04-10-2013, 05:48 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: pakistan hafizabad
Member: 700741 Status: Offline Sonork: 100.1617188 Thanks Meter: 409 | nokia asah 205 flash done with best dongle Core : v1.62 , BB5XG FlashEngine : v4.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm862__03.19.mcusw PPM : rm862__03.19.ppm_ma3 CNT : rm862__03.19.image_ma3_059Q0D1 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.55_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm862__03.19.mcusw Image : rm862__03.19.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x017C0000 Erasing, wait ... Erase done, time : 00:02:02 Write , Start : 0x40280000 , Len : 0x017C0000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm862__03.19.ppm_ma3 Image : package_ma3.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A40000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:20 Write , Start : 0x41A40000 , Len : 0x003F0518 Flashing , wait ... Region flash done, time : 00:00:04 ===Flashing [CNT]=== File : rm862__03.19.image_ma3_059Q0D1 Image : package_ma3_059Q0D1.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42080000 , Len : 0x01DA0000 Erasing, wait ... Erase done, time : 00:03:18 Write , Start : 0x42080000 , Len : 0x00F20000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip Flashing done! Total flash time : 00:06:56 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:36 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok thx infinty team |
The Following User Says Thank You to MALIKTARIQ For This Useful Post: |
