10-04-2017, 11:06 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Nokia 8 [TA-1004] INFO/TESTING and ect. 2. If SW warn you about UNSUPPORTED BOOT VERSION for unlock - senf us report and we will fix it. Nothing more need to know about this phones. Unlock BootLoader : Code: Operation : Unlock BootLoader [FTM] [ v1.01 ] -> Power Off Phone, wait 5-10 seconds, Insert USB cable Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : NB1 HW version : PVT1 SW version : NB1-3080-0-00WW-B02 All done! Switching to main mode -- > Info : Use "Restore BootLoader" after done need operations with device! -- > Hint : FW Flashing will automatically restore bootloader! Done! Elapsed: 00:00:11 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 835 [MSM8998] ID_BLOCK_S : A16A2D1F ID_BLOCK_I : 0005E0E1 ID_BLOCK_L : 178F25B587487C3A694E61751FE47A2B ID_BLOCK_L : 846742BFF9DCAC5132AD040C46D683D4 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1ED-B0C1 0200 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29,50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Brand : Nokia ProdName : TA-1004_00WW ProdModel : TA-1004 Device : NB1 Manufact. : HMD Global NickName : Nokia 8 Dev Build : TA-1004_00WW-user 7.1.1 NMF26F 00WW_3_080 release-keys Dev CPU : MSM8998 Dev SKU : 600WW SKU Vendor: NOKIA SKU Locale: Worldwide SKU Carier: FIH Generic DevInfo : Nokia__TA-1004_00WW__NB1__600WW Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : a_hidden.img [Read Ok] : a_cda.img [Read Ok] : a_sysinfo.cfg [Read Ok] : a_adspso.bin [Read Ok] : a_NON-HLOS.bin [Read Ok] : a_boot.img [Read Ok] : a_system.img [Read Ok] : b_hidden.img [Read Ok] : b_cda.img [Read Ok] : b_sysinfo.cfg [Read Ok] : b_adspso.bin [Read Ok] : b_NON-HLOS.bin [Read Ok] : b_boot.img [Read Ok] : b_system.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : splash2.img [Read Ok] : label.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main1.bin [Read Ok] : a_xbl.elf [Read Ok] : gpt_backup1.bin [Read Ok] : gpt_main2.bin [Read Ok] : b_xbl.elf [Read Ok] : gpt_backup2.bin [Read Ok] : gpt_main3.bin [Read Ok] : gpt_backup3.bin [Read Ok] : gpt_main4.bin [Read Ok] : a_rpm.mbn [Read Ok] : a_tz.mbn [Read Ok] : a_hyp.mbn [Read Ok] : a_pmic.bin [Read Ok] : a_btfm.mbn [Read Ok] : a_mtdsecapp.mbn [Read Ok] : a_mdtp.img [Read Ok] : a_abl.elf [Read Ok] : a_keymaster.mbn [Read Ok] : a_cmnlib.mbn [Read Ok] : a_cmnlib64.mbn [Read Ok] : a_devcfg.mbn [Read Ok] : a_splash.img [Read Ok] : b_rpm.mbn [Read Ok] : b_tz.mbn [Read Ok] : b_hyp.mbn [Read Ok] : b_pmic.bin [Read Ok] : b_btfm.mbn [Read Ok] : b_mtdsecapp.mbn [Read Ok] : b_mdtp.img [Read Ok] : b_abl.elf [Read Ok] : b_keymaster.mbn [Read Ok] : b_cmnlib.mbn [Read Ok] : b_cmnlib64.mbn [Read Ok] : b_devcfg.mbn [Read Ok] : b_splash.img [Read Ok] : sec.dat [Read Ok] : logfs.bin [Read Ok] : storesec.mbn [Read Ok] : gpt_backup4.bin [Read Ok] : gpt_main5.bin [Read Ok] : a_def_preset.mbn [Read Ok] : b_def_preset.mbn [Read Ok] : gpt_backup5.bin Android Info saved! Read finished! Configuration : Nokia MSM8996 / UFS Firmware Size : 5447 MiB Done! Elapsed: 00:06:31 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 835 [MSM8998] ID_BLOCK_S : A16A2D1F ID_BLOCK_I : 0005E0E1 ID_BLOCK_L : 178F25B587487C3A694E61751FE47A2B ID_BLOCK_L : 846742BFF9DCAC5132AD040C46D683D4 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1ED-B0C1 0200 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29,50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:01:00 Reconnect Power/Cable! Code: Loading firmware ... Created by Infinity-Box (c) BEST (c) 2017 Device Brand : Nokia Device IntName : TA-1004_00WW Device