11-21-2013, 08:03 | #1 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | nokia 701 security test failed but same logs Info Quote:
Code: Read Uniq key data started... Key file exists, no need to read... Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272042976152 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272042976152 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... RM-774.pm not exist Select file, please Using : RM-774okkk Nokia 701.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED :( - > Try "Restore CCC/HWC" option, after SX4 again Done! Code: Will Write RPL keys now... Check RPL file... CCC Data found! (CMT) HWC Data found! (CMT) Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 327F0000FFFF7C4053C9AC81562091317A61A550 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot -> No any Flex keys selected, skip flex part Done! Phone disconected! Connect phone on selected interface... info Code: Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! | |
11-21-2013, 08:24 | #3 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | I write rm-779 pm but same Code: Check SD : Key is Ok Phone Imei: 358272042976152 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... RM-774.pm not exist Select file, please Using : RM-779.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED :( - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:18 Upload done |
11-21-2013, 12:20 | #7 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | Here is the info Code: Phone found! Series 60 Device detected! read info... - Ok Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 701 Software ver : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI : 35827------------ XappVer : 000006D6 Ape Ver : 113.010.1506 APE Var : 113.010.1506113.010.1506.18.01113.010.1506.C00.01 APE ADSP: 256 DSP Ver : 79u_sr2_12w20_2 APE Test: 0.037 PPM : CNT : Product SN : M1L419058 Product code : 059J7M6 Long Prod.SN : 0 Hardware info======= HWID : 2011 Retu : 40 Tahvo : 00 Batery: 4712 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 3582720---------- IMEI spNet : 3A 85 72 02 24 79 16 05 IMEI svNet : 33 85 72 02 24 79 16 35 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Damaged!!!!! PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
