10-23-2014, 11:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | Nokia C2-01 Flashing problem !!!!!!!! when i start Flashing a Nokia C2-01 RM-721,takes few seconds at: PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode. After that ---->No any CRT data (MCU damaged/CERT erased), skip saving Finaly ---->Partitioning error! Phone Not respond! This is Log: Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm721__11.40.mcusw PPM : rm721__11.40.ppm_meaa CNT : rm721__11.40.image_meaa_059D649 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600000001020C192102044100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 07A002080BCE15497C4CF1DF4193C4B3EBC8FF12 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... - > No any CRT data (MCU damaged/CERT erased), skip saving === SW Version Check === - > Can not collect initial info, continue flashing... - > Hope, this version will be ok === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm721__11.40.mcusw Partitioning.... Partitioning error! Phone Not respond! Connect phone on selected interface... Elapsed: 00:00:42 Connect phone on selected interface... is it software or hardware problem ??? Thanks |
10-23-2014, 11:56 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Use other PC , seems as some HW/SW problem. Should be flashed normally on different configuration. It related to some limited count of RAP4 phones. |
10-23-2014, 12:01 | #3 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | Today I Face This Same Problem With Best Dongle Flashing By Nokia C2 rm-704 When 42% Flash Write Than Hung Than Solved it By Cyclone Box Please Team Fixed This Infinion Flashing Bug Best Regard Br Palash Ahammad |
10-23-2014, 13:00 | #5 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | @rafanachi I had same problem , but couldn't fix check/read it http://forum.gsmhosting.com/vbb/f641...error-1827912/ If you want to factory reset/read info, check it |