TA-IDxx : TA-1004 Device Manufact.: HMD Global Device Model : NB1 Device CPU : MSM8998 Nokia Model : Nokia 8 CU_SWVer : HMD Global Device Project : 600WW Dev Build Info : TA-1004_00WW-user 7.1.1 NMF26F 00WW_3_080 release-keys Dev CPU : MSM8998 Dev SKU : 600WW SKU Vendor : NOKIA SKU Locale : Worldwide SKU Carier : FIH Generic Load Ok! Operation : Flash [ v1.01 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 835 [MSM8998] ID_BLOCK_S : A16A2D1F ID_BLOCK_I : 0005E0E1 ID_BLOCK_L : 178F25B587487C3A694E61751FE47A2B ID_BLOCK_L : 846742BFF9DCAC5132AD040C46D683D4 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1ED-B0C1 0200 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29,50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Flash Chain : 90 Flashing now Flashing : gpt_main0.bin Flashing : a_hidden.img Flashing : a_cda.img Flashing : a_sysinfo.cfg Flashing : a_adspso.bin Flashing : a_NON-HLOS.bin Flashing : a_boot.img Flashing : a_system.img Flashing : b_hidden.img Flashing : b_cda.img Flashing : b_sysinfo.cfg Flashing : b_adspso.bin Flashing : b_NON-HLOS.bin Flashing : b_boot.img Flashing : b_system.img Flashing : persist.img Flashing : misc.img Flashing : splash2.img Flashing : label.img Flashing : userdata.img Flashing : gpt_backup0.bin Flashing : gpt_main1.bin Flashing : a_xbl.elf Flashing : gpt_backup1.bin Flashing : gpt_main2.bin Flashing : b_xbl.elf Flashing : gpt_backup2.bin Flashing : gpt_main3.bin Flashing : gpt_backup3.bin Flashing : gpt_main4.bin Flashing : a_rpm.mbn Flashing : a_tz.mbn Flashing : a_hyp.mbn Flashing : a_pmic.bin Flashing : a_btfm.mbn Flashing : a_mtdsecapp.mbn Flashing : a_mdtp.img Flashing : a_abl.elf Flashing : a_keymaster.mbn Flashing : a_cmnlib.mbn Flashing : a_cmnlib64.mbn Flashing : a_devcfg.mbn Flashing : a_splash.img Flashing : b_rpm.mbn Flashing : b_tz.mbn Flashing : b_hyp.mbn Flashing : b_pmic.bin Flashing : b_btfm.mbn Flashing : b_mtdsecapp.mbn Flashing : b_mdtp.img Flashing : b_abl.elf Flashing : b_keymaster.mbn Flashing : b_cmnlib.mbn Flashing : b_cmnlib64.mbn Flashing : b_devcfg.mbn Flashing : b_splash.img Flashing : sec.dat Flashing : logfs.bin Flashing : storesec.mbn Flashing : gpt_backup4.bin Flashing : gpt_main5.bin Flashing : a_def_preset.mbn Flashing : b_def_preset.mbn Flashing : gpt_backup5.bin Wipe data ... BootConfig set to 0x01 Flashing done! Done! Elapsed: 00:06:38 Reconnect Power/Cable! Code: Operation : Backup Security [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 835 [MSM8998] ID_BLOCK_S : A16A2D1F ID_BLOCK_I : 0005E0E1 ID_BLOCK_L : 178F25B587487C3A694E61751FE47A2B ID_BLOCK_L : 846742BFF9DCAC5132AD040C46D683D4 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1ED-B0C1 0200 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29,50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Security backup saved to : 0005E0E1_A16A2D1F_CLSEC.simg Done! Elapsed: 00:00:52 Reconnect Power/Cable! Code: Operation : Repair Security Items [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 835 [MSM8998] ID_BLOCK_S : A16A2D1F ID_BLOCK_I : 0005E0E1 ID_BLOCK_L : 178F25B587487C3A694E61751FE47A2B ID_BLOCK_L : 846742BFF9DCAC5132AD040C46D683D4 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1ED-B0C1 0200 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29,50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Select following fields : IMEI1 : 35890644xxxx IMEI2 : 35890644xxxx Processing Block #0 Processing Block #1 Processing Block #2 Processing Block #3 Processing Block #4 Processing Block #5 Processing Block #6 Processing Block #7 Processing Block #8 Done! Elapsed: 00:01:04 Reconnect