03-31-2016, 01:27 | #1 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Ghana
Member: 1809548 Status: Offline Sonork: mysty619/100.167036 Thanks Meter: 120 | nokia asha 200(rm-761) flashin problem after flash only keypad light immediatly wen put in battry and fone not pwer on again.i flashed 2 times with the same flash file but still the same please this is log SSChannel : Create SC SSChannel : SC Created! Selected Variant : RM-761 NDT MEA15 COMMON-ENGLISH PINK Firmware Version : 11.95 SSChannel : DC Ok with code 0x04 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-761 not exist. Attempt to create Prepare done, collect info [Query] : rm761__11.95.image_mem_059J547 , 16.72 MiB [Query] : rm761__11.95.mcusw , 25.47 MiB [Query] : rm761__11.95.ppm_mem , 5.68 MiB [Query] : RM761_059J547_11.95_018.vpl , 3.88 KiB Files to download : 4 Total size to download : 47.87 MiB Downloading now, please, wait... [Download] : rm761__11.95.image_mem_059J547 [Download] : rm761__11.95.mcusw [Download] : rm761__11.95.ppm_mem [Download] : RM761_059J547_11.95_018.vpl Verify files now ... [Verify Ok] : rm761__11.95.mcusw [Verify Ok] : rm761__11.95.ppm_mem [Verify Ok] : rm761__11.95.image_mem_059J547 All done, all files were downloaded! Core : v2.20 , BB5XG FlashEngine : v10.1 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm761__11.95.mcusw PPM : rm761__11.95.ppm_mem CNT : rm761__11.95.image_mem_059J547 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. Elapsed: 00:00:39 Connect phone on selected interface... Core : v2.20 , BB5XG FlashEngine : v10.1 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm761__11.95.mcusw PPM : rm761__11.95.ppm_mem CNT : rm761__11.95.image_mem_059J547 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 35461005xxxxxxx IMEI 2 : 35461005xxxxxxx PCcode : 059J547 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354610059903599_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm761__11.95.mcusw Image : rm761__11.95.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:02 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:15 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:58 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x495E ===Flashing [PPM]=== File : rm761__11.95.ppm_mem Image : package_mem.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00740000 Erasing, wait ... Erase done, time : 00:00:17 Write , Start : 0x41A80000 , Len : 0x00576C00 Flashing , wait ... Region flash done, time : 00:00:12 CRC check passed , 0xDFD6 ===Flashing [CNT]=== File : rm761__11.95.image_mem_059J547 Image : package_mem_059J547.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:02:43 Write , Start : 0x421C0000 , Len : 0x01080000 Flashing , wait ... Region flash done, time : 00:00:39 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:04 No write data, skip CRC check passed , 0xCECB Flashing done! Total flash time : 00:06:22 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Connect phone on selected interface... Elapsed: 00:09:20 Connect phone on selected interface... please check and help me. tanks in advance |
