 98 byte(s) readed - Ok Field [8] 10 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Record 11: 4 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1062 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [26] 2 Record(s) Record 0: 16 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 18 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 1 Record(s) Record 26: 12 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [122] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 7 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 6268 byte(s) readed - Ok Record 2: 6268 byte(s) readed - Ok Record 3: 6268 byte(s) readed - Ok Record 4: 6268 byte(s) readed - Ok Record 5: 6268 byte(s) readed - Ok Record 6: 226 byte(s) readed - Ok Field [296] 4 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Record 3: 5 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 7 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [313] 1 Record(s) Record 0: 800 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4516 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 15 byte(s) readed - Ok Field [356] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [360] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Field [382] 2 Record(s) Record 0: 64 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Field [388] 1 Record(s) Record 0: 4 byte(s) readed - Ok Field [389] 9 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 10 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 7: 3 byte(s) readed - Ok Record 8: 3 byte(s) readed - Ok Record 21: 80 byte(s) readed - Ok Field [395] 1 Record(s) Record 0: 16 byte(s) readed - Ok Saved as F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\Backup\RM-774 Nokia 701_358272041659791_0_400.pm Done! Elapsed: 00:00:02 Check phone mode... Phone in Normal mode Seting Test mode... wait... Test mode set Reading Product Profile sets... 0 - 127 1 - 0 4 - 0 7 - 1 9 - 0 34 - 0 35 - 0 56 - 0 61 - 0 65 - 0 66 - 0 69 - 1 70 - 0 71 - 1 78 - 0 79 - 1 100 - 1 130 - 5 131 - 7 135 - 0 138 - 0 145 - 0 146 - 0 147 - 0 157 - 1 158 - 1 164 - 0 165 - 0 166 - 0 168 - 0 177 - 0 183 - 0 192 - 0 202 - 3 205 - 0 206 - 0 211 - 0 212 - 0 214 - 0 217 - 0 219 - 0 220 - 0 228 - 0 SETS 1 Readed 43 element(s) Saved as F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\RM-774 Nokia 701_358272041659791.pp Done! Elapsed: 00:00:18 Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: BA0D0000FFFF7C402B0E528E88B8B7B4E5A6D5E3 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Reading certificates... Reading NPC certificate... IMEI : 358272041659791 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\Backup\Cert\358272041659791_2nd.rpl All done, Disconnecting Elapsed: 00:00:07 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.98 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual -> File : RM-774_M011.23.emmc.fpsx not found! Check it! Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-774_113.010.1506_79u_prd.core.fpsx PPM : RM-774_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-774_113.010.1506_C25.01_MEA_Embargo_79u_prd.rofs3.fpsx CNT : RM-774_113.010.1506_U05.01_79u.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 113.010.1506 Phone version : 113.010.1506 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3663 mV -> Batery voltage less, than 3,7V (3663mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: BA0D0000FFFF7C402B0E528E88B8B7B4E5A6D5E3 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358272041659791 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\Backup\Cert\358272041659791_2nd.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-774_113.010.1506_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-774_113.010.1506_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 562 blocks TIME : Write time : 00:00:19 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-774_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-774_113.010.1506_10.01_MEA_A_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 229 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-774_113.010.1506_C25.01_MEA_Embargo_79u_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-774_113.010.1506_C25.01_MEA_Embargo_79u_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] CMT: Writing Hash CERT [SOS+IVE3B] Total writen 4 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-774_113.010.1506_U05.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing RM-774_113.010.1506_U05.01_79u.uda.fpsx Total writen 794 blocks TIME : Write time : 00:00:33 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:06 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 701 Software Info: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI: 358272041659791 Ape Version: 113.010.1506 Product code: 059H219 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:41 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 358272041659791 - > Power Off phone, dissconnect it and connect - > Phone was not powered Off Can't read Unique data! :( Repair fail...! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 358272041659791 - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: BA0D0000FFFF7C402B0E528E88B8B7B4E5A6D5E3 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: BA0D0000FFFF7C402B0E528E88B8B7B4E5A6D5E3 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... rap= BA0D0000FFFF7C402B0E528E88B8B7B4E5A6D5E3 hash= 3AB5DB70B45D23F1ADEEBB5734160706 key= F375E19BBA1A0EF450C33D4E3A3B3DA13BA82F4A Key file updated... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041659791 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041659791 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... RM-774.pm not exist Select file, please Using : RM-774 Nokia 701.pm Setting to : 059H219 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:05:09 Upload failed Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:08 Phone disconected! Connect phone on selected interface... Thanks.. |