Power/Cable! Code: Operation : Restore Security [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 835 [MSM8998] ID_BLOCK_S : A16A2D1F ID_BLOCK_I : 0005E0E1 ID_BLOCK_L : 178F25B587487C3A694E61751FE47A2B ID_BLOCK_L : 846742BFF9DCAC5132AD040C46D683D4 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1ED-B0C1 0200 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29,50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Restore security ... Security restored! Clearing device ... Clear done! Done! Elapsed: 00:01:02 Code: Operation : Restore BootLoader [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 835 [MSM8998] ID_BLOCK_S : A16A2D1F ID_BLOCK_I : 0005E0E1 ID_BLOCK_L : 178F25B587487C3A694E61751FE47A2B ID_BLOCK_L : 846742BFF9DCAC5132AD040C46D683D4 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1ED-B0C1 0200 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29,50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Bootloader restored! Done! Elapsed: 00:00:50 |
The Following 17 Users Say Thank You to JayDi For This Useful Post: |
10-04-2017, 13:32 | #4 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
Read here http://forum.gsmhosting.com/vbb/12715520-post13.html | |
11-21-2017, 16:09 | #5 (permalink) |
Freak Poster Join Date: Feb 2012 Location: dhaka Age: 36
Member: 1724593 Status: Offline Sonork: 100.1671528 Thanks Meter: 48 | nokia 8 Unlock BootLoader after set dead Operation : Identify [FTM] [ v1.01 ] -> Power Off Phone, wait 5-10 seconds, Insert USB cable Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : NB1 HW version : PVT1 HW variant : MSM UFS SW version : NB1-303A-0-00WW-B01 SW secured : YES RF suppBAND : G_850_900_1800_1900^W_1_2_5_8^L_1_2_3_4_5_7_8_20 Done! Elapsed: 00:00:09 Operation : Unlock BootLoader [FTM] [ v1.01 ] -> Power Off Phone, wait 5-10 seconds, Insert USB cable Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : NB1 HW version : PVT1 SW version : NB1-303A-0-00WW-B01 All done! Switching to main mode -- > Info : Use "Restore BootLoader" after done need operations with device! -- > Hint : FW Flashing will automatically restore bootloader! Done! Elapsed: 00:00:11 |
02-23-2018, 08:01 | #7 (permalink) |
Freak Poster Join Date: May 2006 Location: Delhi
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | Repair Security cant see Repair Security key in nk2 v1.02 i try switch my dongle uk edition on and off but same cant see repair security how to enable this fitucher |
02-23-2018, 20:13 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | For start - you must check your local law. It not allow manipulate security. But, if you really want activate it and accept all possible effects after - use search. All explained. |
03-09-2018, 06:12 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Check identify log now in EXTRA tab ( Extra - Identify ). With v1.03 Check which BOOT_PART used - A or B. Set that option in Flash Tab - under flash file select there is options for Nokia 8. Reflash device again. |
06-05-2018, 18:51 | #14 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | nokia 8 hang on logo Infinity-Box BEST Nokia [HMD] Module [NK2] v1.02 Operation : Unlock BootLoader [FTM] [ v1.02 ] -> Power Off Phone, wait 5-10 seconds, Insert USB cable Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Unlock BootLoader [FTM] [ v1.02 ] -> Power Off Phone, wait 5-10 seconds, Insert USB cable Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Unlock BootLoader [FTM] [ v1.02 ] -> Power Off Phone, wait 5-10 seconds, Insert USB cable Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! cell is not detecting assit plzz regards |
