Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 04-22-2012, 07:55   #1 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Smile Nokia Asha 202 (RM-834) Flashing :)
Core : v1.44 , FlashEngine : v1.35
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm834__20.28.mcusw
PPM : rm834__20.28.ppm_kz
CNT : rm834__20.28.image_kz_059M5N0
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.47_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 351668050xxxxxx
IMEI 2 : 351668050xxxxxx
PCcode : 059M695
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\351668050xxxxx_351668050xxxx_2nd_XG213.rpl
   ===Flashing [MCU]===
File : rm834__20.28.mcusw
Image : rm834__20.28.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01B40000
Erasing, wait ...
Erase done, time : 00:00:54
Write , Start : 0x40280000 , Len : 0x01AC0000
Flashing , wait ...
Region flash done, time : 00:00:36
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
   ===Flashing [PPM]===
File : rm834__20.28.ppm_kz
Image : package_kz.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41DC0000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:00:08
Write , Start : 0x41DC0000 , Len : 0x003A8154
Flashing , wait ...
Region flash done, time : 00:00:04
   ===Flashing [CNT]===
File : rm834__20.28.image_kz_059M5N0
Image : package_kz_059M5N0.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x424C0000 , Len : 0x01960000
Erasing, wait ...
Erase done, time : 00:00:56
Write , Start : 0x424C0000 , Len : 0x00C00000
Flashing , wait ...
Region flash done, time : 00:00:14
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:02
No write data, skip
Flashing done!
Total flash time : 00:03:02
Reboot phone now...
Reading Phone Info....
Connected phone -   202
Software Info:     V 20.28 22-03-12 RM-834 (c) Nokia
IMEI:  35166805xxxxx
PPM version :   V 20.28 22-03-12 RM-834 (c) Nokia             KZ
Product code:  059M695
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Read RPL
CPUID : XGOLD 213
2nd : Custom
2nd boot Ok, 01
2nd ready, AA
Sending Algo
ALG : Custom
Algo sent Ok
BL : Quantum_Bootloader_2.5_M1S1
Boot done!
Communication verify done... Preparing...
SL3 Simlock read (XGOLD) ... ok
WMDRM Key read ... Ok
CMLA Key read ... Ok
Reboot....
CPUID : XGOLD 213
2nd : Custom
2nd boot Ok, 01
2nd ready, AA
Sending Algo
ALG : Custom
Algo sent Ok
Boot done!
Reading CCC
Reading HWC
Reading NPC
PCcode : 059M695
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
CMLA_KEY Data saved...
RPL saved : C:\InfinityBox\BEST 2\BEST\Backup\Cert\351668050xxxxx_351668050xxxxxx_XG213.rpl
The Following 2 Users Say Thank You to Dzirt For This Useful Post:
Old 04-22-2012, 08:11   #2 (permalink)
Member: 212656
next update coming soon...
Old 04-22-2012, 08:29   #3 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
It already on support area
Old 08-23-2012, 20:02   #4 (permalink)
Member: 40446
possible downgrade asha 202?
Old 08-24-2012, 04:51   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Seems, you not have any piece of brain. Stop spamming and satrt reading.
All XG213 support dwg.
Old 08-24-2012, 08:18   #6 (permalink)
Member: 40446
Software ver : V 20.36 24-05-12 RM-834 (c) Nokia
IMEI 1 : 353271056380629
IMEI 2 : 353271056380637
PPM : V 20.36 24-05-12 RM-834 (c) Nokia I
CNT : Content: i_059N1J6 V 20.36 24-05-12 RM-834 (c) Nokia
Product SN : 37F16B4BI
Product code : 059N1J6
Base Prd.code: 059N243
Module code : 0205125
Long Prod.SN : 0
Hardware info=======
HWID : 2300
Batery: 3788 mV
CMT BT: 19b5-22012
LCDVer: TPO
Lock info ===========
IMEI : 353271056380629
IMEI spNet : 3A 35 72 01 65 83 60 02
IMEI svNet : 33 35 72 01 65 83 60 02 F4
Sl Conf : 001-01-00000000000
Sl Prof : 800000000003000-B
Sl Aux : 000B0000
Hw Sig : 0579E53B63AF1C02
Country : Test SIM (Open)
Operator : NOKIA (Open)
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
CRT308 Backup Created
INFINEON : SuperDongle not exist (It is Ok)
SimLock status : Ok
Security status : Ok
PA_SL3 phone , SP_CODE_LEN : 15
Cert sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:55
Flashing , wait ...
Region flash done, time : 00:00:43
Erasing, wait ...
No write data, skip
File : rm834__20.28.ppm_d
Image : package_d.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Erasing, wait ...
Erase done, time : 00:00:09
Write , Start : 0x41DC0000 , Len : 0x004EC550
Flashing , wait ...
Region flash done, time : 00:00:06
File : rm834__20.28.image_d_059M6T0
Image : package_d_059M6T0.image.fls
Cert sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:00:58
Write , Start : 0x424C0000 , Len : 0x00C60000
Flashing , wait ...
Region flash done, time : 00:00:16
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:03:16
Reboot phone now...
IMEI: 353271056380629
PPM version : V 20.28 22-03-12 RM-834 (c) Nokia D
Product code: 059N1J6
Checking...
Read Info Done!
Total - 42 certs
Battery voltage is enough for start
Done!
Elapsed: 00:04:01
Old 08-24-2012, 10:08   #7 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
So, now you know answer and knoe how do it
Congrats!
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.28007 seconds with 11 queries
