07-27-2014, 12:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: PL Age: 44
Member: 477842 Status: Offline Thanks Meter: 80 | NOKIA C2-01 White screen when card incorrect I read blf nck15 code, and when try to write to nokia c2-01 without oryginal sim card , I always have : Wrong Code: I reflash phone to ver 11.40 ,but always when put sim card from othere operator, power on phone I always have WHITE SCREEN, is there any solution to unlock this Nokia c2-01 rm-721 ??? |
07-27-2014, 14:43 | #3 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | Reading Phone Info.... Connected phone - Nokia C2-01 Software ver : V 11.40 24-10-12 RM-721 (c) Nokia IMEI : 3559WWW.AT-KOM.PL XappVer : 00000758 DSP Ver : SPR91_11.40 PPM : V 11.40 24-10-12 RM-721 (c) Nokia B CNT : Content: b_059D688 V 11.40 24-10-12 RM-721 (c) Nokia Product SN : F80C34AAH Product code : 059J299 Base Prd.code: 059C872 Module code : 0204769 Long Prod.SN : 0 Hardware info======= HWID : 1002 Retu : 51 Tahvo : 00 Batery: 4082 mV CMT BT: 1673-46038 LCDVer: SEIKO Lock info =========== IMEI : 3559WWW.AT-KOM.PL IMEI spNet : 3A 55 49 02 85 65 04 04 IMEI svNet : 33 55 49 02 85 65 04 74 F6 Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! So, What you need bro ? |
07-29-2014, 16:16 | #5 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | Resetting selected items... Check phone mode... Phone in Normal mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:09 Reading Phone Info.... Connected phone - Nokia C2-01 Software ver : V 11.40 24-10-12 RM-721 (c) Nokia IMEI : 35www.at-kom.pl XappVer : 00000758 DSP Ver : SPR91_11.40 PPM : V 11.40 24-10-12 RM-721 (c) Nokia B CNT : Content: b_059D688 V 11.40 24-10-12 RM-721 (c) Nokia Product SN : F80C34AAH Product code : 059J299 Base Prd.code: 059C872 Module code : 0204769 Long Prod.SN : 0 Hardware info======= HWID : 1002 Retu : 51 Tahvo : 00 Batery: 4049 mV CMT BT: 1673-46038 LCDVer: SEIKO Lock info =========== IMEI : 355www.at-kom.pl IMEI spNet : 3A 55 49 02 85 65 04 04 IMEI svNet : 33 55 49 02 85 65 04 74 F6 Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Using F-bus count... Sending code 173301168394838 Level : 1 to SimLock Server... Simlock Server Answer: Bad Code... Done! |
07-30-2014, 14:48 | #7 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | From online server, i read this 2 pieces with bb5 easy service tool, after fev days I`we got codes. This server I use 2 years and there is no problem, but nokia c2-01 and asha always have kind of problem with write code. Last edited by at-kom; 07-30-2014 at 14:54. |
07-30-2014, 20:13 | #9 (permalink) | |
Member: 477842 Status: Offline Thanks Meter: 80 | Quote:
I use this codes from server for my imei: #pw+173301168394838+1# #pw+228290907590364+2# #pw+742992421051804+3# #pw+343935704825656+4# #pw+052530371330700+5# #pw+600659594939159+6# #pw+232885084968826+7# and always have : CODE ERROR any solution ? | |
09-13-2014, 19:46 | #11 (permalink) |
No Life Poster Join Date: Jan 2005 Location: ALGERIA Age: 53
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | same here nokia from switzerland (swisscom) locked without sim card works poerfectly! when insert sim card : nokia logo after white screen ????????????? Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C2-01 Software ver : V 11.40 24-10-12 RM-721 (c) Nokia IMEI : 3566880 XappVer : 00000744 DSP Ver : SPR91_11.40 PPM : V 11.40 24-10-12 RM-721 (c) Nokia MEC CNT : Content: meac_059D643 V 11.40 24-10-12 RM-721 (c) Nokia Product SN : 0D14D3FBH Product code : 059J299 Base Prd.code: 059C872 Module code : 0204769 Long Prod.SN : 0 Hardware info======= HWID : 1002 Retu : 51 Tahvo : 00 Batery: 3839 mV CMT BT: 1673-46038 LCDVer: SEIKO Lock info =========== IMEI : 356688058363013 IMEI spNet : 3A 65 86 08 85 63 03 01 IMEI svNet : 33 65 86 08 85 63 03 71 F6 Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
09-13-2014, 19:49 | #12 (permalink) |
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | here it's self tests: Initializing Tests... IMEI : 3566880 , Phone : RM-721 Nokia C2-01 Get keys... PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_RADIO_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST PASSED | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_MIC_TEST PASSED | ST_KELVIN_CHARGING_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_KELVIN_XEAR_TEST PASSED | ST_INTERNAL_ANTENNA_TEST PASSED | ST_BACKLIGHT_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_TAHVOINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_PWR_KEY_TEST NOT EXECUTED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT EXECUTED | ST_CDSP_TX_IQ_TEST NOT EXECUTED | ST_CDSP_TXC_DATA_TEST NOT EXECUTED | ST_CDSP_RX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST SelfTests end |
09-13-2014, 20:02 | #13 (permalink) |
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | reset all done but same error + full flashing with latest Fw ,also same thing ! when put original sim card from swisscom phone is ok ???? strange!!!!!! and with motorola test card works fine ! the problem is with non accepted sim carde ! moqriba ????? |
